- #include <12c56.H>
- #define uint8 unsigned char
- #define uint16 unsigned int
- #define uint32 unsigned long
- sbit SDCS = P1^4;
- sbit LAST = P3^3;
- sbit NEXT = P3^4;
- sbit STOP = P2^5;
- uint32 played;
- volatile uint32 start_offset;
- volatile uint16 tptr=0,bdat=0;
- // 播放 插卡 曲目 立體聲
- bit PLAY=0, CK=1 ,QM=0, STEREO=1;
- xdata uint8 buf0[512];
- void delay(uint16 dly)
- uint16 i;
- uint8 j;
- for(i=0;i<dly;i++)
- for(j=0;j<10;j++)
- void T1ISR() interrupt 3
- static uint8 x=0;
- if(!PLAY)
- x++;
- if(x==4)x=0;
- if(!x)
- if(CK)
- if(tptr==1920)
- tptr=0;
- TR1=0;
- else
- tptr++;
- else if(QM)
- if(tptr==1376)
- tptr=0;
- TR1=0;
- else
- tptr++;
- else
- ISP_ADDRH=(tptr>>8)&0xFF;
- ISP_ADDRL=(tptr )&0xFF;
- ISP_CONTR=0x80;
- ISP_CMD=1;
- ISP_TRIG=0x46;
- ISP_TRIG=0xB9;
- tptr++;
- if(tptr==0x0480)TR1=0; //容量
- if(tptr==0x0780)TR1=0; //0
- if(tptr==0x0a80)TR1=0; //1
- if(tptr==0x0d80)TR1=0; //2
- if(tptr==0x1080)TR1=0; //3
- if(tptr==0x1380)TR1=0; //4
- if(tptr==0x1680)TR1=0; //5
- if(tptr==0x1980)TR1=0; //6
- if(tptr==0x1c80)TR1=0; //7
- if(tptr==0x1f80)TR1=0; //8
- if(tptr==0x2280)TR1=0; //9
- if(tptr==0x2580)TR1=0; //千
- if(tptr==0x2880)TR1=0; //百
- if(tptr==0x2b80)TR1=0; //十
- if(tptr==0x2e80)TR1=0; //兆
- else
- else
- CCAP0H=buf0[tptr++];
- bdat--;
- if(STEREO)
- CCAP1H=buf0[tptr++];
- bdat--;
- else
- CCAP1H=CCAP0H;
- if(tptr>=512)
- tptr=0;
- void SPI_INIT()
- SPCTL=0xd0;
- void SPI_INIT_LOW()
- SPCTL=0xd1;
- uint8 SPI_COMM(uint8 dat)
- SDCS=0;
- SPDAT=dat;
- while((SPSTAT&0x80)==0);
- SPSTAT=0x80;
- SDCS=1;
- return(SPDAT);
- uint8 SD_SendCommand(uint8 cmd, uint32 arg)
- uint8 r1;
- uint8 retry=0;
- SPI_COMM(0xff);
- SDCS=0;
- SPI_COMM(cmd | 0x40);//分別寫入命令 //send command
- SPI_COMM(arg>>24);
- SPI_COMM(arg>>16);
- SPI_COMM(arg>>8);
- SPI_COMM(arg);
- SPI_COMM(0x95);
- while((r1 = SPI_COMM(0xff)) == 0xff)//等待響應, //wait response
- if(retry++ > 20) break;//超時退出 //time out error
- SDCS=1;
- return r1;//返回狀態值 //return state
- uint8 InitSD()
- uint8 tmp,ret;
- for(tmp=0;tmp<0x0f;tmp++)
- SPI_COMM(0xff);
- SDCS=0;
- SPI_COMM(0x40);
- SPI_COMM(0x00);
- SPI_COMM(0x00);
- SPI_COMM(0x00);
- SPI_COMM(0x00);
- SPI_COMM(0x95);
- for(tmp=0;tmp<0x7f;tmp++)
- ret=SPI_COMM(0xff);
- if(ret==0x01)
- uint8 retry=0,r1;
- do
- r1 = SD_SendCommand(1, 0);//發active命令 //send active command
- retry++;
- if(retry>100) return 1;//超時退出 //time out
- } while(r1);
- //SPI_High();
- r1 = SD_SendCommand(59, 0);//關crc //disable CRC
- r1 = SD_SendCommand(16, 512);//設扇區大小512 //set sector size to 512
- return 0;
- SDCS=1;
- return 1;
- //讀一個扇區 //read one sector
- uint8 SD_ReadSector(uint32 sector, uint8* buffer)
- uint8 r1;
- uint16 i;
- uint16 retry=0;
- r1 = SD_SendCommand(17, (start_offset+sector)<<9);//讀命令 //read command
- if(r1 != 0x00)
- return r1;
- SDCS=0;
- //等數據的開始 //wait to start recieve data
- while(SPI_COMM(0xff) != 0xfe)
- if(retry++ > 1000)
- SDCS=1;
- return 1;
- for(i=0; i<512; i++)//讀512個數據
- bdat++;
- while(bdat>=512);
- *buffer++ = SPI_COMM(0xff);
- SPI_COMM(0xff);//偽crc
- SPI_COMM(0xff);
- SDCS=1;
- return 0;
- void TIMER0_INIT()
- TMOD=0x22;
- TH0=TL0=0xFF;
- TR0=1;
- ET0=0;
- void TIMER1_INIT(uint16 hz)
- if(hz>=8000)
- CLK_DIV=0x00;
