寫的很粗糙但非常實(shí)用
- void shibie(IplImage *pSrcImage,IplImage* img_d,Surface* m)
- //通過一個(gè)IplImag對(duì)象識(shí)別一個(gè)魔方面的狀態(tài)img_d是通過去背景處理后的圖
- IplImage *g_pGrayImage = NULL;
- CvSeq *g_pcvSeq = NULL;
- //增強(qiáng)關(guān)鍵顏色
- CvScalar s;
- for(int i=0;i<pSrcImage->height;i++){
- for(int j=0;j<pSrcImage->width;j++){
- s=cvGet2D(pSrcImage,i,j);
- if(s.val[2]>230&&s.val[1]>110&&s.val[1]<170&&s.val[0]<100&&s.val[0]>30)
- //增強(qiáng)橙色
- s.val[0]=50;
- s.val[1]=140;
- s.val[2]=250;
- cvSet2D(pSrcImage,i,j,s);
- }else if(s.val[2]<25&&s.val[1]>140&&s.val[1]<200&&s.val[0]<120&&s.val[0]>50)
- //增強(qiáng)綠色
- s.val[0]=90;
- s.val[1]=170;
- s.val[2]=0;
- }else if(s.val[2]>0&&s.val[2]<29&&s.val[1]>36&&s.val[1]<70&&s.val[0]<220&&s.val[0]>170)
- //增強(qiáng)藍(lán)色
- s.val[0]=190;
- s.val[1]=50;
- s.val[2]=10;
- }else if(s.val[2]>220&&s.val[2]<250&&s.val[1]>170&&s.val[1]<210&&s.val[0]<20)
- //增強(qiáng)黃色
- s.val[0]=10;
- s.val[1]=190;
- s.val[2]=220;
- // 顯示顏色增強(qiáng)后原圖
- //cvNamedWindow("顏色增強(qiáng)后原圖", CV_WINDOW_AUTOSIZE);
- //cvShowImage("顏色增強(qiáng)后原圖", pSrcImage);
- //去除背景
- for(i=0;i<pSrcImage->height;i++)
- if(!((s.val[0]==50&&s.val[1]==140&&s.val[2]==250)||(s.val[0]==90&&s.val[1]==170&&s.val[2]==0)||(s.val[0]==190&&s.val[1]==50&&s.val[2]==10)||(s.val[0]==10&&s.val[1]==190&&s.val[2]==220)))
- s.val[0]=0;
- s.val[1]=0;
- s.val[2]=0;
- // 轉(zhuǎn)為灰度圖
- g_pGrayImage = cvCreateImage(cvGetSize(pSrcImage), IPL_DEPTH_8U, 1);
- cvCvtColor(pSrcImage, g_pGrayImage, CV_BGR2GRAY);
- // 轉(zhuǎn)為二值圖
- IplImage *pBinaryImage = cvCreateImage(cvGetSize(g_pGrayImage), IPL_DEPTH_8U, 1);
- cvThreshold(g_pGrayImage, pBinaryImage, 0, 255, CV_THRESH_BINARY);
- CvMemStorage* cvMStorage = cvCreateMemStorage();
- // 檢索輪廓并返回檢測到的輪廓的個(gè)數(shù)
- cvFindContours(pBinaryImage,cvMStorage, &g_pcvSeq,sizeof(CvContour),CV_RETR_EXTERNAL);
- IplImage *pOutlineImage = cvCreateImage(cvGetSize(g_pGrayImage), IPL_DEPTH_8U, 3);
- int _levels = 1;
- cvZero(pOutlineImage);
- cvDrawContours(pOutlineImage, g_pcvSeq, CV_RGB(255,0,0), CV_RGB(0,255,0), _levels);
- cvShowImage("pstrWindowsOutLineTitle", pOutlineImage);
- //在原圖上繪制輪廓
- //IplImage *pSrcImage = cvLoadImage("c:\\123.jpg", CV_LOAD_IMAGE_UNCHANGED);
- cvDrawContours(pSrcImage, g_pcvSeq, CV_RGB(0,255,0), CV_RGB(0,255,0), _levels,3);
- //通過輪廓定位并計(jì)算魔方塊坐標(biāo)
- int x,y,x1,y1,H,W,D,x2,y2;
- x=y=x1=y1=1;
- int B=1;//跳出標(biāo)記
- //找左上角
- for(i=0;i<pSrcImage->height&&B==1;i++)
- for(int j=0;j<pSrcImage->width&&B==1;j++)
- if(s.val[2]==0&&s.val[1]==255&&s.val[0]==0)
- y=i;
- B=0;
- B=1;
- for(int i=0;i<pSrcImage->height&&B==1;i++)
- x=j;
- B=0;
- //找右下角
- B=1;
- for(i=pSrcImage->height-1;i>=0&&B==1;i--)
- for(int j=pSrcImage->width-1;j>=0&&B==1;j--)
- y1=i;
- B=0;
- B=1;
- for(j=pSrcImage->width-1;j>=0&&B==1;j--)
- x1=j;
- B=0;
- H=y1-y;
- W=x1-x;
- D=(W+H)/6;
- for(i=y+(D/2),y2=1;i<y1;i+=D,y2++)
- for(j=x+(D/2),x2=1;j<x1;j+=D,x2++)
- if(s.val[0]==50&&s.val[1]==140&&s.val[2]==250) m->s[y2][x2]=(Colors)5;//橙色
- if(s.val[0]==90&&s.val[1]==170&&s.val[2]==0) m->s[y2][x2]=(Colors)4;//綠色
- if(s.val[0]==190&&s.val[1]==50&&s.val[2]==10) m->s[y2][x2]=(Colors)2;//藍(lán)色
- if(s.val[0]==10&&s.val[1]==190&&s.val[2]==220) m->s[y2][x2]=(Colors)6;//黃色
- s.val[0]=0;
- s.val[1]=0;
- s.val[2]=255;
- cvSet2D(pSrcImage,y,x,s);
- cvSet2D(pSrcImage,y1,x1,s);
- for(i=y+(D/2);i<y1;i+=D)
- for(j=x+(D/2);j<x1;j+=D)
- cvNamedWindow("定位矩形區(qū)域", CV_WINDOW_AUTOSIZE);
- cvShowImage("定位矩形區(qū)域", pSrcImage);
- cvReleaseMemStorage(&cvMStorage);
- cvReleaseImage(&pBinaryImage);
- cvReleaseImage(&pOutlineImage);
