查看: 11789|回復: 4
LCD1602顯示時間年月日優化及顯示星期問題
ID:160658 發表于 2017-1-17 21:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
自己總覺得程序有待優化,且星期顯示有問題,對7求余為0時,星期不變化,請高手給予指點,謝謝!
#include<reg51.h>
#include<intrins.h>
sbit EP = P3^2; //使能端
sbit RW = P3^1; //數據/命令選擇端
sbit RS = P3^0; //讀寫選擇端
sbit KEY_1 = P3^4;          //設置模式選擇
sbit KEY_2 = P3^5;          //
static uint code table1[] = {0, 31, 59, 90, 120, 151,181, 212, 242, 273, 303, 334};
static uchar code *Week[7] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
uchar sec = 0, hour = 12, minu = 0;
uchar count = 0, week = 0; month = 1, day = 1;
void T0_Init()
        ET0 = 1;
        TMOD = 0x01;
        TH0 = (65536 - 46071)/256;
        TL0 = (65536 - 46071)%256;
        TR0 = 1;
void delay(uint ms)
        uint i, j;
        for(i=ms; i>0; i--)
                for(j=110; j>0; j--);
void Lcd_Ready() //測忙函數
        uchar sta;
        RS = 0;
        RW = 1;
        do {
                EP = 1;
                sta = P1;
                EP = 0;
        }while(sta & 0x80);         //檢測P1最高位是否為1,若為1,則1602忙,為0則可以讀寫操作
void Write_Cmd(uchar cmd) //寫入命令
        Lcd_Ready();
        RS = 0;
        RW = 0;
        P1 = cmd;
        delay(5);
        EP = 1;
        delay(5);
        EP = 0;
void Write_Dat(uchar dat) //寫入數據
        Lcd_Ready();  //LCD1602 不忙則跳出
        RS = 1;
        RW = 0;
        P1 = dat;
        delay(5);
        EP = 1;
        delay(5);
        EP = 0;
void Write_Week(uchar day, uchar month)                        //星期與日期同步
        week = (table1[(month - 1)] + day - 1);
        week = week % 7;
        Write_Cmd(0x80 + 12);
        while(*Week[week] != '\0')
                Write_Dat(*Week[week]++);
void Write_Num(uchar x, uchar y, uchar num) //將時分秒和日期寫入1602
        uchar unit, decad;
        unit = num % 10;
        decad = num /10;
        if(y == 1)
                Write_Cmd(0x80 + 0x40 + x);
                Write_Dat(0x30 + decad);         //即加48,將數字轉換為ASC||字符數字
                Write_Dat(0x30 + unit);
                Write_Cmd(0x80 + x);
void Lcd_Init()          //LCD初始化設定
        Write_Cmd(0x38); // 16*2顯示,5*7點陣,8位數據
        Write_Cmd(0x0c); // 顯示開,關光標
        Write_Cmd(0x06); // 讀寫地址自動加1,光標加1
        Write_Cmd(0x01); //清除屏幕
void Display()  //
        Write_Week(day, month);
        Write_Num(9, 0, day);
        Write_Num(6, 0, month);
        Write_Num(4, 1, hour);
        Write_Num(7, 1, minu);
        Write_Num(10, 1, sec);
        Write_Cmd(0x80 + 0x40 + 6);
        Write_Dat(':');
        Write_Cmd(0x80 + 0x40 + 9);
        Write_Dat(':');
void TimerCount()
        if(count == 20)
                count = 0;
                sec++;
                if(sec == 60)
                        sec = 0;
                        minu++;
                         if(minu == 60)
                                minu = 0;
                                hour++;
                                 if(hour == 24)
                                        hour = 0;
                                        day++;
                                        week++;
                                        if(week == 7)
                                                week = 0;
                                        switch(month)
                                                case 1:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 2:
                                                        if(day == 29)
        day = 0;
        month++;
        break;
                                                case 3:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 4:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 5:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 6:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 7:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 8:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 9:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 10:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 11:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 12:
                                                        if(day == 32)
        day = 0;
        month = 1;
        break;
                Display();
void KeyScan()
        static uchar key1cnt = 0;                //KEY_1按下的次數
        if(KEY_1 == 0)
                delay(10);
                if(KEY_1 == 0)
                        key1cnt++;
                        while(!KEY_1);
                        switch(key1cnt)
                                case 1:
                                        TR0 = 0;
                                        Write_Cmd(0x80 + 0x40 + 5);
                                        Write_Cmd(0x0F);            //顯示光標且光標閃爍
                                        break;
                                case 2:
                                        Write_Cmd(0x80 + 0x40 + 8);
                                        break;
                                case 3:
                                        Write_Cmd(0x80 + 0x40 + 11);
                                        break;
                                case 4:
                                        Write_Cmd(0x80 + 7);
                                        break;
                                case 5:
                                        Write_Cmd(0x80 + 10);
                                        break;
                                case 6:
                                        TR0 = 1;
                                        Write_Cmd(0x0C);           //不顯示光標
                                        key1cnt = 0;
                                        break;
        if(key1cnt != 0)
                if(KEY_2 == 0)
                        delay(10);
                        if(KEY_2 == 0)
                                while(!KEY_2);
                                switch(key1cnt)
                                        case 1:
                                                hour++;
                                                if(hour == 24)
                                                        hour = 0;
                                                break;
                                        case 2:
                                                minu++;
                                                if(minu == 60)
                                                        minu = 0;
                                                break;
                                        case 3:
                                                sec++;
                                                if(sec == 60)
                                                        sec = 0;
                                                break;
                                        case 4:
                                                month++;
