使用51單片機模擬USB鍵盤原理圖(附件里面可以下載清晰版的電路圖及完整源碼):
2017-4-26 21:25 上傳
2017-4-26 21:25 上傳
單片機源程序:
- 本程序只供學習使用,未經作者許可,不得用于其它任何用途
- 我的郵箱:computer-lov@tom.com
- USBKeyBoard.C file
- 作者:Computer-lov
- 建立日期: 2007.03.20
- 修改日期: 2007.03.23
- 版本:V1.1
- 版權所有,盜版必究。
- Copyright(C) Computer-lov 2007-2017
- All rights reserved
- #include <AT89x52.H>
- #include "USB.H"
- #include "PDIUSBD12.H"
- #include "My_type.h"
- #include "UART.H"
- #include "key.h"
- #include "keyboard.h"
- #define USB_COMMAND_ADD 1
- #define USB_DATA_ADD 0
- //USB芯片連接引腳
- #define USB_DATA P0
- #define USB_A0 P3_5
- #define USB_WR P3_6
- #define USB_RD P3_7
- #define USB_INT P3_2
- #define ENDPOINT_NUMBER 2
- #define MAX_CONTROL_DATA_SIZE 16
- //控制傳輸時保存數據
- CONTROL_DATA_BUFF Control_Data;
- //緩沖
- uint8 idata buffer[64];
- //交換數據時用的指針
- uint8 *pData;
- uint8 idle; //空閑狀態
- uint8 protocol; //當前協議
- //高低字節交換
- #define SWAP16(x) ((((uint16)(x))<<8)|(((uint16)(x))>>8))
- //取一個整數的低字節
- #define LSB(x) ((uint8)(x))
- //取一個整數的高字節
- #define MSB(x) ((uint8)(((uint16)(x))>>8))
- //字符串描述符所用的語言種類
- code uint8 LANGUAGE_ID[4]={0x04,0x03,0x09,0x04};
- //設備序列號
- code uint8 device_serial_number[]=
- {22,STRING_DESCRIPTOR,'2',0,'0',0,'0',0,'7',0,'-',0,'0',0,'3',0,'-',0,'2',0,'3',0};
- //廠商字符串
- code uint8 ManufacturerString[80]=
- {80,STRING_DESCRIPTOR,0x35,0x75,0x11,0x81,0x08,0x57,0x08,0x57,0x84,0x76,0xB6,0x5B,
- 0x53,0x5F,'-',0x00,'-',0x00,'-',0x00,'-',0x00,'@',0,0x20,0x00,'H',0,'t',0,'t',0,
- 'p',0,':',0,'/',0,'/',0,'C',0,'o',0,'m',0,'p',0,'u',0,'t',0,'e',0,'r',0,'0',0,
- '0',0,'.',0,'2',0,'1',0,'i',0,'c',0,'.',0,'o',0,'r',0,'g',0};
- //產品字符串
- code uint8 ProducterString[80]=
- {80,STRING_DESCRIPTOR,0x35,0x75,0x11,0x81,0x08,0x57,0x08,0x57,0x5A,0x50,0x84,0x76,
- 'U',0,'S',0,'B',0,0x2E,0x95,0xD8,0x76,'@',0,0x20,0x00,'H',0,'t',0,'t',0,
- code DEVICE_DESCRIPTOR_STRUCT device_descriptor= //設備描述符
- sizeof(DEVICE_DESCRIPTOR_STRUCT), //設備描述符的字節數大小
- DEVICE_DESCRIPTOR, //設備描述符類型編號
- 0x1001, //USB版本號
- 0x00, //USB分配的設備類代碼
- 0x00, //USB分配的子類代碼
- 0x00, //USB分配的設備協議代碼
- 0x10, //端點0的最大包大小
- 0x3412, //廠商編號VID,這里只是作為測試用,請使用自己的VID
- 0x7856, //產品編號PID,這里只是作為測試用,請使用自己的PID
- 0x0100, //設備出廠編號
- 0x01, //設備廠商字符串的索引
- 0x02, //描述產品字符串的索引
- 0x03, //描述設備序列號字符串的索引
- 0x01 //可能的配置數量
- //定義配置,接口,端點等描述符結構體,因為它們是隨配置描述符一起返回的
- typedef struct _CON_INT_ENDP_DESCRIPTOR_STRUCT
- CONFIGURATION_DESCRIPTOR_STRUCT configuration_descriptor;
- INTERFACE_DESCRIPTOR_STRUCT interface_descriptor;
- HID_DESCRIPTOR_STRUCT hid_descriptor;
- ENDPOINT_DESCRIPTOR_STRUCT endpoint_descriptor[ENDPOINT_NUMBER];
- }CON_INT_ENDP_DESCRIPTOR_STRUCT;
- code CON_INT_ENDP_DESCRIPTOR_STRUCT con_int_endp_descriptor=
- //configuration_descriptor //配置描述符
- sizeof(CONFIGURATION_DESCRIPTOR_STRUCT), //配置描述符的字節數大小
- CONFIGURATION_DESCRIPTOR, //配置描述符類型編號
- SWAP16(sizeof(CON_INT_ENDP_DESCRIPTOR_STRUCT)),
- 0x01, //只包含一個接口
- 0x01, //該配置的編號
- 0x00, //iConfiguration字段
- 0xA0, //采用總線供電,支持遠程喚醒
- 0xC8 //從總線獲取最大電流400mA
- //interface_descritor //接口描述符
- sizeof(INTERFACE_DESCRIPTOR_STRUCT), //接口描述符的字節數大小
- INTERFACE_DESCRIPTOR, //接口描述符類型編號
- 0x00, //接口編號為0
- 0x00, //該接口描述符的編號
