查看: 3623|回復: 1
stm8s ADC采樣代碼
ID:85501 發表于 2015-7-13 08:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<iostm8s103f3.h>
unsigned int ms_count;
unsigned char adcflag;
unsigned int ADCData;
unsigned char ADCBuff[4];
**函數名稱:void UART1_Init(unsigned int baudrate)
**功能描述:初始化USART模塊
**入口參數:unsigned int baudrate  -> 設置串口波特率
**輸出:無
  unsigned int baud;              //
  baud = 16000000 / baudrate;     //設定串口相應波特率與串口時鐘的分頻數
  //先寫BRR2 , 再寫BRR1
  UART1_BRR2 = ((unsigned char)((baud & 0xf000) >> 8 )) | ((unsigned char)(baud & 0x000f));       //先寫波特比率的高4位與低4位
  UART1_BRR1 =  ((unsigned char)((baud & 0x0ff0) >> 4));                                          //后寫波特比率的中間8位
  UART1_CR1_bit.UART0 = 0;        //使能UART0
  UART1_CR2_bit.RIEN = 0;         //不使能中斷接收
  UART1_CR2_bit.TEN = 1;          //使能發送
  UART1_CR2_bit.REN = 0;          //接收不使能
**函數名稱:void Uart_SendData(unsigned char  data)
**功能描述:向串口發送寄存器寫入一個字節數據
**入口參數:unsigned char  data
**輸出:無
  while(!(UART1_SR&0X80));        //判斷發送數據寄存器是否為空
  UART1_DR = data;                //向發送寄存器寫入數據
  while(!(UART1_SR&0X40));        //等待發送完成
**函數名稱:void Uart_SendString(unsigned char *data , unsigned char strlen)
**功能描述:向串口連續發送多個字符
**入口參數:unsigned char *data   ,  unsigned char strlen
**輸出:無
  unsigned char datalen;
  for(datalen = 0 ; datalen < strlen ; datalen++)
    Uart_SendData(data[datalen]);
**函數名稱:void ADC_Init()
**功能描述:初始化ADC
**入口參數:無
**輸出:無
void ADC_Init()
  PC_DDR_bit.DDR4 = 0;   //設置PC->4 為輸入
  PC_CR1_bit.C14 = 0;    //設置為懸空輸入
  PC_CR2_bit.C24 = 0;    //設置中斷禁止
  ADC_CR1_bit.SPSEL = 3;    //fmaster / 18 = 16MHZ / 18 = 888888HZ
  ADC_CR2_bit.ALIGN = 1;    //RIGHT ALIGN
  ADC_CSR_bit.CH = 2;       //SELECT AIN2
  ADC_CR1_bit.ADON = 1;     //啟動ADC
**函數名稱:void ADC_Data_Read(unsigned int *AD_Value)
**功能描述:讀取ADC完成一次模數轉換結果
**入口參數:unsigned int *AD_Value
            *AD_Value ->讀取ADC采樣數據的指針
**輸出:無
  while(ADC_CSR_bit.EOC == 0);  //等待轉換結束
  *AD_Value = ADC_DRH;          //先讀取高8位
  *AD_Value = (unsigned int)((*AD_Value << 8) + ADC_DRL);   //高8位與低8位相加,湊成16位數據
**函數名稱:void Timer4Init()
**功能描述:定時器4參數初始化
**入口參數:無
**輸出:無
void Timer4Init()
  TIM4_IER_bit.UIE = 0;       //禁止中斷
  TIM4_EGR_bit.UG = 0;
  TIM4_PSCR_bit.PSC = 7;      // 設置TIM4的時鐘分頻系數為 128  即定時器時鐘 = 16000000 /128 = 125KHZ
  TIM4_ARR = 125;             // 設定TIM4產生1毫秒的計數值
  TIM4_CNTR = 0x00;            // 清除TIM4計數寄存器數值
  TIM4_SR_bit.UIF = 0;        //清除中斷標志
  TIM4_SR_bit.TIF = 0;
  TIM4_CR1_bit.CEN = 1;       //使能定時器4計數
  TIM4_CR1_bit.ARPE = 1;      //使能預裝載
  TIM4_IER_bit.UIE = 1;       // 使能更新中斷
/*    主函數    */
int main(void)
  asm("sim");             //關閉系統總中斷
  CLK_CKDIVR = 0x00;      //CPUDIV = 1 HSIDIV = 1  內部時鐘 = 16Mhz
  UART1_Init(9600);       //調用串口初始化函數,并設置波特率為9600 bps
  ADC_Init();             //調用ADC初始化函數
  Timer4Init();           //初始化定時器4
  asm("rim");             //打開系統總中斷
    if(adcflag == 1)                        //1秒定時時間到對使能ADC進行采樣
      asm("sim");                           //關系統總中斷
     // ADC_Data_Read(&ADCData);              //讀取ADC的采樣數值
     // Uart_SendString("ADC_DATA = " , 11);  //發送字符串"ADC_DATA = "
      ADCBuff[1] = ADCData % 10 + '0';      //轉換成ASCII碼
      ADCBuff[0] = ADCData % 100 / 10 + '0';
     // ADCBuff[1] = ADCData / 100 % 10 + '0';
      //ADCBuff[0] = ADCData / 1000 + '0';
      ADCBuff[2] = 0x0d;                    //換行字符
      ADCBuff[3] = 0x0a;
      Uart_SendString(ADCBuff , 4);         //向PC機發送ADC采樣數值
      adcflag = 0;                          //ADC采樣標志清除
      asm("rim");                           //開系統總中斷,準備下次ADC采樣
/**     定時器4中斷服務函數       */
#pragma vector = 25
__interrupt void TIM4_UPDATE_IRQHandler(void)
  ms_count++;
  if(ms_count >= 1000)      //記錄1秒時間到
    ms_count = 0;
    adcflag = 1;            //設置ADC采樣標志
參與人數 1威望 +50 黑幣 +50 收起 理由
admin + 50 + 50 共享資料的積分獎勵!
收藏收藏3 分享淘帖 頂 踩
ID:219807 發表于 2017-7-19 17:14 | 只看該作者
多謝分享,參考正做AD采樣測量電流的方案。
