查看: 3532|回復: 0
哈哈笨法子流水LED顯示屏字幕
ID:83710 發表于 2015-6-23 20:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本程序系用世界上少有的“笨法子”編譯,因為簡單所以可靠,可惜占空間太大!9月8日于天津第四項目部宿舍編!
          “       滾動顯示                  "
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. //#define x=P2;
  5. //#define y=P1;
  6.    uchar code  taby[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; //Y軸掃描碼
  7.    uchar code  tabx7[]={ 0xFE,0x10,0x10,0x7E,0x10,0x10,0x10,0xFF};//X軸自行嗎
  8.    uchar code  tabx6[]={0x10,0x10,0x7E,0x10,0x10,0x10,0xFF,0x00};
  9.    uchar code  tabx5[]={0x10,0x7E,0x10,0x10,0x10,0xFF,0x0e,0x00};
  10.    uchar code  tabx4[]={0x7E,0x10,0x10,0x10,0xFF,0x00,0x00,0x00};
  11.    uchar code  tabx3[]={0x10,0x10,0x10,0xFF,0x00,0x00,0x00,0x00};
  12.    uchar code  tabx2[]={0x10,0x10,0xFF,0x00,0x00,0x00,0x00,0x00};
  13.    uchar code  tabx1[]={0x10,0xFF,0x00,0x00,0x00,0x00,0x00,0x00};
  14.    uchar code  tabx0[]={0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  15. uchar code  tabx17[]={0x48,0x5F,0xF9,0x59,0x45,0x69,0x91,0x6};
  16. uchar code  tabx16[]={0x5F,0xF9,0x59,0x45,0x69,0x91,0x6,0x00};
  17. uchar code  tabx15[]={0xF9,0x59,0x45,0x69,0x91,0x6,0x00,0x00,};
  18. uchar code  tabx14[]={0x59,0x45,0x69,0x91,0x6,0x00,0x00,0x00};
  19. uchar code  tabx13[]={0x45,0x69,0x91,0x6,0x00,0x00,0x00,0x00};
  20. uchar code  tabx12[]={0x69,0x91,0x6,0x00,0x00,0x00,0x00,0x00};
  21. uchar code  tabx11[]={0x91,0x6,0x00,0x00,0x00,0x00,0x00,0x00};
  22. uchar code  tabx10[]={0x6,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  23. uchar code  tabx27[]={0x48,0x7F,0xDE,0xC8,0x7F,0x49,0x4B,0x4A};
  24. uchar code  tabx26[]={0x7F,0xDE,0xC8,0x7F,0x49,0x4B,0x4A,0x00};
  25. uchar code  tabx25[]={0xDE,0xC8,0x7F,0x49,0x4B,0x4A,0x00,0x00};
  26. uchar code  tabx24[]={0xC8,0x7F,0x49,0x4B,0x4A,0x00,0x00,0x00};
  27. uchar code  tabx23[]={0x7F,0x49,0x4B,0x4A,0x00,0x00,0x00,0x00};
  28. uchar code  tabx22[]={0x49,0x4B,0x4A,0x00,0x00,0x00,0x00,0x00};
  29. uchar code  tabx21[]={0x4B,0x4A,0x00,0x00,0x00,0x00,0x00,0x00};
  30. uchar code  tabx20[]={0x4A,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  31. void delay1ms()
  32. {
  33. unsigned char a,b;
  34.     for(b=102;b>0;b--)
  35.         for(a=3;a>0;a--);
  36. }
  37. void main()
  38. {
  39. uchar s,m;
  40. while(1)
  41.   {
  42.    uint j;
  43.    for(j=0;j<25;j++)
  44.      {
  45.                 uchar i;
  46.             for(i=0;i<8;i++)
  47.                   {
  48.                 P1=taby[s];//Y軸掃描
  49.                 P2=tabx0
  50. -; //X軸數碼
  51.                    delay1ms();
  52.                s++;
  53.                m++;
  54.                  }
  55.                  s=0;
  56.               m=0;
  57.    }
  58.    for(j=0;j<25;j++)
  59.      {
  60.                 uchar i;
  61.             for(i=0;i<8;i++)
  62.                   {
  63.                 P1=taby[s];//Y軸掃描
  64.                 P2=tabx1
  65. -; //X軸數碼
  66.                    delay1ms();
  67.                s++;
  68.                m++;
  69.                  }
  70.                  s=0;
  71.               m=0;
  72.    }
  73.
  74.    for(j=0;j<25;j++)
  75.      {
  76.                 uchar i;
  77.             for(i=0;i<8;i++)
  78.                   {
  79.                 P1=taby[s];//Y軸掃描
  80.                 P2=tabx2
  81. -; //X軸數碼
  82.                    delay1ms();
  83.                s++;
  84.                m++;
  85.                  }
  86.                  s=0;
  87.               m=0;
  88.    }
  89.