- ENDPOINT_NUMBER, //非0端點數量為2,只使用端點主端點輸入和輸出
- 0x03, //人機接口設備(HID)類
- 0x01, //使用的子類:支持BIOS根啟動Boot的子類
- 0x01, //使用的協議:鍵盤
- 0x00 //接口描述符字符串索引
- //hid_descriptor
- sizeof(HID_DESCRIPTOR_STRUCT), //HID描述符的字節數大小
- HID_DESCRIPTOR, //HID描述符類型編號
- 0x1001, //HID類協議版本號,為1.1
- 0x21, //固件的國家地區代號,0x21為美國
- NUM_SUB_DESCRIPTORS, //下級描述符的數量
- REPORT_DESCRIPTOR, //下級描述符為報告描述符
- SWAP16(sizeof(KeyBoardReportDescriptor)) //下級描述符的長度
- //endpoint_descriptor[]
- { //主端點輸入描述
- sizeof(ENDPOINT_DESCRIPTOR_STRUCT), //端點描述符的字節數大小
- ENDPOINT_DESCRIPTOR, //端點描述符類型編號
- MAIN_POINT_IN, //端點號,主輸入端點
- ENDPOINT_TYPE_INTERRUPT, //使用的傳輸類型:中斷傳輸
- 0x4000, //該端點支持的最大包尺寸,64字節
- 0x0A //中斷掃描時間:設置為10ms
- { //主端點輸出描述
- MAIN_POINT_OUT, //端點號,主輸出端點
- union //程序標志位
- uint16 Register;
- struct
- uint8 bus_reset :1;
- uint8 suspend :1;
- uint8 remote_wakeup :1;
- uint8 int_isr :1;
- uint8 not_end :1;
- uint8 usb_idle :1;
- uint8 usb_busy :1;
- uint8 setup_packet_in :1;
- uint8 setup_packet_out :1;
- uint8 set_addr :1;
- uint8 usb_endp0_in :1;
- uint8 usb_endp2_in :1;
- uint8 usb_endp2_out :1;
- }flags;
- }usb_flags;
- union //中斷寄存器
- uint8 Register[2];
- struct
- uint8 control_out_port :1;
- uint8 control_in_port :1;
- uint8 port_out_1 :1;
- uint8 port_in_1 :1;
- uint8 main_out_port :1;
- uint8 main_in_port :1;
- uint8 suspend_change :1;
- uint8 DMA_EOT :1;
- uint8 not_use :7;
- }Interrupt;
- }Interrupt_Register;
- union //端點最后處理狀態
- uint8 Register;
- struct
- uint8 successful :1;
- uint8 error_code :4;
- uint8 setup_packet :1;
- uint8 data_1 :1;
- uint8 prestatus_not_read :1;
- }Status;
- }Last_Status;
- /***************** 延時x毫秒函數 ***********/
- void delay(uint16 x)
- uint16 i;
- uint16 j;
- for(i=0;i<x;i++)
- for(j=0;j<230;j++);
- /*******************************寫USB命令******************************************/
- void write_usb_command(uint8 usb_command)
- USB_A0=USB_COMMAND_ADD;
- USB_DATA=usb_command;
- USB_WR=0;
- USB_WR=1;
- USB_DATA=0xFF;
- /*********************寫一字節USB數據*******************************************/
- void write_a_usb_data(uint8 usb_data)
- USB_A0=USB_DATA_ADD;
- USB_DATA=usb_data;
- USB_WR=0;
- USB_WR=1;
- USB_DATA=0XFF;
- /****************************讀一字節USB數據************************************/
- uint8 read_a_usb_data(void)
- uint8 temp;
- USB_RD=0;
- temp=USB_DATA;
- USB_RD=1;
- return temp;
- /************************讀USB中斷寄存器**************************************/
- void read_interrupt_register(void)
- write_usb_command(Read_Interrupt_Register);
- Interrupt_Register.Register[0]=read_a_usb_data();
- Interrupt_Register.Register[1]=read_a_usb_data();
- /************************設置USB地址*******************************************/
- void set_usb_addr(uint8 addr)
- write_usb_command(Set_Address);
- write_a_usb_data(0x80|addr);
- Prints(" 設置地址.....................",1);
- Prints(" 地址為: ",0);
- PrintLongInt(addr);
- Prints("",1);
- /*************************端點使能******************************************/
- void set_endpoint_enable(void)
- write_usb_command(Set_Endpoint_Enable);
- write_a_usb_data(0x01);
- /****************************選擇終端點*************************************/
