查看: 2811|回復: 1
電壓表程序
ID:205169 發表于 2017-5-26 17:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
A/D
#include <reg51.h>
uchar code LEDData[]= {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f};
sbit  OE=P2^7;
sbit  EOC=P2^6;
sbit  START=P2^5;
sbit  CLK=P2^4;
sbit  ALE=P2^5;
void Delay(uint count)
uchar i;
    while(count--)
for(i=0;i<120;i++);
void Display_Result(uchar num)
num=num*5/255;
P2 = 0xf7;    //FB=1111 0111
P0 = LEDData[num%10];
Delay(5);
P2 = 0xfb;
P0 = LEDData[num%100/10];
Delay(5);
P2 = 0xfd;
P0 = LEDData[num/100];
Delay(5);
void main(void)
TMOD = 0x02;
TH0 = 206;
TL0 = 206;
TR0=1;
EA=1;
ET0=1;
ALE=0;
ALE=1;
START = 0;
START= 1;
START = 0;
while(EOC==0);
OE = 1;
Display_Result(P1);
OE = 0;
void Timer0_INT() interrupt 1
CLK = !CLK;
ID:227504 發表于 2017-12-8 20:06 | 只看該作者
拜托,有原理圖可好
