- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- bit write=0;
- sbit sda=P2^0;
- sbit scl=P2^1;
- sbit dula=P2^6;
- sbit wela=P2^7;
- uchar sec,tcnt;
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x7c,0x39,0x5e,0x79,0x71};
- void delay()
- void delay1ms(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void start()
- sda=1;
- delay();
- scl=1;
- delay();
- sda=0;
- delay();
- void stop()
- sda=0;
- delay();
- scl=1;
- delay();
- sda=1;
- delay();
- void respons()
- uchar i;
- scl=1;
- delay();
- while((sda==1)&&i<250)
- i++;
- scl=0;
- delay();
- void init()
- sda=1;
- delay();
- scl=1;
- delay();
- void write_byte(uchar date)
- uchar i,temp;
- temp=date;
- for(i=0;i<8;i++)
- temp=temp<<1;
- scl=0;
- delay();
- sda=CY;
- delay();
- scl=1;
- delay();
- scl=0;
- delay();
- sda=1;
- delay();
- uchar read_byte()
- uchar i,k;
- scl=0;
- delay();
- sda=1;
- delay();
- for(i=0;i<8;i++)
- scl=1;
- delay();
- k=(k<<1)|sda;
- scl=0;
- delay();
- return k;
- void write_add(uchar address,uchar date)
- start();
- write_byte(0xa0);
- respons();
- write_byte(address);
- respons();
- write_byte(date);
- respons();
- stop();
- uchar read_add(uchar address)
- uchar date;
- start();
- write_byte(0xa0);
- respons();
- respons();
- start();
- write_byte(0xa1);
- respons();
- date=read_byte();
- stop();
- return date;
- void display(uchar bai_c,uchar sh_c)
- dula=0;
- P0=table[bai_c];
- dula=1;
- dula=0;
- wela=0;
- P0=0x7e;
- wela=1;
- wela=0;
- delay1ms(5);
- dula=0;
- P0=table[sh_c];
- dula=1;
- dula=0;
- wela=0;
- P0=0x7d;
- wela=1;
- wela=0;
- delay1ms(5);
- void main()
- init();
- sec=read_add(2);
- if(sec>100)
- sec=0;
- TMOD=0x01;
- ET0=1;
- EA=1;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- TR0=1;
- while(1)
- display(sec/10,sec%10);
- if(write==1)
- write=0;
- write_add(2,sec);
- void t0() interrupt 1
- tcnt++;
- if(tcnt==20)
- tcnt=0;
- sec++;
- write=1;
- if(sec==100)
- sec=0;