- uint8 select_endpoint(uint8 endp)
- write_usb_command(Select_EndPoint+endp);
- return read_a_usb_data();
- /****************************讀端點最后狀態**********************************/
- uint8 read_last_status(uint8 endp)
- write_usb_command(Read_Last_Status+endp);
- /****************************設置端點狀態**************************************/
- void set_endpoint_status(uint8 endp,uint8 status)
- write_usb_command(0x40+endp);
- write_a_usb_data(!status);
- /*****************************讀端點狀態**************************************/
- uint8 read_endpoint_status(uint8 endp)
- write_usb_command(0x80+endp);
- /************************清緩沖,在讀取緩沖數據后調用**************************/
- void clear_buffer(void)
- write_usb_command(Clear_Buffer);
- /***********************緩沖區數據有效,在寫緩沖后調用**************************/
- void validate_buffer(void)
- write_usb_command(Validate_Buffer);
- /***************************應答建立包************************************/
- void ack_setup(uint8 endp)
- select_endpoint(endp);
- write_usb_command(Ack_Setup);
- /***********************出錯處理******************************************/
- void error(uint8 number)
- Prints("有錯誤發生!!!",1);
- number=0;
- /*************************讀終端點緩沖****************************************/
- uint8 read_endpoint_buff(uint8 endp,uint8 len,uint8 * buff)
- uint8 i,j;
- read_last_status(endp);
- if(!(select_endpoint(endp))&0x01){error(0); return 0;}
- read_endpoint_status(endp);
- write_usb_command(Read_Buffer);
- read_a_usb_data();
- j=read_a_usb_data();
- if(j>len)
- j=len;
- for(i=0;i<j;i++)
- USB_RD=0;
- *(buff+i)=USB_DATA;
- USB_RD=1;
- clear_buffer();
- return j;
- /*************************寫終端點緩沖*****************************************/
- uint8 write_endpoint_buff(uint8 endp,uint8 len,uint8 * buff)
- uint8 i;
- write_usb_command(Write_Buffer);
- write_a_usb_data(0);
- write_a_usb_data(len);
- for(i=0;i<len;i++)
- USB_DATA=*(buff+i);
- USB_WR=0;
- USB_WR=1;
- USB_DATA=0XFF;
- validate_buffer();
- return len;
- /***************************斷開USB連接****************************************/
- void disconnect_usb(void)
- Prints("斷開USB連接........................",1);
- write_usb_command(0xf3);
- write_a_usb_data(0x0e);
- write_a_usb_data(0x47);
- delay(100);
- /*******************************連接USB**************************************/
- void connect_usb(void)
- Prints("連接USB...............",1);
- write_usb_command(0xf3); //初始化USBD12
- write_a_usb_data(0x1e); //連接USB
- write_a_usb_data(0x47); //設置頻率
- /***************************初始化USB***************************************************/
- void init_usb(void)
- Prints("USBD12芯片初始化",1);
- set_usb_addr(0);
- set_endpoint_enable();
- /****************************USB總線復位處理***********************************/
- void usb_bus_reset(void)
- Prints("USB總線復位................................",1);
- usb_flags.Register=0;
- /*****************************USB總線掛起處理**********************************/
- void usb_bus_suspend(void)
- Prints("USB總線掛起................................",1);
- /***************************設置地址***************************************/
