給51黑電子論壇的朋友們分享一個基于51單片機的智能窗簾控制系統(tǒng)(帶51單片機源碼+ad軟件畫的原理圖和pcb工程文件),這是我的畢業(yè)設(shè)計,大家多多指教.
智能窗簾的原理圖(ad畫的 需要用ad打開):
智能窗簾的pcb工程文件:
單片機窗簾主程序:
- #include <reg51.h>//51頭文件
- #include<INTRINS.h>
- #define uchar unsigned char
- #define uint unsigned int //變量宏定義
- #define ulong unsigned long //變量宏定義
- uchar count,s1num,shi2=0,fen2=0,shi3=10,fen3=10;//全局變量
- uchar miao,fen,shi;//時間變量
- uchar c,v,l,i;
- ulong AD_ad1,AD_ad2;
- float JiZhun_AD=2.5;
- float AD_Data=0.0;
- ulong AD_ad=0;
- uchar dianji;
- sbit rs = P0^5;//數(shù)據(jù),命令選擇端(H/L)
- sbit rw = P0^6;//讀,寫選擇端(H/L)
- sbit e = P0^7;//使能信號
- sbit CLOCK = P1^1; //lcd
- sbit D_IN = P1^2; //lcd
- sbit D_OUT = P1^3; //lcd
- sbit _CS = P1^4; //lcd
- sbit menu = P1^0; //按鍵//P1^3
- sbit add = P1^7; //按鍵//P1^4
- sbit cut = P1^5; //按鍵
- sbit yes = P1^6; //按鍵
- sbit ma = P3^0; //步進電機
- sbit mb = P3^1; //步進電機
- sbit mc = P3^2; //步進電機
- sbit md = P3^3; //步進電機
- sbit led1 = P3^4; //LED1
- sbit led2 = P3^5; //LED2
- sbit spek = P3^6; //SPEK
- uchar code table[]="shut-00:00|ray:0";
- uchar code table1[]="open-00:00|00:00";//數(shù)據(jù)字符表
- uchar data display[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- //顯示單元后臺數(shù)據(jù),1分2時現(xiàn)在時間,5分6時關(guān)閉時間,3分4時打開時間,7亮度級數(shù) //
- //****************延時*****************
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--) ;
- //****************寫液晶指令*****************
- void write_com(uchar com)
- rs=0;
- e=0;
- P2=com;
- delay(5);
- e=1;
- delay(5);
- e=0;
- //****************液晶數(shù)據(jù)*****************
- void write_date(uchar date)
- rs=1;
- e=0;
- P2=date;
- delay(5);
- e=1;
- delay(5);
- e=0;
- //****************初始化液晶定時器************
- void init() //
- uchar num;
- rs=0;
- rw=0;
- e=0;//鎖存關(guān)閉
- write_com(0x38);
- delay(5);
- write_com(0x0c);//
- delay(5);
- write_com(0x06);
- delay(5);
- write_com(0x01);
- write_com(0x80);//第一行開始寫
- for(num=0;num<16;num++)
- write_date(table[num]);
- delay(20);
- write_com(0x80+0x40);//第二行前一部分,也就是時間開始寫
- write_date(table1[num]);
- delay(20);
- TMOD=0x01;//定時器0的方式1
- TH0=(65536-50000)/256;//求模
- TL0=(65536-50000)%256;//取余
- EA=1;//開總中斷
- ET0=1;//開定時器中斷
- TR0=1;//啟動定時器
- //****************地址數(shù)據(jù)變量**************
- void write_sfm(uchar add, uchar date)
- uchar shi,ge;
- shi=date/10;
- ge=date%10;
- write_com(0x80+0x40+add);
- write_date(0x30+shi);
- write_date(0x30+ge);
- void write_sfn(uchar add, uchar date)
- uchar si,g;
- si=date/10;
- g=date%10;
- write_com(0x80+add);
- write_date(0x30+si);
- write_date(0x30+g);
- //****************按鍵函數(shù)*****************
- void key()
- if(c==8)c=0;
- if(menu==0)
