查看: 2972|回復: 0
PCF8691-單片機C語言程序
ID:188417 發表于 2017-4-11 12:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
電路圖詳見:http://www.raoushi.com/bbs/dpj-81234-1.html
#include <reg51.h>
sbit CLK=P1^1;
sbit SDA=P1^2;
sbit A=P2^0;
sbit M=P2^1;
sbit C=P2^2;
unsigned charnum[10]={0X3f,0X06,0X5b,0X4f,0X66,0X6d,0X7d,0X07,0X7f,0X6f};
//-------------IIC--------------------
void IIC_Delay()
void start()
    SDA=1;
    IIC_Delay();
    CLK=1;
    IIC_Delay();
    SDA=0;
    IIC_Delay();
void stop()
    SDA=0;
    IIC_Delay();
    CLK=1;
    IIC_Delay();
    SDA=1;
    IIC_Delay();
void answer()
   CLK=1;
   IIC_Delay();
   while(SDA==1);
   CLK=0;
   IIC_Delay();
void write_byte(unsigned char dat)
   unsigned char i;
   for(i=0;i<8;i++)
      dat=dat<<1;
      CLK=0;
      IIC_Delay();
       SDA=CY;
      IIC_Delay();
      CLK=1;
      IIC_Delay();
   CLK=0;
   IIC_Delay();
   SDA=1;
   IIC_Delay();
unsigned char read_byte()
   unsigned char i,dat;
   CLK=0;
   IIC_Delay();
   SDA=1;
   IIC_Delay();
   for(i=0;i<8;i++)
       CLK=1;
       IIC_Delay();
       dat=dat<<1;
       if(SDA)
        dat=dat|0x01;
       CLK=0;
       IIC_Delay();
   return dat;
//-------------IIC A/DD/A-----------------------
void DA_trans(unsigned char dat)
    start();
    write_byte(0x90);
    answer();
    write_byte(0x40);
    answer();
    write_byte(dat);
    answer();
    stop();
unsigned char AD_trans()
    unsigned char dat;
    start();
    write_byte(0x90);
    answer();
    write_byte(0x02);
    answer();
    start();
    write_byte(0x91);
    answer();
    dat=read_byte();
    stop();
    return dat;
void delay(unsigned char Xms)
   unsigned int i,j;
   for(i=0;i<Xms;i++)
      for(j=0;j<114;j++);
void weixuan(char x,char y,char z)
A=x;
M=y;
C=z;
void Display(unsigned char dat)
  weixuan(0,0,0);
  P0=num[dat/100];
  delay(5);
  weixuan(1,0,0);
  P0=num[(dat%100)/10];
  delay(5);
  weixuan(0,1,0);
  P0=num[dat%10];
  delay(5);
main()
    unsigned char dat;
       dat=AD_trans();
       Display(dat);
PCF8591-單片機C語言程序--ADDA裝換.docx
13.31 KB, 下載次數: 7, 下載積分: 黑幣 -5