- void set_usb_address(void)
- usb_flags.flags.set_addr=1;
- while(select_endpoint(1)&0x01);
- write_endpoint_buff(1,0,0);
- set_usb_addr(Control_Data.DeviceRequest.wValue);
- usb_flags.flags.usb_endp0_in=0;
- usb_flags.flags.setup_packet_out=0;
- /**************************獲取狀態響應*****************************************/
- void get_status(uint8 receiver)
- uint8 status[2];
- switch (receiver)
- case 0: //獲取設備狀態
- status[0]=0x00;
- status[1]=0x00;
- break;
- case 1: //獲取接口狀態
- status[0]=0x00;
- status[0]=0x00;
- break;
- case 2: //獲取端點狀態
- status[0]=0x00;
- status[1]=0x00;
- break;
- write_endpoint_buff(1,2,status);
- /*********************清除特性*******************************************/
- void clear_feature(uint8 receiver)
- Prints(" 清除特性................................",1);
- receiver=0;
- /*******************設置特性**************************************************/
- void set_feature(uint8 receiver)
- Prints(" 設置特性................................",1);
- receiver=0;
- /*****************************設置描述*****************************************/
- void set_descriptor(void)
- Prints(" 設置描述符................................",1);
- /***************************設置配置*******************************************/
- void set_configuration(void)
- Prints(" 設置配置................................",1);
- /************************獲取配置狀態******************************************/
- void get_configuration(void)
- uint8 value=0x01;
- Prints(" 獲取配置................................",1);
- write_endpoint_buff(1,1,&value);
- /****************************設置接口************************************/
- void set_interface(void)
- Prints(" 設置接口................................",1);
- /***************************獲取接口狀態***************************************/
- void get_interface(void)
- uint8 value=0x01;
- Prints(" 獲取接口................................",1);
- /***********************獲取描述符*********************************************/
- void get_descriptor(void)
- Prints(" 獲取描述符................................",1);
- if(!usb_flags.flags.not_end)
- switch(MSB(Control_Data.DeviceRequest.wValue))
- case DEVICE_DESCRIPTOR:
- Prints(" 獲取設備描述符................................",1);
- Control_Data.wCount=sizeof(DEVICE_DESCRIPTOR_STRUCT);
- Control_Data.pData=(uint8 *)(&device_descriptor);
- break;
- case CONFIGURATION_DESCRIPTOR:
- Prints(" 獲取配置描述符................................",1);
- Control_Data.wCount=SWAP16(con_int_endp_descriptor.configuration_descriptor.wTotalLength);
- Control_Data.pData=(uint8 *)(&con_int_endp_descriptor);
- if(Control_Data.wLength<Control_Data.wCount)Control_Data.wCount=Control_Data.wLength;
- break;
- case STRING_DESCRIPTOR:
- Prints(" 獲取字符串描述符................................",1);
- switch(LSB(Control_Data.DeviceRequest.wValue))
- case 0:
- Prints(" 獲取語言ID................................",1);
- Control_Data.wCount=LANGUAGE_ID[0];
- Control_Data.pData=LANGUAGE_ID;
- break;
- case 1:
- Prints(" 獲取廠商字符串................................",1);
- Control_Data.wCount=ManufacturerString[0];
- Control_Data.pData=ManufacturerString;
- break;
- case 2:
