#include <reg52.h>
#include <intrins.h>
#define NOP _nop_()
sbit OE = P1^0;
sbit A1 = P1^4;
sbit B1 = P1^5;
sbit SHCP=P1^6; //11腳SHCP 移位時鐘
sbit STCP=P1^7; //12腳STCP 鎖存時鐘
sbit DATA=P3^1; //數據輸入
uchar code table[10][32]=
{{0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF}, //謝
{ 0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
}; //謝
//數據串行輸入
void serial_input(uchar dat)
uint m;
for(m=0;m<8;m++)
if(dat & 0x80)
DATA=1;
DATA=0;
SHCP=0;
SHCP=1;
NOP;
NOP;
SHCP=0;
NOP;
NOP;
dat=dat<<1;
//并出
void serial_output()
STCP=1;
NOP;
NOP;
STCP=0;
//行顯控制
void HC138_scan(uchar temp)
OE=1;
A1=0x01 & temp;
B1=0x01 &(temp>>1);
//整屏顯示
void display()
uint i,j,k;
for(k=0;k<4;k++) //顯示的四行
for(j=0;j<2;j++) //顯示3、4列
for(i=0;i<2;i++) // 顯示1、2列
serial_input(table[j][3*8+2*k+i]);
serial_input(table[j][2*8+2*k+i]);
serial_input(table[j][1*8+2*k+i]);
serial_input(table[j][0*8+2*k+i]);
serial_output();
HC138_scan(k);
display();
這是程序,由于我技術有限,看不懂。望各位大神指導一下。
