查看: 5475|回復: 0
全彩RGB音樂頻譜效果
ID:128682 發(fā)表于 2016-6-30 11:43 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
之前在網(wǎng)上看到有人發(fā)了一個全彩RGB的音樂頻譜效果的視頻,很炫酷,但是沒有完整的資料
視頻鏈接:http://v.youku.com/v_show/id_XNzY1MjI5Mzcy.html
不知道有沒有人有關于這個的資料(原理圖)
Digi-Key Part NumberManufacturerManufacturer Part NumberCustomer ReferenceQuantity 1Quantity 2Quantity 3DescriptionComments
P150GCT-NDPANASONIC - ECG (VA)ERJ-3GEYJ151V150 OHM
162
0
0
RES 150 OHM 1/10W 5% 0603 SMDAlternate Packaging Exists
P220GCT-NDPANASONIC - ECG (VA)ERJ-3GEYJ221V220 OHM
9
0
0
RES 220 OHM 1/10W 5% 0603 SMDAlternate Packaging Exists
P1.0KGCT-NDPANASONIC - ECG (VA)ERJ-3GEYJ102V1 K OHM
13
0
0
RES 1.0K OHM 1/10W 5% 0603 SMDAlternate Packaging Exists
P470GCT-NDPANASONIC - ECG (VA)ERJ-3GEYJ471V470 OHM
3
0
0
RES 470 OHM 1/10W 5% 0603 SMDAlternate Packaging Exists
P10KGCT-NDPANASONIC - ECG (VA)ERJ-3GEYJ103V10K OHM
1
0
0
RES 10K OHM 1/10W 5% 0603 SMDAlternate Packaging Exists
445-6853-1-NDTDK CORPORATION (VA)C1608X5R1A106M10UF
2
0
0
CAP CER 10UF 10V X5R 20% 0603Alternate Packaging Exists
311-1372-1-NDYAGEO (VA)CC0603ZRY5V7BB1051UF
10
0
0
CAP CERAMIC 1UF 16V Y5V 0603Alternate Packaging Exists
AP7333-33SAG-7DICT-NDDIODES INC (VA)AP7333-33SAG-7AP7333-33
1
0
0
IC REG LDO 3.3V 0.3A SOT23Alternate Packaging Exists
DMP3098LDICT-NDDIODES INC (VA)DMP3098L-7DMP3098L
3
0
0
MOSFET P-CH 30V 3.8A SOT23-3Alternate Packaging Exists
MMBT2222A-FDICT-NDDIODES INC (VA)MMBT2222A-7-FMMBT2222A
12
0
0
TRANS NPN 40V 350MW SMD SOT23-3Alternate Packaging Exists
PIC24F08KA101-I/SS-NDMICROCHIP TECHNOLOGYPIC24F08KA101-I/SSPIC24F08KA101
1
0
0
IC PIC MCU FLASH 8K 20-SSOPAlternate Packaging Exists
P13351SCT-NDPANASONIC - ECG (VA)EVQ-Q7GA504-WAY STICK SWITCH
1
0
0
SWITCH LT MULTI DIRECTION SMDAlternate Packaging Exists
WM4300-NDMOLEX INC22-05-30212 pin right angle header
1
0
0
CONN HEADER 2POS .100 R/A TIN
WM2011-NDMOLEX INC22-01-20272 pin connector housing
1
0
0
CONN HOUSING 2POS .100 W/RAMP
WM1114-NDMOLEX INC08-50-0114Molex connector terminals
2
0
0
CONN TERM FEMALE 22-30AWG TINAlternate Packaging Exists
附件有hex和最初的原理圖
原理圖源程序.rar
477.59 KB, 下載次數(shù): 98, 下載積分: 黑幣 -5
參與人數(shù) 1黑幣 +100 收起 理由
admin + 100 回帖助人的獎勵!
