package com.socket.client;
import java.io.*;
import java.net.Socket;
import java.net.UnknownHostException;
import android.app.Activity;
import android.os.Bundle;
import android.os.Handler;
import android.os.Message;
import android.text.TextUtils;
import android.util.Xml.Encoding;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
public class main extends Activity implements OnClickListener{
/** Called when the activity is first created. */
//定義聲明需要用到的UI元素
private EditText edtmsgcontent;
private Button btnSend;
private String ip="192.168.137.1";//服務(wù)器ip地址
private int port=9898;
private Socket socket=null;//socket
private BufferedWriter writer=null;
Handler handler=new Handler()
@Override
public void handleMessage(Message msg) {
// TODO Auto-generated method stub
byte[] data=(byte[])msg.obj;//取書據(jù)
String str = new String(data);
Toast.makeText(main.this,str,1).show();
super.handleMessage(msg);
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
InitView();
try
socket=new Socket(ip,port); //客戶端分配socket套接字
writer=new BufferedWriter(new OutputStreamWriter(socket.getOutputStream()));
catch(UnknownHostException e)
//e.printStackTrace();
} catch (IOException e)
// e.printStackTrace();
private void InitView()
//顯示主界面
setContentView(R.layout.main);
//通過id獲取ui元素對(duì)象
edtmsgcontent=(EditText)findViewById(R.id.msgcontent);
btnSend=(Button)findViewById(R.id.btnsend);
//為btnsend設(shè)置點(diǎn)擊事件
btnSend.setOnClickListener(this);
public void onClick(View bt)
new Thread(new ReceivThunder()).start(); //step4:開線程
try
String msg=edtmsgcontent.getText().toString();
if(!TextUtils.isEmpty(msg))
SendMsg(ip,port,msg);
Toast.makeText(this,"請(qǐng)先輸入要發(fā)送的內(nèi)容", Toast.LENGTH_LONG);
edtmsgcontent.requestFocus();
catch (Exception e) {
// TODO Auto-generated catch block
public void SendMsg(String ip,int port,String msg) throws UnknownHostException, IOException
writer.write(msg);
writer.flush();
public class ReceivThunder implements Runnable//step1,多線程函數(shù)
@Override
public void run() {
char []ch=new char[10];
try {
BufferedReader reader=new BufferedReader(new InputStreamReader(socket.getInputStream()));
byte[] buffer = new byte[10];
reader.read(ch);
for(int i=0;i<10;i++)
buffer[i]=(byte)ch[i];
Message message=Message.obtain();//攜帶數(shù)據(jù)
message.obj=buffer;
handler.sendMessage(message);//發(fā)送到handler
} catch (IOException e) {