- TH1=TL1=(uint8)(256-((uint32)1040000/hz));//0x7e;
- else
- CLK_DIV=0x02;
- TH1=TL1=(uint8)(256-((uint32)260000/hz));//0x7e;
- TR1=0;
- EA=1;
- ET1=1;
- void CCP_INIT()
- AUXR|=0x80;
- CMOD=0x04;
- CL=0x00;
- CH=0x00;
- CCAP0L=0x80;
- CCAP0H=0x80;
- CCAPM0=0x42;
- CCAP1L=0x80;
- CCAP1H=0x80;
- CCAPM1=0x42;
- CR=1;
- void main()//主函數
- uint8 i=0;
- uint32 ptr;
- uint8 FATs;
- uint16 BytesPerSector;
- uint8 SectorsPerClust;
- uint8 FirstFATSector;
- uint16 RootDirCount;
- uint16 RootDirSectors;
- uint16 FirstDirSector;
- uint16 FirstDataSector;
- uint32 samps;
- uint8 sbits;
- uint32 filelen;
- uint16 sPtr=0,iPtr=0;
- uint8 currTrack=0,Track=1;
- //------ 3.3V I/O口配置 -------
- P1M0=P1M1=0xf0; //P1.7-P1.4開漏
- TIMER0_INIT();
- CCP_INIT();
- IT0=1;
- EX0=1;
- RESTART:
- Track=0;
- TR1=0;
- CK=1;
- tptr=0;
- PLAY=0;
- TIMER1_INIT(8000);
- TR1=1;
- while(TR1);
- CK=0;
- SPI_INIT_LOW();
- while(1)
- if(!InitSD())break;
- SPI_INIT();
- delay(1000);
- tptr=0;
- TR1=1;
- while(TR1);
- TR1=1;
- while(TR1);
- delay(5000);
- goto read;
- LASTTRACK:
- TR1=0;
- PLAY=0;
- start_offset=0;
- currTrack=0;
- Track--;
- goto read;
- NEXTTRACK:
- TR1=0;
- PLAY=0;
- start_offset=0;
- currTrack=0;
- Track++;
- read:
- while(1)
- //FAT16文件系統處理
- //判斷引導扇區有效性
- bdat=65535;
- if(!SD_ReadSector(0,buf0))
- if((buf0[0]!=0xeb)||(buf0[1]!=0x3c)||(buf0[2]!=0x90)) //如果不是EB 3C 90說明有分區表,繼續讀取之,否則直接開始播放
- start_offset=(buf0[0x01c6]<<0)|(buf0[0x01c7]<<8)|(buf0[0x01c8]<<16)|(buf0[0x01c9]<<24);
- bdat=65535;
- SD_ReadSector(0,buf0);
- if((buf0[510]==0x55)&&(buf0[511]==0xaa))
- else
- goto RESTART;
- else
- goto RESTART;
- //讀FAT表信息
- FATs=buf0[0x10];
- BytesPerSector=buf0[0x0B]|(buf0[0x0C]<<8);
- SectorsPerClust=buf0[0x0D];
- FirstFATSector=buf0[0x0E];
- RootDirCount=buf0[0x11]|(buf0[0x12]<<8);
- RootDirSectors = (RootDirCount>>4);//根目錄占用的扇區數
- FirstDirSector=FirstFATSector+FATs*(buf0[0x16]|(buf0[0x17]<<8));
- FirstDataSector = FirstDirSector+RootDirSectors;//第一個數據扇區
- //搜索WAV文件
- for(sPtr=0;sPtr<RootDirSectors;sPtr++)
- bdat=65535; //-1(允許讀卡一次讀完512字節)
- SD_ReadSector(FirstDirSector+sPtr,buf0);
- for(iPtr=0;iPtr<512;iPtr+=32)
- if((buf0[iPtr]!='.')&&(buf0[iPtr]!=0x00)&&(buf0[iPtr]!=0xe5) & (buf0[iPtr+0x0B]!=0x0f))
- if((buf0[iPtr+0x08]=='W')&&(buf0[iPtr+0x09]=='A')&&(buf0[iPtr+0x0a]=='V'))
- ptr=(uint32)FirstDataSector+(uint32)SectorsPerClust*((buf0[iPtr+0x1A]|(buf0[iPtr+0x1B]<<8))-2);
- filelen=(((uint32)buf0[iPtr+0x1c]|(((uint32)buf0[iPtr+0x1d])<<8)|(((uint32)buf0[iPtr+0x1e])<<16)|((uint32)(buf0[iPtr+0x1f])<<24))/512)-2;
- currTrack++;
- if(currTrack==Track)break;
- if(currTrack!=Track)
- Track=0;
- goto NEXTTRACK;
- bdat=65535;
- SD_ReadSector(ptr++,buf0);
- samps=(buf0[0x18]|(buf0[0x19]<<8)|(buf0[0x1A]<<16)|(buf0[0x1B]<<24));
- sbits=buf0[0x22];
- if(buf0[0x16]==2)
- STEREO=1;
- else
- STEREO=0;
- if(sbits!=8)
- goto NEXTTRACK;
- if(samps>48000)
- goto NEXTTRACK;
- QM=1;
- tptr=0;
- TR1=1;
- while(TR1);
- QM=0;
- TIMER1_INIT(samps/2);//(24000);
- bdat=65535;
- tptr=0;
- played=0;
- PLAY=1;
- TR1=1;
- while(1)
- if(SD_ReadSector(ptr++,buf0))goto RESTART;
- if(!LAST)goto LASTTRACK;
- if(!NEXT)goto NEXTTRACK;
- if(!STOP)PCON=PCON^0xfe;
- if((played++)>filelen)goto NEXTTRACK;
- void exint0() interrupt 0