- Prints(" 獲取產品字符串................................",1);
- Control_Data.wCount=ProducterString[0];
- Control_Data.pData=ProducterString;
- break;
- case 3:
- Prints(" 獲取設備序列號................................",1);
- Control_Data.wCount=device_serial_number[0];
- Control_Data.pData=device_serial_number;
- break;
- default: break;
- break;
- default:
- Prints(" 獲取其它描述符..................描述符索引為:",0);
- PrintLongInt(MSB(Control_Data.DeviceRequest.wValue));
- Prints("",1);
- break;
- //寫數據到D12輸入端點
- if(Control_Data.wCount>=MAX_CONTROL_DATA_SIZE)
- write_endpoint_buff(1,MAX_CONTROL_DATA_SIZE,Control_Data.pData);
- Control_Data.pData+=MAX_CONTROL_DATA_SIZE;
- Control_Data.wCount-=MAX_CONTROL_DATA_SIZE;
- if(usb_flags.flags.set_addr)usb_flags.flags.not_end=1;
- else usb_flags.flags.usb_endp0_in=0;
- return;
- else
- write_endpoint_buff(1,Control_Data.wCount,Control_Data.pData);
- usb_flags.flags.setup_packet_in=0;
- return;
- /*********************發到接口的獲取描述符**************************************/
- void get_descriptor_interface(void)
- Prints(" 獲取描述符(從接口)..............................",1);
- case HID_DESCRIPTOR:
- Prints(" 獲取HID描述符................................",1);
- Control_Data.wCount=sizeof(HID_DESCRIPTOR_STRUCT);
- //Control_Data.pData=(uint8 *)(&hid_descriptor);
- break;
- case REPORT_DESCRIPTOR:
- Prints(" 獲取報告描述符................................",1);
- Control_Data.wCount=SWAP16(sizeof(KeyBoardReportDescriptor));
- Control_Data.pData=(uint8 *)(KeyBoardReportDescriptor);
- break;
- case PHYSICAL_DESCRIPTOR:
- Prints(" 獲取物理描述符................................",1);
- break;
- default:
- Prints("",1);
- break;
- //寫數據到D12輸入端點
- return;
- else
- return;
- /************************終端點0輸出中斷處理************************************/
- void endp0_out(void)
- Last_Status.Register=read_last_status(0);
- if(Last_Status.Status.setup_packet)
- Control_Data.wLength=0;
- Control_Data.wCount=0;
- if(read_endpoint_buff(0,sizeof(Control_Data.DeviceRequest),(uint8 *)(&(Control_Data.DeviceRequest)))!=sizeof(REQUESTCMD))
- set_endpoint_status(0,0);
- set_endpoint_status(1,0);
- return;
- Control_Data.DeviceRequest.wValue=SWAP16(Control_Data.DeviceRequest.wValue);
- Control_Data.DeviceRequest.wIndex=SWAP16(Control_Data.DeviceRequest.wIndex);
- Control_Data.DeviceRequest.wLength=SWAP16(Control_Data.DeviceRequest.wLength);
- ack_setup(0);
- ack_setup(1);
- Control_Data.wLength=Control_Data.DeviceRequest.wLength;
- usb_flags.flags.not_end=0;
- usb_flags.flags.usb_endp0_in=1;
- if(Control_Data.DeviceRequest.bmRequestType&0x80){usb_flags.flags.setup_packet_in=1;return;}
- else {usb_flags.flags.setup_packet_out=1;return;}
- else
- select_endpoint(0);
- clear_buffer();
- /***********************獲取報告*********************************************/
- void get_report(void)
- Prints(" 獲取報告................................",1);
- /**********************獲取空閑狀態*********************************************/
- void get_idle(void)
- Prints(" 獲取空閑................................",1);
- write_endpoint_buff(1,1,&idle);
- /*************************獲取協議**********************************************/
