查看: 4032|回復: 0
單片機輸出1HZ方波(源代碼+仿真)
ID:109895 發表于 2016-3-21 08:44 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#include        "Reg51.h"
sbit        SquOut        =        P2^0;
char        INIT_H_0,        INIT_L_0,        INIT_H_1,        INIT_L_1;
void        MySqureOut_T0_ISR(void)        interrupt        1        using        1
        /*TH0        =        0xFE;
        TL0        =        0x16;
        SquOut        ^=        0x01;*/
        if        (SquOut)
                TH0        =        INIT_H_0;
                TL0        =        INIT_L_0;
                SquOut        =        0;
                TH0        =        INIT_H_1;
                TL0        =        INIT_L_1;
                SquOut        =        1;
void        main(void)
        unsigned        int        Period,        CntH, CntL;
        float        TempF;
        Period        =        1;
        Period        *=        1000;        //將其確定為計數個數
        TempF        =        20;
        TempF        *=        Period;
        TempF        /=        100;
        CntH        =        (int)TempF;
        CntL        =        Period        -        CntH;
        if        (CntH        >        10)
                CntH        -=        10;
                CntH        =        1;
        CntH        =        0xFFFF        -        CntH;
        INIT_H_1        =        (CntH        >>        8)        &        0xFF;
        INIT_L_1        =        CntH        &        0xFF;
        if        (CntL        >        10)
                CntL        -=        10;
                CntL        =        1;
        CntL        =        0xFFFF        -        CntL;
        INIT_H_0        =        (CntL        >>        8)        &        0xFF;
        INIT_L_0        =        CntL        &        0xFF;
        //初始化
        TH0        =        0xFE;
        TL0        =        0x0C;
        TMOD        =        0x01;
        ET0                =        1;
        EA                =        1;
        TR0                =        1;
        while(1);
9.1 輸出1kHz方波.rar
38.97 KB, 下載次數: 11, 下載積分: 黑幣 -5
