查看: 2573|回復: 1
stm8 tim1 如何實現定時 不明白都不行
ID:7209 發表于 2016-10-14 14:13 | 顯示全部樓層 |閱讀模式
/* MAIN.C file
* Copyright (c) 2002-2016 STMicroelectronics
曾經給TIM1  捏了無數次,希望能幫到后來的兄弟免遭揉捏之苦,我將持續分析TIM1 的東西發上來給大家共同學習,保障每次一看就明白。
#include "stm8s105c4.h"
void gpio_init(void);
void tim1_init(void);
void delay(unsigned int time);
                PB_ODR |=0X01;
                PB_DDR |=0X01;
                PB_CR1 |=0X01;
                PB_CR2 |=0X01;
void tim1_init()
                //設置預分頻 系數
                TIM1_PSCRH = 0;
                TIM1_PSCRL = 19;
                //默認系統時鐘 2Mhz  2000.000/20 = 100khz
                //周期 1/100.000 = 0.00001s
                //開啟溢出中斷
                TIM1_IER = 0X01;
                //設置定時值
                TIM1_ARRH = (unsigned char) (5000>>8);
                TIM1_ARRL = (unsigned char )5000;
                //設置定時器初值
                TIM1_CNTRH = (unsigned char) (5000>>8);
                TIM1_CNTRL = (unsigned char )5000;
//這產生1 HZ 的方波  高電平500ms  低電平500毫秒
*  50000 從什么地方毛出來的 是預裝載值
*  50000 =定時時間 / 周期
*  比如想 產生10HZ 的方波
*   1/10HZ = 0.1s  就是50ms高電平 50ms低電平
*  0.05s/0.00001s = 5000
*  裝載值 = 5000
*  0.00001s 從哪里來的啊啊啊啊
*  系統默認是 內部時鐘 2mhz   2000.000/(19+1) = 100KHZ
*  1/100KZH = 0.00001s
                while(time--);
void  main()
                gpio_init();
                tim1_init();
                TIM1_CR1 |=0X01;
                _asm("rim");
          while (1);
@far @interrupt void TIM1_OVF_IRQ(void)
                TIM1_SR1 &= 0XFE;
                PB_ODR ^=0X01;  //取反 PB0
記得修改中斷 11 ,否則還是不行的。
ID:7209 發表于 2016-10-14 14:14 | 顯示全部樓層
還是把,中斷這部分發上來,否則,還真有人,實驗不通過
/*        BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
*        Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
        unsigned char interrupt_instruction;
        interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
        /* in order to detect unexpected events during development,
           it is recommended to set a breakpoint on the following instruction
        return;
extern void _stext();     /* startup routine */
extern @far @interrupt void TIM1_OVF_IRQ(void);
struct interrupt_vector const _vectab[] = {
        {0x82, (interrupt_handler_t)_stext}, /* reset */
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, NonHandledInterrupt}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, NonHandledInterrupt}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, TIM1_OVF_IRQ}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, NonHandledInterrupt}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, NonHandledInterrupt}, /* irq18 */
        {0x82, NonHandledInterrupt}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 */
        {0x82, NonHandledInterrupt}, /* irq23 */
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
