單片機4*4矩陣鍵盤程序如下:
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit key1=P3^4;
- sbit D1=P1^0;
- sbit dula=P2^6;
- sbit wela=P2^7;
- void delay(uint z);
- void display(uchar num);
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uchar temp=0;
- void main()
- wela=1; //單個數碼管一直保持選通狀態。
- P0=0xdf;
- wela=0;
- P1=0xff;
- key1=1;
- while(1)
- display(temp);
- if(key1==0)
- delay(9);
- if(key1==0)
- D1=0;
- temp++;
- if(temp==10)
- temp=0;
- while(!key1); //關鍵語句,只要按著按鍵,就不會退出if檢測語句
- else
- D1=1;
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- dula=1;
- P0=table[num];
- dula=0;
- delay(10);