- void get_protocol(void)
- Prints(" 獲取協議................................",1);
- write_endpoint_buff(1,1,&protocol);
- /***********************設置報告***********************************************/
- void set_report(void)
- Prints(" 設置報告................................",1);
- /***********************設置空閑***********************************************/
- void set_idle(void)
- Prints(" 設置空閑................................",1);
- idle=Control_Data.DeviceRequest.wValue;
- /**********************設置協議**************************************************/
- void set_protocol(void)
- Prints(" 設置協議................................",1);
- protocol=Control_Data.DeviceRequest.wValue;
- /****************************終端點0輸入處理**************************************/
- void endp0_in(void)
- read_last_status(1);
- //如果是輸入請求包
- if(usb_flags.flags.setup_packet_in||usb_flags.flags.not_end)
- switch(Control_Data.DeviceRequest.bmRequestType&0x60)
- case 0x00: //標準請求
- Prints("USB標準請求................................",1);
- switch(Control_Data.DeviceRequest.bmRequestType&0x1F)
- case 0: //到設備
- switch (Control_Data.DeviceRequest.bRequest)
- case 0: get_status(0);break;
- case 6: get_descriptor();break;
- case 8: get_configuration();break;
- default:break;
- break;
- case 1: //到接口
- case 0: get_status(1);break;
- case 6: get_descriptor_interface();break;
- case 10: get_interface();break;
- default: break;
- break;
- case 2: //到端點
- if(Control_Data.DeviceRequest.bRequest==0)get_status(2);
- default: break;
- break;
- case 0x20: //類請求
- Prints("USB類請求................................",1);
- case 0: //到設備
- default:break;
- break;
- case 1: //到接口
- case GET_REPORT: get_report(); break; //獲取報告
- case GET_IDLE: get_idle(); break; //獲取空閑狀態
- case GET_PROTOCOL: get_protocol(); break; //獲取協議
- default: break;
- break;
- case 2: //到端點
- default: break;
- default: break;
- break;
- case 0x40: //用戶請求
- Prints("USB用戶請求................................",1);
- case 0: //到設備
- default: break;
- break;
- case 1: //到接口
- default: break;
- break;
- case 2: //到端點
- default: break;
- default: break;
- return;
- //如果是輸出請求包
- if(usb_flags.flags.setup_packet_out)
- case 0x00: //標準請求
- case 0: //到設備
- case CLEAR_FEATURE: clear_feature(0);break;
- case SET_FEATURE: set_feature(0);break;
- case SET_ADDRESS: set_usb_address();break; //set_address
- case SET_DESCRIPTOR: set_descriptor();break; //set_descriptor
- case SET_CONFIGURATION: set_configuration(); break; //set_configurat
- default: break;
- break;
- case 1: //到接口
- case CLEAR_FEATURE: clear_feature(1);break;
- case SET_FEATURE: set_feature(1); break;
- case SET_INTERFACE: set_interface();break;
- default: break;
- break;
- case 2: //到端點
- case CLEAR_FEATURE: clear_feature(2);break;
- case SET_FEATURE: set_feature(2);break;
- default: break;
- break;
- default: break;
- break;
- case 0x20: //類請求
- case 0: //接收者為設備
- default: break;
- break;
- case 1: //接收者為接口
- case SET_REPORT: set_report(); break; //設置報告
- case SET_IDLE: set_idle(); break; //設置空閑
- case SET_PROTOCOL: set_protocol(); break; //設置協議
- default: break;
- break;
