查看: 4990|回復: 6
51單片機籃球計分器有些問題不懂
這個是我的圖,想問問有沒有什么錯誤。
還想詢問一下,如果想在加分的同時進行24秒復位,就是用一個按鍵完成這兩個任務是否可行
T0計時器進行12分鐘的計時,T1計時器同時進行24秒和14秒的倒計時可行嗎?
這里我不懂,求幫助。
ID:169181 發表于 2017-6-15 22:37 | 只看該作者
void T0_init()
        EA=1;
        TMOD=0x11;
        TH0=(65536-46080)/256;
        TL0=(65536-46080)%256;
        ET0=1;
        TR0=0;
        TH1=(65536-46080)/256;
        TL1=(65536-46080)%256;
        ET1=1;
        TR1=0;
void T0_interrupt(void) interrupt 1 using 1
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        T0_num++;
        if(T0_num==20)
                T0_num=0;
                if(second==0)
                        minute--;
                        second=59;
                        second--;
                        if(second==0&&minute==0)
                                TR0=0;
                                speaker=0;
void T1_interrupt(void) interrupt 3        using 0
        TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
        T1_num++;
        if(T1_num==20)
                T1_num=0;
                if(second24!=0)
                        second24--;
                        TR1=0;
                        second24=24;
                        buzzer(1);
#endif
ID:169181 發表于 2017-6-15 22:39 | 只看該作者
void chuli(uchar key)
        if(key==1)
                bifeng[0]++;
        second24=24;
                T1_num=0;
        if(key==2)
                bifeng[0]=bifeng[0]+2;
        second24=24;
                T1_num=0;
        if(key==3)
                bifeng[0]=bifeng[0]+3;
        second24=24;
                T1_num=0;
        if(key==5)
                bifeng[1]++;
        second24=24;
                T1_num=0;
        if(key==6)
                bifeng[1]=bifeng[1]+2;
        second24=24;
                T1_num=0;
        if(key==7)
                bifeng[1]=bifeng[1]+3;
        second24=24;
                T1_num=0;
        if(key==4)
                if(bifeng[0]!=0)
                        bifeng[0]--;
  if(key==8)
                if(bifeng[1]!=0)
                        bifeng[1]--;
        if(key==14)
                if(jieshu<4)
                        jieshu++;
                        jieshu=1;
        if(key==13)
                TR0=~TR0;
                if(TR0==1&&second==0&&minute==0&&T0_num==0)
                        speaker=1;
                        T0_num=0;
                        second=0;
                        minute=12;
        if(key==12)
                TR1=~TR1;
        if(key==11)
                foul[0]++;
        if(key==12)
                foul[1]++;
        if(key==9)
                pause[0]++;
        if(kry==10)
                pause[1]++;
ID:169181 發表于 2017-6-15 22:41 | 只看該作者
uchar jiema(unsigned char key)
   uchar n;
   switch(key)
           case 24: n= 1; break;
           case 40: n= 2; break;
           case 72: n= 3; break;
           case 136: n= 4; break;
           case 20: n= 5; break;
           case 36: n= 6; break;
           case 68: n= 7; break;
           case 132: n= 8; break;
           case 18: n= 9; break;
           case 34: n= 10; break;
           case 66: n= 11; break;
           case 130: n= 12; break;
           case 17: n= 13; break;
           case 33: n= 14; break;
           case 65: n= 15; break;
           case 129: n= 16; break;
           default: break;
   return n;
還想問一下,這里是如何定義的鍵盤號?
鍵盤換到P1口的話,case后的數會改變嗎
ID:123289 發表于 2017-6-16 12:13 | 只看該作者
圖可以。
所提問題也都能實現,只有一個要注意的地方:“用一個按鍵完成這兩個任務”:
當此鍵按下時,你有下列四個選擇項,你必須有選擇或區分的方式。
1、甲乙兩件事都不處理;
2、甲乙兩件事都處理;
3、做甲不做乙;
4、不做甲做乙。
ID:169181 發表于 2017-6-17 21:04 | 只看該作者
yzwzfyz 發表于 2017-6-16 12:13
圖可以。
當此鍵按下時,你 ...
那我要是用T1進行24秒或者14秒的倒計時,打斷那里應該怎么寫程序?
ID:82765 發表于 2017-6-18 12:39 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