- delay(50);
- if(menu==0)
- c++;spek=0;delay(50);
- while(menu==0);spek=1;
- if(add==0)
- spek=0;delay(50);
- while(add==0);
- spek=1;
- display[c]++;
- write_sfm(14,display[1]);//分針位置
- write_sfm(11,display[2]);//時針位置
- if(cut==0)
- spek=0;delay(50);
- while(cut==0);
- spek=1;
- display[c]--;
- if(yes==0)
- spek=0;delay(50);
- while(yes==0);
- spek=1;
- c=0;
- write_sfm(14,display[1]);//現(xiàn)在分針位置
- write_sfm(11,display[2]);//現(xiàn)在時針位置
- write_sfm(8,display[3]);//打開分針位置
- write_sfm(5,display[4]);//打開分針位置
- write_sfn(8,display[5]);//關(guān)閉分針位置
- write_sfn(5,display[6]);//關(guān)閉分針位置
- write_com(0x80+15); //亮度級數(shù)
- write_date(0x30+display[7]);//亮度級數(shù)位置
- //****************步進電機函數(shù)*****************
- void motorzen()
- while(v)
- led1=0;
- ma=1,mb=0;mc=0;md=0;delay(3);
- ma=0,mb=1;mc=0;md=0;delay(3);
- ma=0,mb=0;mc=1;md=0;delay(3);
- ma=0,mb=0;mc=0;md=1;delay(3);
- led1=1;
- void motorfan()
- while(v&l)
- led2=0;
- led2=1;
- //****************A/D*****************
- uint read1543(uchar port)
- uint ad;
- uint i;
- uchar al=0,ah=0;
- CLOCK=0;
- _CS=0;
- port<<=4;
- for (i=0;i<4;i++) //將四位通道地址送1543
- D_IN=(bit)(port&0x80);CLOCK=1;CLOCK=0;
- port<<=1;
- for (i=0;i<6;i++) //填6個CLOCK信號
- CLOCK=1;CLOCK=0;
- _CS=1;
- _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
- _CS=0; //等待AD轉(zhuǎn)換結(jié)束
- for (i=0;i<2;i++) //D9,D8
- D_OUT=1;CLOCK=1;ah<<=1;
- if (D_OUT) ah +=0x01;
- CLOCK=0;
- for (i=0;i<8;i++) //取出D7--D0
- D_OUT=1;CLOCK=1;al <<= 1;
- if (D_OUT)
- al +=0x01;
- CLOCK=0;
- _CS=1;
- ad = (uint)ah;
- ad <<= 8;
- ad +=(uint)al; //
- return(ad);
- //****************亮度測試*****************
- void liangdu()
- i++;
- if(i==30)
- i=0;
- AD_ad1 = read1543(0); // (通道0電壓正端)
- AD_Data = ((float)AD_ad1)*JiZhun_AD*2/1024+0.005;//0.15經(jīng)過實測需要加0.15減少誤差
- AD_ad =(AD_Data*100);
- if(display[7]>AD_ad%100/10)
- if(dianji==0)
- spek=0;delay(50);spek=1;
- motorzen();
- dianji=1;
- else
- if(dianji==1)
- motorfan();
- dianji=0;
- //****************主函數(shù)*****************
- void main()
- display[4]=8;
- display[6]=20;
- display[7]=50;
- spek=1;
- init();
- while(1)
- key();liangdu();
- if(display[2]==display[4])//時間判斷關(guān)閉窗簾
- if(display[1]==display[3])//與打開時間一致動作
- if(miao<5)
- v=10;
- motorzen();
- if(display[2]==display[6])//時間判斷關(guān)閉窗簾
- if(display[1]==display[5])//與打開時間一致動作
- if(miao<5)
- v=10;
- motorfan();
- void timer0() interrupt 1 //定時器0中斷服程序
- TL0=(65536-50000)%256;//求佘
- count++;//變量
- if(count==20)//此處為時間基準調(diào)節(jié),20為走一秒
- …………余下代碼請下載附件…………
資料下載:
窗簾控制.rar
(1.21 MB, 下載次數(shù): 502)
2017-3-19 22:51 上傳
51單片機
