查看: 2646|回復(fù): 1
單片機控制LCD12864
ID:176586 發(fā)表于 2017-3-26 17:32 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
經(jīng)典LCD12864仿真
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. unsigned char code xi[]= // xi
  6. {
  7. 0x00,0x00,0x22,0x32,0x2A,0xA6,0xA2,0x62,0x21,0x11,0x09,0x81,0x01,0x00,0x00,0x00,
  8. 0x00,0x42,0x22,0x13,0x0B,0x42,0x82,0x7E,0x02,0x02,0x0A,0x12,0x23,0x46,0x00,0x00,
  9. };
  10. unsigned char code tong[]= // tong
  11. {
  12. 0x20,0x30,0xAC,0x63,0x30,0x00,0x88,0xC8,0xA8,0x99,0x8E,0x88,0xA8,0xC8,0x88,0x00,
  13. 0x22,0x67,0x22,0x12,0x12,0x80,0x40,0x30,0x0F,0x00,0x00,0x3F,0x40,0x40,0x71,0x00,
  14. };
  15. unsigned char code chu[]= // chu
  16. {
  17. 0x08,0x08,0x89,0xEA,0x18,0x88,0x00,0x04,0x04,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
  18. 0x02,0x01,0x00,0xFF,0x01,0x86,0x40,0x20,0x18,0x07,0x40,0x80,0x40,0x3F,0x00,0x00,
  19. };
  20. unsigned char code shi[]= // shi
  21. {
  22. 0x10,0x10,0xF0,0x1F,0x10,0xF0,0x00,0x40,0xE0,0x58,0x47,0x40,0x50,0x60,0xC0,0x00,
  23. 0x40,0x22,0x15,0x08,0x16,0x21,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,
  24. };
  25. unsigned char code hua[]= // hua
  26. {
  27. 0x00,0x80,0x60,0xF8,0x07,0x00,0x00,0x00,0xFF,0x40,0x20,0x10,0x08,0x04,0x00,0x00,
  28. 0x01,0x00,0x00,0xFF,0x00,0x04,0x02,0x01,0x3F,0x40,0x40,0x40,0x40,0x40,0x78,0x00,
  29. };
  30. unsigned char code qi[]= // qi
  31. {
  32. 0x00,0x00,0x00,0xFC,0x44,0x44,0x44,0x45,0x46,0x44,0x44,0x44,0x44,0x7C,0x00,0x00,
  33. 0x40,0x20,0x18,0x07,0x00,0xFC,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFC,0x00,0x00,
  34. };
  35. unsigned char code dong[]= // dong
  36. {
  37. 0x40,0x44,0xC4,0x44,0x44,0x44,0x40,0x10,0x10,0xFF,0x10,0x10,0x10,0xF0,0x00,0x00,
  38. 0x10,0x3C,0x13,0x10,0x14,0xB8,0x40,0x30,0x0E,0x01,0x40,0x80,0x40,0x3F,0x00,0x00,
  39. };
  40. unsigned char code kong[]= // dong
  41. {
  42. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44. };
  45. unsigned char code shu[]= // dong
  46. {
  47. 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
  48. /*--  文字:  1  --*/
  49. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  50. 0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,
  51. /*--  文字:  2  --*/
  52. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  53. 0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
  54. /*--  文字:  3  --*/
  55. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  56. 0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00,
  57. /*--  文字:  4  --*/
  58. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  59. 0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24,
  60. /*--  文字:  5  --*/
  61. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  62. 0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00,
  63. /*--  文字:  6  --*/
  64. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  65. 0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00,
  66. /*--  文字:  7  --*/
  67. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  68. 0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00,
  69. /*--  文字:  8  --*/
  70. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  71. 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
  72. /*--  文字:  9  --*/
  73. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  74. 0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00,
  75. };
  76. sbit CS1=P2^0;//片選1,低電平有效,CS1=0開左屏幕,CS1=1關(guān)左屏幕
  77. sbit CS2=P2^1;//片選2,低電平有效,CS2=0開右屏幕,CS2=1關(guān)右屏幕
  78. sbit RS=P2^2;//數(shù)據(jù),指令選擇信號,RS=1為數(shù)據(jù)操作,RS=0為寫指令或讀狀態(tài)(一般為讀忙標(biāo)志)
  79. sbit RW=P2^3;//讀寫選擇信號,RW=1為讀選通,RW=0為寫選通
  80. sbit EN=P2^4;//讀寫使能信號
