做了個簡單的計算器練手
單片機計算器仿真原理圖:
2016-11-30 15:04 上傳
單片機源程序預覽:
- #include<reg52.h>
- sbit in1 = P2^0; //按鍵P2.0輸出
- sbit in2 = P2^1;
- sbit in3 = P2^2;
- sbit in4 = P2^3;
- sbit out1 = P2^4; //動態行變換
- sbit out2 = P2^5; //動態行變換
- sbit out3 = P2^6; //動態行變換
- sbit out4 = P2^7; //動態行變換
- unsigned char code LedChar[]={
- 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
- 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
- unsigned char KeySta[4][4] = {
- {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
- unsigned char LedBuff[6] = {
- 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
- unsigned char code KeyCodeMap[4][4] = { //矩陣按鍵編號到標準鍵盤鍵碼的映射表
- { 0x31, 0x32, 0x33, 0x26 }, //數字鍵1、數字鍵2、數字鍵3、向上鍵
- { 0x34, 0x35, 0x36, 0x25 }, //數字鍵4、數字鍵5、數字鍵6、向左鍵
- { 0x37, 0x38, 0x39, 0x28 }, //數字鍵7、數字鍵8、數字鍵9、向下鍵
- { 0x30, 0x1B, 0x0D, 0x27 } //數字鍵0、ESC鍵、 回車鍵、 向右鍵
- void KeyDriver();
- void main()
- EA = 1; //使能總中斷
- ET0 = 1; //使能T0中斷
- TMOD = 0x01; //設置T0為模式1
- TH0 = 0xDC;
- TL0 = 0x00;
- TR0 = 1; //啟動T0
- P1=0xFF;
- LedBuff[0] = LedChar[0]; //上電顯示0
- while (1)
- KeyDriver(); //調用按鍵驅動函數
- void ShowNumber(unsigned long num)
- signed char i;
- unsigned char buf[6];
- for(i=0; i<6; i++)
- buf[i] = num % 10;
- num = num / 10;
- for(i=5; i>=1; i--)
- if(buf[i] == 0)
- LedBuff[i] = 0xFF;
- else
- break;
- for(; i>=0; i--)
- LedBuff[i] = LedChar[buf[i]];
- void KeyAction(unsigned char keycode)
- static unsigned long result = 0;
- static unsigned long addend = 0;
- if((keycode >= 0x30) &&(keycode <= 0x39))
- addend = (addend *10) + (keycode - 0x30);
- ShowNumber(addend);
- else if(keycode == 0x26)
- result += addend;
- addend = 0;
- ShowNumber(result);
- else if(keycode == 0x0D)
- result += addend;
- addend = 0;
- else if(keycode == 0x1B)
- addend = 0;
- result = 0;
- void KeyDriver()
- unsigned char i, j;
- static unsigned char backup [4][4] = {
- for(i=0; i<4; i++)
- for(j=0; j<4; j++)
- if(backup[i][j] != KeySta[i][j])
- if(backup[i][j] == 0)
- KeyAction(KeyCodeMap[i][j]);
- backup[i][j] = KeySta[i][j];
- /* 按鍵掃描函數,需在定時中斷中調用,推薦調用間隔1ms */
- void KeyScan()
- unsigned char i;
- static unsigned char keyout = 0; //矩陣按鍵掃描輸出索引
- static unsigned char keybuf[4][4] = { //矩陣按鍵掃描緩沖區
- {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
- //將一行的4個按鍵值移入緩沖區
- keybuf[keyout][0] = (keybuf[keyout][0] << 1) | in1;
- keybuf[keyout][1] = (keybuf[keyout][1] << 1) | in2;
- keybuf[keyout][2] = (keybuf[keyout][2] << 1) | in3;
- keybuf[keyout][3] = (keybuf[keyout][3] << 1) | in4;
- //消抖后更新按鍵狀態
- for (i=0; i<4; i++) //每行4個按鍵,所以循環4次
- if ((keybuf[keyout][i] & 0x0F) == 0x00)
- { //連續4次掃描值為0,即4*4ms內都是按下狀態時,可認為按鍵已穩定的按下
- KeySta[keyout][i] = 0;
- else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
- { //連續4次掃描值為1,即4*4ms內都是彈起狀態時,可認為按鍵已穩定的彈起
- KeySta[keyout][i] = 1;
- //執行下一次的掃描輸出
- keyout++; //輸出索引遞增
- keyout = keyout & 0x03; //索引值加到4即歸零
- switch (keyout) //根據索引,釋放當前輸出引腳,拉低下次的輸出引腳
- case 0: out1 = 0; out2 = 1; out3 = 1;out4 = 1; ; break; //當我按下第一行的按鍵,只有keyout==0時符合條件
- case 1: out1 = 1; out2 = 0; out3 = 1;out4 = 1; ; break;
- case 2: out1 = 1; out2 = 1; out3 = 0;out4 = 1; ; break;
- case 3: out1 = 1; out2 = 1; out3 = 1;out4 = 0; ; break;
- default: break;
- /* 數碼管動態掃描刷新函數,需在定時中斷中調用 */
- void LedScan()
- static unsigned char i = 0; //動態掃描的索引
- P0 = 0xFF; //顯示消隱
- switch (i)
- case 0:P1=0xFE; i++; P0=LedBuff[0];break;
- case 1:P1=0xFD; i++; P0=LedBuff[1];break;
- case 2:P1=0xFB; i++; P0=LedBuff[2];break;
- case 3:P1=0xF7; i++; P0=LedBuff[3];break;
- case 4:P1=0xEF; i++; P0=LedBuff[4];break;
- case 5:P1=0xDF; i=0; P0=LedBuff[5];break;
- default:break;
- /* T0中斷服務函數,用于數碼管顯示掃描與按鍵掃描 */
- void InterruptTimer0() interrupt 1
- TH0 = 0xDC;
- TL0 = 0x00;
- LedScan();
- KeyScan();
2016-12-3 23:44 上傳
所有資料打包下載:
簡單的計算器加法程序.zip
(79.82 KB, 下載次數: 21)
2016-11-30 15:02 上傳
下載積分: 黑幣 -5
