- /* 名稱:數(shù)碼管顯示撥碼開關(guān)編碼
- 說明:系統(tǒng)顯示撥碼開關(guān)所設置的編碼 000~255
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- //各數(shù)字的數(shù)碼管段碼(共陰)
- uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- //顯示緩沖
- uchar DSY_Buffer[3]={0,0,0};
- //延時
- void DelayMS(uint ms)
- uchar t;
- while(ms--)for(t=0;t<120;t++);
- //主程序
- void main()
- uchar i,m,Num;
- P0=0xff;
- P2=0xff;
- while(1)
- m=0xfe;
- Num=P1;//讀取撥碼開關(guān)的值
- DSY_Buffer[0]=Num/100;
- DSY_Buffer[1]=Num/10%10;
- DSY_Buffer[2]=Num%10;
- for(i=0;i<3;i++) //刷新顯示在數(shù)碼管上
- m=_crol_(m,1);
- P2=m;
- P0=DSY_CODE[DSY_Buffer[i]];
- DelayMS(10);
復制代碼 |
