程序如下
Receives Test Events from your phone.
After it gets a test message the led 13 will blink
for one second.
#include <MeetAndroid.h>
MeetAndroid meetAndroid;
int onboardLed = 13;
int x;
void setup()
// use the baud rate your bluetooth module is configured to
// not all baud rates are working well, i.e. ATMEGA168 works best with 57600
Serial.begin(57600);
// register callback functions, which will be called when an associated event occurs.
// - the first parameter is the name of your function (see below)
// - match the second parameter ('A', 'B', 'a', etc...) with the flag on your Android application
meetAndroid.registerFunction(testEvent, 'A');
pinMode(onboardLed, OUTPUT);
digitalWrite(onboardLed, HIGH);
void loop()
while(Serial.available())
x=Serial.read();
Serial.println(x);
meetAndroid.receive(); // you need to keep this in your loop() to receive events
* This method is called constantly.
* note: flag is in this case 'A' and numOfValues is 0 (since test event doesn't send any data)
void testEvent(byte flag, byte numOfValues)
flushLed(300);
flushLed(300);
void flushLed(int time)
digitalWrite(onboardLed, LOW);
delay(time);
delay(time);
無論輸入什么參數,結果都是0或者224,這是什么情況???
手機上使用的是Amarino2.0界面如下
