查看: 5513|回復: 1
mps430與rc522模塊
ID:147114 發表于 2016-11-12 13:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
主程序
IC-S50數據手冊.PDF (145.92 KB, 下載次數: 12)
MFRC522數據手冊.pdf (2.41 MB, 下載次數: 10)
S50非接觸式IC卡性能簡介(M1).doc (108 KB, 下載次數: 9)
#include "msp430x14x.h"
#include "PIN_DEF.H"
#include "RC522.H"
#include "UART0_Func.c"
#include "ctype.h"
#include "BoardConfig.h"
unsigned char UID[5],Temp[4]                                       ;
unsigned char RF_Buffer[18]                                        ;
unsigned char Password_Buffer[6]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF}   ; // Mifare One 缺省密碼
char          MBRX[30]                                             ;
char          MBKeyTP[30]                                          ;
char          Event                                                ;
unsigned char DISP_MODE,i                                            ; // 編輯控件顯示模式
unsigned char des_on       = 0                                     ; // DES加密標志
void Key_TP_Task(void)                                             ;
//                 初始化主時鐘: MCLK = XT1×(FLL_FACTOR+1)                  //
void Init_CLK(void)
  unsigned int qq;
  WDTCTL     = WDTPW + WDTHOLD                                     ; // 關看門狗
  BCSCTL1 &= ~XT2OFF;           //打開XT2高速晶體振蕩器
  do
    IFG1 &= ~OFIFG;           //Clear oscFault flag清除振蕩器失效標志
    for(qq=0xff;qq>0;qq--);
  }while((IFG1&OFIFG));       //oscFault flag still set
  BCSCTL2 |= SELM_2;          //MCLK=XT2
  //BCSCTL2 |= DIVM_0;        //控制MCLK不分頻,默認
  BCSCTL2 |= SELS;            //SMCLK=XT2
  //BCSCTL2 |= DIVS_0;        //控制SMCLK不分頻,默認
void Delay(unsigned int time)
  unsigned int i,k                             ;
  for(i=0;i<255;i++)
    for(k=0;k<time;k++)
      _NOP()                                   ;
void Auto_Reader(void)
    if(PcdRequest(0x52,Temp)==MI_OK)
      if(Temp[0]==0x04&&Temp[1]==0x00)
          PutString("MFOne-S50");
        else if(Temp[0]==0x02&&Temp[1]==0x00)
          PutString("MFOne-S70");
        else if(Temp[0]==0x44&&Temp[1]==0x00)
          PutString("MF-UltraLight");
        else if(Temp[0]==0x08&&Temp[1]==0x00)
          PutString("MF-Pro");
        else if(Temp[0]==0x44&&Temp[1]==0x03)
          PutString("MF Desire");
          PutString("Unknown");
      if(PcdAnticoll(UID)==MI_OK)
        PutString0("Card Id is:");
        tochar(UID[0]);
        tochar(UID[1]);
        tochar(UID[2]);
        tochar(UID[3]);
        while (!(IFG1 & UTXIFG0));
        TXBUF0 = '\n';                              //發送換行指令
        RED_LED_ON                                            ;
        Delay(200)                                           ;
        RED_LED_OFF                                           ;
        Delay(200)                                           ;
  else GRE_LED_OFF                                            ;
void Find_Card(void)
        PutString("SUCCESS!");
    else PutString("Faile!");
void Init_Port(void)
  P4DIR   =   RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT                     ;
  P2DIR |= BIT0+RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT;
  P1DIR   =   RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT                     ;
函數名稱:HandleConfigMenu
功    能:處理PC的配置函數
參    數:inputvalue--接收到的來自PC機的字符
返回值  :無
void HandleConfigMenu(uchar inputvalue)
    switch(toupper(inputvalue))
    case 'A':
              Auto_Reader();
              break;
    case 'F':
              Find_Card();
              break;
    default:
              DisplayConfigMenu();
void main( void )
  BoardConfig(0xf0);
  Init_Port();
  InitUART();
  _EINT()                                            ;
  PcdReset();//復位RC522
  PcdAntennaOn();//開啟天線發射
        Send1Char('>');
        Send1Char('\n');
        i=Get1Char();
        HandleConfigMenu(i);
8-M1卡的安全問題及華東師大的應對策略.pdf
158.44 KB, 下載次數: 6, 下載積分: 黑幣 -5
13.56MHz天線設計.pdf
134.33 KB, 下載次數: 8, 下載積分: 黑幣 -5
13.56M設計規范.pdf
426.7 KB, 下載次數: 7, 下載積分: 黑幣 -5
Dismantling MIFARE Classic.pdf
566.07 KB, 下載次數: 6, 下載積分: 黑幣 -5
ht-ide3000.pdf
1.74 MB, 下載次數: 6, 下載積分: 黑幣 -5
MSP430 單片機與CPU 卡接口函數設計.pdf
207.46 KB, 下載次數: 6, 下載積分: 黑幣 -5
RC500-FM1702XX比較.pdf
104.16 KB, 下載次數: 6, 下載積分: 黑幣 -5
RFID讀寫器天線的研究與設計.pdf
129.41 KB, 下載次數: 6, 下載積分: 黑幣 -5
RFID天線研究與設計.pdf
低功耗無磁水表中射頻卡讀寫器的設計.pdf
195.42 KB, 下載次數: 7, 下載積分: 黑幣 -5
高速和資源節約型數據加密算法設計.pdf
121.54 KB, 下載次數: 6, 下載積分: 黑幣 -5
基于MF RC500的RFID讀寫器的天線及匹配電路設計.doc
113 KB, 下載次數: 6, 下載積分: 黑幣 -5
基于TRF7960 讀寫器硬件部分設計中應注意的地方.pdf
205.68 KB, 下載次數: 6, 下載積分: 黑幣 -5
近耦合射頻識別系統的工作原理及天線設計.pdf
59.07 KB, 下載次數: 6, 下載積分: 黑幣 -5
設計MF RC500 的匹配電路和天線的應用指南.pdf
959.06 KB, 下載次數: 6, 下載積分: 黑幣 -5
無源電子標簽讀卡器防沖突檢測及天線設計.pdf
1.62 MB, 下載次數: 6, 下載積分: 黑幣 -5
遠距離RFID天線設計.doc
51 KB, 下載次數: 7, 下載積分: 黑幣 -5
阻抗匹配.doc
ID:375715 發表于 2019-11-20 15:47 來自觸屏版 | 只看該作者
謝謝分享
