查看: 2800|回復: 1
求基于單片機的交通燈信號燈系統
ID:158765 發表于 2016-12-29 22:07 | 顯示全部樓層 |閱讀模式
求基于單片機的交通燈信號燈系統
ID:65425 發表于 2016-12-30 09:25 | 顯示全部樓層
#include<reg51.h>
sbit RED_A=P0^0;
sbit YELLOW_A=P0^1;
sbit GREEN_A=P0^2;
sbit RED_B=P0^3;
sbit YELLOW_B=P0^4;
sbit GREEN_B=P0^5;
uchar Flash_Count=0,Operation_Type=1;
void DelayMs(uint x)
uchar i;
while(x--)for(i=0;i<120;i++);
void Traffic_Light()
        switch(Operation_Type)
                case 1:RED_A=1;YELLOW_A=1;GREEN_A=0;
                       RED_B=0;YELLOW_B=1;GREEN_B=1;
                       DelayMs(2000);
                       Operation_Type=2;
                       break;
                case 2:DelayMs(300);
                       YELLOW_A=~YELLOW_A;GREEN_A=1;
                       if(++Flash_Count!=10)return;
                       Flash_Count=0;
                       Operation_Type=3;
                       break;
                case 3:RED_A=0;YELLOW_A=1;GREEN_A=1;
                       RED_B=1;YELLOW_B=1;GREEN_B=0;
                        DelayMs(2000);
             Operation_Type=4;
                       break;
                case 4:DelayMs(300);
                       YELLOW_B=~YELLOW_B;GREEN_B=1;
                       Flash_Count=0;
                         Operation_Type=1;
   while(1)Traffic_Light();
