下面是MP3的電路圖,有單片機(jī)部分的圖和電源部分的電路
這是壓縮包文件 包含源代碼2種格式的電路圖:
下載地址:
51單片機(jī)作MP3.zip
(1.23 MB, 下載次數(shù): 76)
2016-4-16 20:31 上傳
點(diǎn)擊文件名下載附件
源碼預(yù)覽scheduler.c :
- /*C**************************************************************************
- * NAME: scheduler.c
- * Copyright (c) 2003 Atmel.
- * RELEASE: snd1c-refd-nf-4_0_3
- * REVISION: 1.8
- * PURPOSE:
- * This file contains the scheduler routines
- * NOTES:
- * Configuration:
- * - SCH_TYPE in scheduler.h header file
- * - SCH_TIMER in scheduler.h header file
- * Global Variables:
- * - gl_cpt_tick: byte in data space
- * - gl_kbd_tick: byte in data space
- * - gl_mem_tick: byte in data space
- /*_____ I N C L U D E S ____________________________________________________*/
- #include "config.h" /* system definition */
- #include "lib_mcu\timer\timer_drv.h" /* timer definition */
- #include "scheduler.h" /* scheduler definition */
- /*_____ M A C R O S ________________________________________________________*/
- /*_____ D E F I N I T I O N ________________________________________________*/
- extern data Byte gl_cpt_tick; /* general tick counter */
- extern data Byte gl_kbd_tick; /* keypad tick counter */
- extern data Byte gl_mem_tick; /* memory tick counter */
- extern data Byte gl_led_tick; /* led tick counter */
- extern idata Uint16 gl_act_tick; /* led tick counter */
- #if (SCH_TYPE != SCH_FREE)
- bit sch_tick_flag;
- #endif
- /*_____ D E C L A R A T I O N ______________________________________________*/
- static void sch_time_init (void);
- /*F**************************************************************************
- * NAME: sch_scheduler_init
- * PARAMS:
- * return:
- * PURPOSE:
- * Scheduler initialization
- * EXAMPLE:
- * NOTE:
- * Task_x_init() and Task_x_fct() are defined in scheduler.h
- * REQUIREMENTS:
- void sch_scheduler_init (void)
- Task_1_init();
- Task_2_init();
- Task_3_init();
- Task_4_init();
- Task_5_init();
- Task_6_init();
- Task_7_init();
- Task_8_init();
- Task_9_init();
- Task_10_init();
- sch_tick_flag = FALSE;
- #endif
- sch_time_init(); /* start time base */
- * PARAMS:
- * return:
- * PURPOSE:
- * Task execution scheduler
- * EXAMPLE:
- * NOTE:
- * REQUIREMENTS:
- void sch_scheduler (void)
- while (1)
- Task_1_fct();
- Sch_call_next_task();
- Task_2_fct();
- Task_3_fct();
- Task_4_fct();
- Task_5_fct();
- Task_6_fct();
- Task_7_fct();
- Task_8_fct();
- Task_9_fct();
- Task_10_fct();
- Sch_new_schedule();
- * NAME: sch_default_fct
- * PARAMS:
- * return:
- * PURPOSE:
- * This function does nothing
- * EXAMPLE:
- * NOTE:
- * REQUIREMENTS:
- void sch_default_fct (void)
- #if (SCH_TIMER == SCH_TIMER0)
- * NAME: sch_time_init
- * PARAMS:
- * return:
- * PURPOSE:
- * Scheduler time base (timer 0) initialization
- * EXAMPLE:
- * NOTE:
- * mode 16-bit Timer, Time counter
- * T0_PRIO to be defined in config.h
- * TIM_LOW & TIM_HIGH defined in scheduler.h
- * REQUIREMENTS:
- void sch_time_init (void)
- T0_init(T0_NOT_GATED, T0_TIMER, T0_MODE_1);
- TL0 = TIM_LOW;
- TH0 = TIM_HIGH;
- t0_set_prio(T0_PRIO); /* set-up priority */
- T0_enable_int(); /* enable interrupt */
- T0_start(); /* start time base */
- * NAME: sch_timer_int
- * PARAMS:
- * return:
- * PURPOSE:
- * Timer 0 interrupt function
- * EXAMPLE:
- * NOTE:
- * IRQ_T0 defined in extsnd1.h
- * REQUIREMENTS:
- Interrupt (sch_timer_int(void), IRQ_T0)
- // T0_stop(); /* stop timer */
- TL0 = TIM_LOW; /* reload timer */
- TH0 = TIM_HIGH;
- // T0_start(); /* restart timer */
- sch_tick_flag = TRUE;
- #endif
- /* increment task tick counters */
- gl_cpt_tick++; /* general timer */
- gl_kbd_tick++; /* keyboard timer */
- gl_mem_tick++; /* memory timer */
- gl_led_tick++; /* LED timer */
- gl_act_tick++; /* Inactivity TIMER */
- #elif (SCH_TIMER == SCH_TIMER1)
- * PARAMS:
- * return:
- * PURPOSE:
- * Scheduler time base (timer 1) initialization
- * EXAMPLE:
- * NOTE:
- * T1_PRIO to be defined in config.h
- * REQUIREMENTS:
- T1_init(T1_NOT_GATED, T1_TIMER, T1_MODE_1);
- TL1 = TIM_LOW;
- TH1 = TIM_HIGH;
- t1_set_prio(T1_PRIO); /* set-up priority */
- T1_enable_int(); /* enable interrupt */
- T1_start(); /* start time base */
- * PARAMS:
- * return:
- * PURPOSE:
- * Timer 1 interrupt function
- * EXAMPLE:
- * NOTE:
- * IRQ_T1 defined in extsnd1.h
- * REQUIREMENTS:
- Interrupt (sch_timer_int(void), IRQ_T1)
- // T1_stop(); /* stop timer */
- TL1 = TIM_LOW; /* reload timer */
- TH1 = TIM_HIGH;
- // T1_start(); /* restart timer */
- #endif
- gl_cpt_tick++;
- #elif (SCH_TIMER == SCH_TIMER2)
- * PARAMS:
- * return:
- * PURPOSE:
- * Scheduler time base (timer 2) initialization
- * EXAMPLE:
- * NOTE:
- * mode 16-bit auto-reload
- * T2_PRIO to be defined in config.h
- * REQUIREMENTS:
- T2_init(T2_AUTO_RELOAD, T2_TIMER, T2_NOT_GATED);
- RCAP2L = TIM_LOW;
- RCAP2H = TIM_HIGH;
- t2_set_prio(T2_PRIO); /* set-up priority */
- T2_enable_int(); /* enable interrupt */
- T2_start(); /* start time base */
- * PARAMS:
- * return:
- * PURPOSE:
- * Timer 2 interrupt function
- * EXAMPLE:
- * NOTE:
- * IRQ_T2 defined in extsnd1.h
- * REQUIREMENTS:
- Interrupt (sch_timer_int(void), IRQ_T2)
- TF2 = 0; /* ack interrupt */
- #endif
- gl_cpt_tick++;
- #endif
評(píng)分
查看全部評(píng)分