  81. sbit k1=P1^0;
  82. void wcmd(uchar cmd)//寫命令
  83. {
  84. RS=0;
  85. RW=0;
  86. P0=cmd;
  87. EN=1;_nop_();_nop_();//在EN下降沿寫入數(shù)據(jù)和指令
  88. EN=0;
  89. }
  90. void wdata(uchar dat) //寫命令和寫數(shù)據(jù)只在RS=0或RS=1上不同,其余都相同
  91. {
  92. //busy();
  93. RS=1;
  94. RW=0;
  95. P0=dat;
  96. EN=1;_nop_();_nop_();//在EN下降沿寫入數(shù)據(jù)和指令
  97. EN=0;
  98. }
  99. void set_page(uchar page)//設(shè)置頁,12864LCD共有8頁,每頁有8行點陣點。
  100. {page=0xb8|page;  //首頁地址為0XB8
  101. wcmd(page);                  //page取值范圍為0~7,表示第1到8頁
  102. }
  103. void set_line(uchar line)//設(shè)置顯示的起始行,共有0--63行,一般從0行開始顯示
  104. {line=0xc0|line;  //起始行地址0XC0
  105. wcmd(line);        //line取值范圍為0~63,表示第1到64行
  106. }
  107. void set_column(uchar column)//設(shè)置顯示的列
  108. {//column=column&0x3f; //列的最大值為0X3F,即64
  109. column=0x40|column;         //列的首地址為0X40,
  110. wcmd(column);                 //column的取值范圍為0~63,共64列
  111. }
  112. void set_onoff(uchar onoff)//設(shè)置顯示開關(guān),onoff取值為0或1
  113. {onoff|=0x3e;//0X3E是關(guān)顯示,0X3F是開顯示
  114. wcmd(onoff);//所以若onoff為0,則表示關(guān)顯示,onoff為1,則表示開顯示
  115. }
  116. void select_screen(uchar screen)//選屏,screen取值范圍為0,1,2
  117. {switch(screen)
  118. {case 0:CS1=0;CS2=0;break; //全屏
  119. case 1:CS1=0;CS2=1;break;  //左半屏
  120. case 2:CS1=1;CS2=0;break;  //右半屏
  121. default:break;
  122. }
  123. }
  124. void clear_screen(uchar screen)//清屏
  125. {uchar i,j;
  126. select_screen(screen);//先選屏
  127. for(i=0;i<8;i++)//控制頁數(shù)0--7,共8頁
  128. {set_page(i);//設(shè)置頁
  129. set_column(0); //設(shè)置列,每頁都從第1列開始,共64列
  130. for(j=0;j<64;j++)//控制列數(shù)0--63,共64列
  131. wdata(0x00);//寫入0,列地址指針會自動加1
  132. }
  133. }
  134. void init()        //LCD初始化
  135. {
  136. select_screen(0);//選屏,全屏
  137. set_onoff(0);        //關(guān)顯示
  138. select_screen(0); //選屏,全屏
  139. set_onoff(1);          //開顯示
  140. select_screen(0); //選屏,全屏
  141. clear_screen(0);  //清屏
  142. set_line(0);          //起始行:0
  143. }
  144. void show(uchar screen,uchar page,uchar column,uchar *p)//顯示一個漢字,一個漢字有32字節(jié)數(shù)據(jù)
  145. {uchar i;        //screen表示選擇屏幕,page表示頁,column表示列,*p表示漢字的數(shù)組
  146. select_screen(screen); //選屏
  147. set_page(page);           //設(shè)置頁,寫上半頁
  148. set_column(column);//設(shè)置列
  149. for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
  150. wdata(p[i]);   //漢字的上半部分
  151. set_page(page+1); //寫下半頁
  152. set_column(column);        //控制列
  153. for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
  154. wdata(p[i+16]);         //漢字的下半部分
  155. }
  156. void show8(uchar screen,uchar page,uchar column,int qq)//顯示一個漢字,一個漢字有32字節(jié)數(shù)據(jù)
  157. {uchar i;        //screen表示選擇屏幕,page表示頁,column表示列,*p表示漢字的數(shù)組
  158. select_screen(screen); //選屏
  159. set_page(page);           //設(shè)置頁,寫上半頁
  160. set_column(column);//設(shè)置列
  161. for(i=0;i<8;i++) //控制16列的數(shù)據(jù)輸出
  162. wdata(shu[i+qq*16]);   //漢字的上半部分
  163. set_page(page+1); //寫下半頁
  164. set_column(column);        //控制列
  165. for(i=0;i<8;i++) //控制16列的數(shù)據(jù)輸出
  166. wdata(shu[i+8+qq*16]);         //漢字的下半部分
  167. }
  168. void main()
  169. {init();  //LCD初始化
  170. clear_screen(0); //清屏
  171. show(1,0,0,xi);//顯示“初”
  172. show(1,0,16,tong);//顯示“始”
  173. show(1,0,32,chu);//顯示“化”
  174. show(1,0,48,shi);//顯示“化”
  175. show(2,0,0,hua);//顯示“化”
  176. while(1)
  177.   {
  178.    show8(2,0,32,3);//顯示“化”
  179.    if(k1==0)
  180.      {
  181.       show(1,0,48,qi);//顯示“啟”
  182.       show(2,0,0,dong);//顯示“動
  183.           show(1,0,32,kong);//顯示“ ”
  184.      }
  185.   }
  186. }
仿真工程文件及源碼下載:
128641.rar (58.04 KB, 下載次數(shù): 9)
相關(guān)帖子
ID:219500 發(fā)表于 2017-7-15 20:44 | 只看該作者
此帖僅作者可見