  90.    for(j=0;j<25;j++)
  91.      {
  92.                 uchar i;
  93.             for(i=0;i<8;i++)
  94.                   {
  95.                 P1=taby[s];//Y軸掃描
  96.                 P2=tabx3
  97. -; //X軸數碼
  98.                    delay1ms();
  99.                s++;
  100.                m++;
  101.                  }
  102.                  s=0;
  103.               m=0;
  104.    }
  105.
  106.    for(j=0;j<25;j++)
  107.      {
  108.                 uchar i;
  109.             for(i=0;i<8;i++)
  110.                   {
  111.                 P1=taby[s];//Y軸掃描
  112.                 P2=tabx4
  113. -; //X軸數碼
  114.                    delay1ms();
  115.                s++;
  116.                m++;
  117.                  }
  118.                  s=0;
  119.               m=0;
  120.    }
  121.
  122.    for(j=0;j<25;j++)
  123.      {
  124.                 uchar i;
  125.             for(i=0;i<8;i++)
  126.                   {
  127.                 P1=taby[s];//Y軸掃描
  128.                 P2=tabx5
  129. -; //X軸數碼
  130.                    delay1ms();
  131.                s++;
  132.                m++;
  133.                  }
  134.                  s=0;
  135.               m=0;
  136.    }
  137.
  138.    for(j=0;j<25;j++)
  139.      {
  140.                 uchar i;
  141.             for(i=0;i<8;i++)
  142.                   {
  143.                 P1=taby[s];//Y軸掃描
  144.                 P2=tabx6
  145. -; //X軸數碼
  146.                    delay1ms();
  147.                s++;
  148.                m++;
  149.                  }
  150.                  s=0;
  151.               m=0;
  152.    }
  153.
  154.    for(j=0;j<25;j++)
  155.      {
  156.                 uchar i;
  157.             for(i=0;i<8;i++)
  158.                   {
  159.                 P1=taby[s];//Y軸掃描
  160.                 P2=tabx7
  161. -; //X軸數碼
  162.                    delay1ms();
  163.                s++;
  164.                m++;
  165.                  }
  166.                  s=0;
  167.               m=0;
  168.    }
  169.
  170.    for(j=0;j<25;j++)
  171.      {
  172.                 uchar i;
  173.             for(i=0;i<8;i++)
  174.                   {
  175.                 P1=taby[s];//Y軸掃描
  176.                 P2=tabx10
  177. -; //X軸數碼
  178.                    delay1ms();
  179.                s++;
  180.                m++;
  181.                  }
  182.                  s=0;
  183.               m=0;
  184.    }
  185.
  186.    for(j=0;j<25;j++)
  187.      {
  188.                 uchar i;
  189.             for(i=0;i<8;i++)
  190.                   {
  191.                 P1=taby[s];//Y軸掃描
  192.                 P2=tabx11
  193. -; //X軸數碼
  194.                    delay1ms();
  195.                s++;
  196.                m++;
  197.                  }
  198.                  s=0;
  199.               m=0;
  200.    }
  201.
  202.    for(j=0;j<25;j++)
  203.      {
  204.                 uchar i;
  205.             for(i=0;i<8;i++)
  206.                   {
  207.                 P1=taby[s];//Y軸掃描
  208.                 P2=tabx12
  209. -; //X軸數碼
  210.                    delay1ms();
  211.                s++;
  212.                m++;
  213.                  }
  214.                  s=0;
  215.               m=0;
  216.    }
  217.
  218.    for(j=0;j<25;j++)
  219.      {
  220.                 uchar i;
  221.             for(i=0;i<8;i++)
  222.                   {
  223.                 P1=taby[s];//Y軸掃描
  224.                 P2=tabx13
  225. -; //X軸數碼
  226.                    delay1ms();
  227.                s++;
  228.                m++;
  229.                  }
  230.                  s=0;
  231.               m=0;
  232.    }
  233.
  234.    for(j=0;j<25;j++)
  235.      {
  236.                 uchar i;
  237.             for(i=0;i<8;i++)
  238.                   {
  239.                 P1=taby[s];//Y軸掃描
  240.                 P2=tabx14
  241. -; //X軸數碼
  242.                    delay1ms();
  243.                s++;
  244.                m++;
  245.                  }
  246.                  s=0;
  247.               m=0;
  248.    }
  249.