- case 2: //接收者為端點
- default: break;
- break;
- case 3: //其它接收者
- default: break;
- }break;
- default: break;
- break;
- case 0x40: //用戶請求
- case 0: //接收者為設備
- default: break;
- break;
- case 1: //接收者為接口
- default: break;
- break;
- case 2: //接收者為端點
- default: break;
- break;
- case 3: //其它接收者
- default: break;
- break;
- default: break;
- /**********************端點1輸出***********************************************/
- /*void endp1_out(void)
- Prints("端點1輸出................................",1);
- /*************************端點1輸入*****************************************/
- /*void endp1_in(void)
- Prints("端點1輸入................................",1);
- /***************************端點2輸出****************************************/
- void endp2_out(void)
- uint8 i,j;
- j=read_endpoint_buff(4,64,buffer);
- P2=~buffer[0];
- Prints("端點2輸出................................",1);
- Prints(" 端點2的數據是 ",0);
- for(i=0;i<j;i++)
- PrintHex(buffer[i]);
- if(i==16)Prints("",1);
- Prints("",1);
- //用來返回數據的緩沖
- uint8 idata InBuffer[64];
- /***************************統計x中有多少個bit為1*******************************/
- uint8 Count1Bits(uint16 x)
- uint8 i;
- i=0;
- while(x)
- if(x&0x8000)i++;
- x<<=1;
- return i;
- /****************************主端點輸入處理************************************/
- void endp2_in(void)
- uint8 i;
- // Prints("端點2輸入................................",1);
- KeyMapCanChange=0; //禁止修改按鍵值
- if(KeyMapOk) //如果有按鍵按下
- //4*4的鍵盤,最多能夠識別3個鍵同時按下,
- //如果開關上接二極管可以同時識別更多的鍵
- if(Count1Bits(KeyMapOk)>3)
- for(i=2;i<8;i++)InBuffer[i]=0x01; //按鍵過多
- else
- if(KeyMapOk&(1<<3)) //左Ctrl鍵
- InBuffer[0]|=1;
- else
- InBuffer[0]&=~1;
- if(KeyMapOk&(1<<7)) //左shift鍵
- InBuffer[0]|=1<<1;
- else
- InBuffer[0]&=~(1<<1);
- if(KeyMapOk&(1<<2)) //左ALT鍵
- InBuffer[0]|=1<<2;
- else
- InBuffer[0]&=~(1<<2);
- i=2;
- if(KeyMapOk&(1))
- InBuffer[i++]=0x28; //回車鍵
- if(KeyMapOk&(1<<1))
- InBuffer[i++]=0x62; //0鍵
- if(KeyMapOk&(1<<4))
- InBuffer[i++]=0x5B; //3鍵
- if(KeyMapOk&(1<<5))
- InBuffer[i++]=0x5A; //2鍵
- if(KeyMapOk&(1<<6))
- InBuffer[i++]=0x59; //1鍵
- if(KeyMapOk&(1<<8))
- InBuffer[i++]=0x5E; //6鍵
- if(KeyMapOk&(1<<9))
- InBuffer[i++]=0x5D; //5鍵
- if(KeyMapOk&(1<<10))
- InBuffer[i++]=0x5C; //4鍵
- if(KeyMapOk&(1<<11))
- InBuffer[i++]=0x39; //Caps Lock鍵
- if(KeyMapOk&(1<<12))
- InBuffer[i++]=0x61; //9鍵
- if(KeyMapOk&(1<<13))
- InBuffer[i++]=0x60; //8鍵
- if(KeyMapOk&(1<<14))
- InBuffer[i++]=0x5F; //2鍵
- if(KeyMapOk&(1<<15))
- InBuffer[i++]=0x53; //Num Lock鍵
- for(;i<8;i++)
- InBuffer[i]=0; //多余的清0
- else //如果無按鍵按下,則返回0
- for(i=0;i<8;i++)
- InBuffer[i]=0;
- KeyMapCanChange=1; //允許修改按鍵值
- //返回8個字節數據
- write_endpoint_buff(5,8,InBuffer);
- /***************************主函數**********************************************/
- void main(void)
- InitUART(); //串口初始化
- Printc(0x0c); //清屏
- Printc(0x0c);
- Prints("系統啟動................................",1);
- delay(1000); //延遲
- disconnect_usb(); //斷開USB連接
- init_usb(); //初始化USB芯片
- connect_usb(); //連接USB
- InitTimer0(); //定時器0初始化,用來做鍵盤掃描,定時時間大約為5ms
2017-4-26 21:25 上傳
下載:
51單片機模擬一個USB鍵盤的代碼,.rar
(322.46 KB, 下載次數: 364)
2017-4-26 11:26 上傳
下載積分: 黑幣 -5
