使用ov9655攝像頭,拍攝圖象。
全部源碼下載:
STM32F4XX OV9655攝像頭程序.zip
(540.44 KB, 下載次數: 20)
2017-4-19 10:58 上傳
ov9655
部分源碼預覽:
- * @file main.c
- * @author MCD Application Team
- * @version V1.0.0
- * @brief Main program body
- * @attention
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f4xx.h"
- #include "usart.h"
- #include "LCD/LCD.h"
- #include "camera/dcmi_OV9655.h"
- /** @addtogroup STM32F2xx_StdPeriph_Examples
- /** @addtogroup IOToggle
- void LCD_CS_ResetBits(void);
- void Delay(__IO uint32_t nTime);
- void TimingDelay_Decrement(void);
- static __IO uint32_t TimingDelay;
- uint32_t fps=0;
- uint32_t disfps=0;
- uint32_t fpsbuff[5];
- * @param None
- * @retval None
- int main(void)
- OV9655_IDTypeDef OV9655ID;
- /*!< At this stage the microcontroller clock setting is already configured,
- this is done through SystemInit() function which is called from startup
- file (startup_stm32f2xx.s) before to branch to application main.
- To reconfigure the default setting of SystemInit() function, refer to
- system_stm32f2xx.c file
- USART_Configuration();
- //USART_NVIC_Config();
- LCD_Initializtion();
- LCD_Clear(Red);
- GUI_Text(50,70,"Camera Init..",White,Red);
- printf("\r\n\r\nWelcome to WaveShare STM32F2 series MCU Board Open207I\r\n");
- printf("OV9655 Init..\r\n");
- if(DCMI_OV9655Config()==0){
- printf("Camera Have Init..\r\n");
- GUI_Text(50,90,"Camera Have Init..",White,Red);
- else {
- printf("OV9655 Init fails!!\r\n");
- GUI_Text(50,90,"OV9655 Init fails!!",White,Red);
- DCMI_OV9655_ReadID(&OV9655ID);
- printf("OV9655 ID:0x%x 0x%x 0x%x 0x%x\r\n",OV9655ID.Manufacturer_ID1, OV9655ID.Manufacturer_ID2, OV9655ID.PID, OV9655ID.Version);
- LCD_WriteReg(0x0011,0x6068);
- LCD_SetCursor(0,0);
- Prepare_Write_RAM();
- /* Start Image capture and Display on the LCD *****************************/
- /* Enable DMA transfer */
- DMA_Cmd(DMA2_Stream1, ENABLE);
- /* Enable DCMI interface */
- DCMI_Cmd(ENABLE);
- /* Start Image capture */
- DCMI_CaptureCmd(ENABLE);
- //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x10); //color test on
- //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x80); //color test on
- //uint32_t i=0x1fffff;
- // while(i--);
- //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x00); //color test off
- //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x00); //color test off
- while (1)
- TimingDelay = nTime;
- while(TimingDelay != 0)
- if (TimingDelay != 0x00)
- TimingDelay--;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
- //LCD_CS PD7
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_ResetBits(GPIOD , GPIO_Pin_7); //CS=0;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
