查看: 9085|回復: 9
51單片機捕捉占空比(仿真+源程序)
ID:209873 發表于 2017-6-10 16:19 | 顯示全部樓層 |閱讀模式
這個程序演示了51單片機捕捉占空比并顯示在lcd12864液晶屏上面(帶仿真)
仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載):
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #include <string.h>
  4. #include <stdio.h>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7. sbit RS=  P2^0  ;
  8. sbit RW=  P2^1  ;
  9. sbit EN=  P2^2  ;
  10. uint cc=0,shidu=0 ;
  11. uchar LCD_LINE_ONE[16]={"     hs1101 "};
  12. uchar LCD_LINE_TWO[16]={"HZ:       hz"};
  13. uchar LCD_LINE_THR[16]={"CAP:      pf"};
  14. uchar LCD_LINE_FOU[16]={"HR:       % "};
  15. uint        Cap0 =        0;
  16. uint        Cap1 =         0;
  17. uint N=0,N1=0,NP1=0 ;
  18. unsigned int        CF1 = 0 ;
  19. void delay( ms )
  20. {
  21.           int i ;
  22.           while(ms--)
  23.           {
  24.                for(i=0 ;i<5 ;i++ )  ;
  25.           }
  26. }
  27. uchar Read_LCD_State()
  28. {
  29.         uchar state;
  30.         RS=0;RW=1;EN=1;delay(1);
  31.         state=P0;
  32.         EN = 0;delay(1);
  33.         return state;
  34. }
  35. void LCD_Busy_Wait()
  36. {
  37.         while((Read_LCD_State()&0x80)==0x80);
  38.         delay(5);
  39. }
  40. void Write_LCD_Zhilin(uchar zl)
  41. {
  42.         LCD_Busy_Wait();
  43.         RS=0;RW=0;
  44.         EN=0;
  45.         P0=zl;
  46.         EN=1;
  47.         delay(1);
  48.         EN=0;
  49. }
  50. void Write_LCD_shuju(uchar date)
  51. {
  52.         LCD_Busy_Wait();
  53.         RS=1;RW=0;
  54.         EN=0;
  55.         P0=date;
  56.         EN=1;
  57.         delay(1);
  58.         EN=0;
  59. }
  60. void LCD_INIT()
  61. {
  62.     Write_LCD_Zhilin(0x38);          // 顯示模式設置
  63.         delay(1);
  64.         Write_LCD_Zhilin(0x01);          // 顯示清屏
  65.         delay(1);
  66.         Write_LCD_Zhilin(0x06);          // 光標移動設置
  67.         delay(1);
  68.         Write_LCD_Zhilin(0x0c);          // 開及光標設置
  69.         delay(1);
  70. }
  71. void Display_LCD_String(uchar p,uchar *s)
  72. {
  73.         uchar i;
  74.         Write_LCD_Zhilin(p|0x80)        ;    //寫地址高位為一
  75.         //Write_LCD_Zhilin(0x40|0x80)        ;
  76.         for(i=0;i<16;i++)
  77.         {
  78.                 Write_LCD_shuju(s[i]);
  79.                 delay(1);
  80.         }
  81. }
  82. void Timer2Init(void)
  83. {
  84.     T2CON = 0x09;        //定時器2工作在捕獲模式,由外部輸入信號產生跳變
  85.     RCAP2L = 0x00;        //捕獲保存TL2、TH2的值,CL,CH,的值自動賦給RCAP2L,RCAP2H.
  86.     RCAP2H = 0x00;
  87.     TL2 = 0x00;
  88.     TH2 = 0x00;
  89.     ET2 = 1;        //定時器2中斷使能
  90.     EA = 1;
  91.         //IP = 0x20;        //高優先級
  92.     TR2 = 1;        //定時器2的啟動開關
  93. }
  94.    void ISR_Timer2(void) interrupt 5
  95. {
  96.     //  清除Timer2溢出標志
  97.         if(TF2)//溢出中斷,進行結算
  98.         {
  99.                 TR2 = 0;        //定時器停止計數
  100.                 TF2 = 0;        //定時器2溢出標志清
  101.                 NP1=N;
  102.                 N = 0;
  103.                 if(Cap1 >Cap0)
  104.                         {
  105.
  106.                              CF1 = 1000000 * (NP1-1)  / (Cap1 - Cap0);//捕獲回來的頻率
  107.                      }
  108.
  109.
  110.                 TL2 = 0x00;                           //數據重載
  111.                 TH2 = 0x00;
  112.                 TR2 = 1;
  113.         }
  114.         else                                     //捕獲中斷
  115.         {
  116.                 EXF2 = 0;                            //捕獲中斷標志
  117.                 if(N==0)
  118.                 {
  119.                         Cap0 = RCAP2H;                   //高8位
  120.                         Cap0 = (Cap0 << 8) | RCAP2L;     //低8位
  121.                         N = 1;
  122.                 }
  123.                 else
  124.                 {
  125.                         N++;
  126.                         Cap1 = RCAP2H;
  127.                         Cap1 = (Cap1 << 8) | RCAP2L;
  128.                 }
  129.         }
  130. }
  131. void main()
  132. {
  133.      int  i ;
  134.          LCD_INIT();
  135.          Timer2Init();
  136.          Display_LCD_String(0x00,LCD_LINE_ONE);
  137.          while(1)
  138.          {
  139.
  140.                                  cc=479000/CF1 ;
  141.                            shidu=(cc-162)*100/38 ;
  142.                             sprintf(LCD_LINE_TWO+4,"%d",        CF1 );
  143.                            Display_LCD_String(0x40,LCD_LINE_TWO);
  144.                            sprintf(LCD_LINE_THR+4,"%d", cc);
  145.                            Display_LCD_String(0x10,LCD_LINE_THR);
  146.                            sprintf(LCD_LINE_FOU+3,"%5d",shidu );
  147.
  148.
  149.                             Display_LCD_String(0x50,LCD_LINE_FOU);
  150. ……………………
  151. …………限于本文篇幅 余下代碼請從51黑下載附件…………
52buhuo.zip (62.45 KB, 下載次數: 163)
ID:210623 發表于 2017-6-12 21:59 | 顯示全部樓層
樓主,我想獲得一個方波的頻率,如何寫程序?謝謝了!
ID:210623 發表于 2017-6-12 22:03 | 顯示全部樓層
能否修改一下,記錄一個方波的頻率?謝謝!
ID:210623 發表于 2017-6-12 22:04 | 顯示全部樓層
樓主,我需要記錄一個方波的頻率,如何寫程序?
ID:210623 發表于 2017-6-12 22:10 | 顯示全部樓層
樓主能否寫一個記錄方波頻率的程序?
ID:308632 發表于 2018-4-15 16:11 來自觸屏版 | 顯示全部樓層
luodongxu 發表于 2017-6-12 22:04
用定時器及中斷
ID:366653 發表于 2018-7-7 09:37 | 顯示全部樓層
好東西,正好用上,希望下載了能用
ID:720658 發表于 2020-5-24 15:11 | 顯示全部樓層
求大神指導一下dsn格式的仿真文件要如何打開?
ID:775464 發表于 2020-6-12 09:53 來自觸屏版 | 顯示全部樓層
S[i]數組前面怎么沒有定義啊?代表什么?
ID:859238 發表于 2020-12-13 01:23 | 顯示全部樓層
哇,好棒喔,最近在學這部分內容,液晶屏一直用的不好,這個正好做參考,挺好&#128077;