                                                if(month == 13)
                                                        month = 1;
                                                break;
                                        case 5:
                                                day++;
                                                if(day == 32)
                                                        day = 1;
                                                break;
        uchar i = 0;
        uchar code table[] = {"2017-01-01 Sun"};
        EA = 1;
        Lcd_Init();                        //1602初始化
        T0_Init();          //定時器0初始化
        Write_Cmd(0x80 + 1);
        while(table[i] != '\0')
                Write_Dat(table[i]);
                i++;
                KeyScan();
void Timer0() interrupt 1
        count++;
        TimerCount();
ID:89072 發表于 2018-8-31 15:51 | 只看該作者
/*作者:lern01 自己總覺得程序有待優化,且星期顯示有問題,對7求余為0時,星期不變化,請高手給予指點,謝謝!                                         **/
#include<reg51.h>
#include<intrins.h>
sbit rs=P3^5;
sbit lcden=P3^4;
sbit rw=P3^6;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit s4=P3^7;        //矩陣鍵盤         公共
sbit EP = P3^4; //使能端
sbit RW = P3^6; //數據/命令選擇端
sbit RS = P3^5; //讀寫選擇端
sbit KEY_1 = P3^0;          //設置模式選擇
sbit KEY_2 = P3^1;          //
void T0_Init()
        ET0 = 1;
        TMOD = 0x01;
        TR0 = 1;
void delay(uint ms)
        uint i, j;
        for(i=ms; i>0; i--)
       // Lcd_Ready();
        RS = 0;
        RW = 0;
                EP = 0;
        P0 = cmd;
        delay(5);
        EP = 1;
        delay(5);
        EP = 0;
       // Lcd_Ready();  //LCD1602 不忙則跳出
        RS = 1;
        RW = 0;
                EP = 0;
        P0 = dat;
        delay(5);
        EP = 1;
        delay(5);
        EP = 0;
        week = week % 7;
        uchar unit, decad;
        unit = num % 10;
        decad = num /10;
        if(y == 1)
                Write_Cmd(0x80);
void Display()  //
        Write_Dat(':');
        Write_Dat(':');
void TimerCount()
        if(count == 20)
                count = 0;
                sec++;
                if(sec == 60)
                        sec = 0;
                        minu++;
                         if(minu == 60)
                                minu = 0;
                                hour++;
                                 if(hour == 24)
                                        hour = 0;
                                        day++;
                                        week++;
                                        if(week == 7)
                                                week = 0;
                                        switch(month)
                                                case 1:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 2:
                                                        if(day == 29)
        day = 0;
        month++;
        break;
                                                case 3:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 4:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 5:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 6:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 7:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 8:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 9:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 10:
                                                        if(day == 32)
        day = 0;
        month++;
        break;
                                                case 11:
                                                        if(day == 31)
        day = 0;
        month++;
        break;
                                                case 12:
                                                        if(day == 32)
        day = 0;
        month = 1;
        break;
                Display();
void KeyScan()
        if(KEY_1 == 0)
                delay(10);
                if(KEY_1 == 0)
                        key1cnt++;
                        while(!KEY_1);
                        switch(key1cnt)
                                case 1:
                                        TR0 = 0;
                                        break;
                                case 2:
                                        break;
                                case 3:
                                        break;
                                case 4:
                                        break;
                                case 5:
                                        break;
                                case 6:
                                        TR0 = 1;
                                        key1cnt = 0;
                                        break;
        if(key1cnt != 0)
                if(KEY_2 == 0)
                        delay(10);
                        if(KEY_2 == 0)
                                while(!KEY_2);
                                switch(key1cnt)
                                        case 1:
                                                hour++;
                                                if(hour == 24)
                                                        hour = 0;
                                                break;
                                        case 2:
                                                minu++;
                                                if(minu == 60)
                                                        minu = 0;
                                                break;
                                        case 3:
                                                sec++;
                                                if(sec == 60)
                                                        sec = 0;
                                                break;
                                        case 4:
                                                month++;
                                                if(month == 13)
                                                        month = 1;
                                                break;
                                        case 5:
                                                day++;
                                                if(day == 32)
                                                        day = 1;
                                                break;
        uchar i = 0;
        EA = 1;
                i++;
                KeyScan();
        count++;
        TimerCount();
為什么要做個測試呢?我把程序改了下現在可以用了,星期我也沒搞明白怎樣顯示,希望高手指導
ID:1 發表于 2018-8-31 16:38 | 只看該作者
hslcac 發表于 2018-8-31 15:51
/*作者:lern01 自己總覺得程序有待優化,且星期顯示有問題,對7求余為0時,星期不變化,請高手給予指點, ...
最好到問答區發,這里人氣不夠
ID:89072 發表于 2018-8-31 17:12 | 只看該作者
admin 發表于 2018-8-31 16:38
最好到問答區發,這里人氣不夠
好的,謝謝你
ID:392924 發表于 2018-9-3 14:29 | 只看該作者
厲害了