  250.    for(j=0;j<25;j++)
  251.      {
  252.                 uchar i;
  253.             for(i=0;i<8;i++)
  254.                   {
  255.                 P1=taby[s];//Y軸掃描
  256.                 P2=tabx15
  257. -; //X軸數碼
  258.                    delay1ms();
  259.                s++;
  260.                m++;
  261.                  }
  262.                  s=0;
  263.               m=0;
  264.    }
  265.
  266.    for(j=0;j<25;j++)
  267.      {
  268.                 uchar i;
  269.             for(i=0;i<8;i++)
  270.                   {
  271.                 P1=taby[s];//Y軸掃描
  272.                 P2=tabx16
  273. -; //X軸數碼
  274.                    delay1ms();
  275.                s++;
  276.                m++;
  277.                  }
  278.                  s=0;
  279.               m=0;
  280.    }
  281.
  282.    for(j=0;j<25;j++)
  283.      {
  284.                 uchar i;
  285.             for(i=0;i<8;i++)
  286.                   {
  287.                 P1=taby[s];//Y軸掃描
  288.                 P2=tabx17
  289. -; //X軸數碼
  290.                    delay1ms();
  291.                s++;
  292.                m++;
  293.                  }
  294.                  s=0;
  295.               m=0;
  296.    }
  297.
  298.    for(j=0;j<25;j++)
  299.      {
  300.                 uchar i;
  301.             for(i=0;i<8;i++)
  302.                   {
  303.                 P1=taby[s];//Y軸掃描
  304.                 P2=tabx20
  305. -; //X軸數碼
  306.                    delay1ms();
  307.                s++;
  308.                m++;
  309.                  }
  310.                  s=0;
  311.               m=0;
  312.    }
  313.
  314.    for(j=0;j<25;j++)
  315.      {
  316.                 uchar i;
  317.             for(i=0;i<8;i++)
  318.                   {
  319.                 P1=taby[s];//Y軸掃描
  320.                 P2=tabx21
  321. -; //X軸數碼
  322.                    delay1ms();
  323.                s++;
  324.                m++;
  325.                  }
  326.                  s=0;
  327.               m=0;
  328.    }
  329.
  330.    for(j=0;j<25;j++)
  331.      {
  332.                 uchar i;
  333.             for(i=0;i<8;i++)
  334.                   {
  335.                 P1=taby[s];//Y軸掃描
  336.                 P2=tabx22
  337. -; //X軸數碼
  338.                    delay1ms();
  339.                s++;
  340.                m++;
  341.                  }
  342.                  s=0;
  343.               m=0;
  344.    }
  345.
  346.    for(j=0;j<25;j++)
  347.      {
  348.                 uchar i;
  349.             for(i=0;i<8;i++)
  350.                   {
  351.                 P1=taby[s];//Y軸掃描
  352.                 P2=tabx23
  353. -; //X軸數碼
  354.                    delay1ms();
  355.                s++;
  356.                m++;
  357.                  }
  358.                  s=0;
  359.               m=0;
  360.    }
  361.
  362.    for(j=0;j<25;j++)
  363.      {
  364.                 uchar i;
  365.             for(i=0;i<8;i++)
  366.                   {
  367.                 P1=taby[s];//Y軸掃描
  368.                 P2=tabx24
  369. -; //X軸數碼
  370.                    delay1ms();
  371.                s++;
  372.                m++;
  373.                  }
  374.                  s=0;
  375.               m=0;
  376.    }
  377.
  378.    for(j=0;j<25;j++)
  379.      {
  380.                 uchar i;
  381.             for(i=0;i<8;i++)
  382.                   {
  383.                 P1=taby[s];//Y軸掃描
  384.                 P2=tabx25
  385. -; //X軸數碼
  386.                    delay1ms();
  387.                s++;
  388.                m++;
  389.                  }
  390.                  s=0;
  391.               m=0;
  392.    }
  393.
  394.    for(j=0;j<25;j++)
  395.      {
  396.                 uchar i;
  397.             for(i=0;i<8;i++)
  398.                   {
  399.                 P1=taby[s];//Y軸掃描
  400.                 P2=tabx26
  401. -; //X軸數碼
  402.                    delay1ms();
  403.                s++;
  404.                m++;
  405.                  }
  406.                  s=0;
  407.               m=0;
  408.    }
  409.
  410.    for(j=0;j<25;j++)
  411.      {
  412.                 uchar i;
  413.             for(i=0;i<8;i++)
  414.                   {
  415.                 P1=taby[s];//Y軸掃描
  416.                 P2=tabx27
  417. -; //X軸數碼
  418.                    delay1ms();
  419.                s++;
  420.                m++;
  421.                  }
  422.                  s=0;
  423.               m=0;
  424.    }
  425.   }
  426. }//END
