- #include "radio.h"
- #include"spi.h"
- #include"uart.h"
- #define TxGPIOSetting() SpiWriteRegister(0x0E, 0x02)
- #define RxGPIOSetting() SpiWriteRegister(0x0E, 0x01)
- #define IdleGPIOSetting() SpiWriteRegister(0x0E, 0x01)
- void RF_init(void)
- //Set the physical parameters
- //Frequency: 433MHz
- //Modulation type: GFSK
- //CrytalTolerance: Rx,10ppm; Tx, 10ppm
- //Data rate: 9.6Kbps/1.2Kbps
- //AFC: Enable
- //Frequency deviation: 20KHz
- //set the center frequency to 433 MHz
- SpiWriteRegister(0x75, 0x53); //write data to the Frequency Band Select register
- SpiWriteRegister(0x76, 0x4B); //write data to the Nominal Carrier Frequency1 register
- SpiWriteRegister(0x77, 0x00); //write data to the Nominal Carrier Frequency0 register
- //set the desired TX data rate (1.2kbps)
- SpiWriteRegister(0x6E, 0x09); //write data to the TXDataRate 1 register
- SpiWriteRegister(0x6F, 0xD5); //write data to the TXDataRate 0 register
- SpiWriteRegister(0x70, 0x2C); //write data to the Modulation Mode Control 1 register
- SpiWriteRegister(0x58, 0x80);
- //set the TX power to MAX. dBm
- SpiWriteRegister(0x6D, 0x1F); //write data to the TX Power register
- //set the Tx deviation register (+-20kHz)
- SpiWriteRegister(0x72, 0x20); //write data to the Frequency Deviation register
- /*set the modem parameters according to the exel calculator(parameters: 1.2 kbps, deviation: 20 kHz*/
- SpiWriteRegister(0x1C, 0x2C); //write data to the IF Filter Bandwidth register
- SpiWriteRegister(0x20, 0x41); //write data to the Clock Recovery Oversampling Ratio register
- SpiWriteRegister(0x21, 0x60); //write data to the Clock Recovery Offset 2 register
- SpiWriteRegister(0x22, 0x27); //write data to the Clock Recovery Offset 1 register
- SpiWriteRegister(0x23, 0x52); //write data to the Clock Recovery Offset 0 register
- SpiWriteRegister(0x24, 0x00); //write data to the Clock Recovery Timing Loop Gain 1 register
- SpiWriteRegister(0x25, 0x04); //write data to the Clock Recovery Timing Loop Gain 0 register
- SpiWriteRegister(0x1D, 0x40); //write data to the AFC Loop Gearshift Override register
- SpiWriteRegister(0x1E, 0x0A);
- SpiWriteRegister(0x2A, 0x0F); //write data to the AFC Limiter register
- SpiWriteRegister(0x1F, 0x03);
- SpiWriteRegister(0x69, 0x60);
- /*set the packet structure and the modulation type*/
- //set the preamble length to 10bytes if the antenna diversity is used and set to 5bytes if not
- SpiWriteRegister(0x34, 0x0C); //write data to the Preamble Length register
- //set preamble detection threshold to 20bits
- SpiWriteRegister(0x35, 0x2A); //write data to the Preamble Detection Control register
- //Disable header bytes; set variable packet length (the length of the payload is defined by the
- //received packet length field of the packet); set the synch word to two bytes long
- SpiWriteRegister(0x33, 0x02); //write data to the Header Control2 register
- //Set the sync word pattern to 0x2DD4
- SpiWriteRegister(0x36, 0x2D); //write data to the Sync Word 3 register
- SpiWriteRegister(0x37, 0xD4); //write data to the Sync Word 2 register
- //enable the TX & RX packet handler and CRC-16 (IBM) check
- SpiWriteRegister(0x30, 0x8D); //write data to the Data Access Control register
- //Disable the receive header filters
- SpiWriteRegister(0x32, 0x00 ); //write data to the Header Control1 register
- //enable FIFO mode and GFSK modulation
- SpiWriteRegister(0x71, 0x63); //write data to the Modulation Mode Control 2 register
- /*set the GPIO's according the testcard type*/
- SpiWriteRegister(0x0B, 0xCA); //Set GPIO0 output
- SpiWriteRegister(0x0C, 0xCA); //Set GPIO1 output
- SpiWriteRegister(0x0D, 0xCA); //Set GPIO2 output Rx Data
- //set Crystal Oscillator Load Capacitance register
- SpiWriteRegister(0x09, CRYSTAL_CAPACITANCE); //write data to the Crystal Oscillator Load Capacitance register
- idata U8 ItStatus1,ItStatus2;
- // Function Name :RFSetRxMode
- // Return Value : None
- // Parameters : None
- // Notes : 設置模塊工作在接收狀態下,當一切準備好的時候,調用該函數可以讓模塊工作于接收模式下
- void RFSetRxMode(void)
- //read interrupt status registers to release all pending interrupts
- ItStatus1 = SpiReadRegister(0x03); //read the Interrupt Status1 register
- ItStatus2 = SpiReadRegister(0x04); //read the Interrupt Status2 register
- //Set the Rx switcher,利用GPIO口控制模塊內部的天線開關。
- RxGPIOSetting();
- /*enable receiver chain*/
- SpiWriteRegister(0x07, 0x05);
- // Function Name :RFSetTxMode
- // Notes : 設置模塊工作在接收狀態下,當一切準備好的時候,調用該函數可以讓模塊工作于發射狀態模式下
- void RFSetTxMode(void)
- //Read interrupt status regsiters. It clear all pending interrupts and the nIRQ pin goes back to high.
- TxGPIOSetting();
- /*enable transmitter*/
- //The radio forms the packet and send it automatically.
- SpiWriteRegister(0x07, 0x09);
- // Function Name :RFSetIdleMode
- // Notes : 設置模塊工作在空閑狀態下。當模塊不需要接收數據也不需要發射數據的時候可以調用該函數以便省電;
- void RFSetIdleMode(void)
- //The radio will work in idle mode
- SpiWriteRegister(0x07, 0x01); //write 0x09 to the Operating Function Control 1 register
- IdleGPIOSetting();
- // Function Name :RFFIFOSendData
- // Parameters : uint8 length: the length of the content which will be sent out. This value should
- // not more than 64bytes because the FIFO is 64bytes. If it is bigger than 64, the
- // content should be sent out for more times according to the FIFO empty interrupt.
- // uint8 *payload: point to the content.
- // Notes : In FIFO mode, send out one packet data.
- // 調用該函數可以把數據寫入模塊的FIFO中并把數據發送出去;數據長度不能大于64個字節;
- void RFFIFOSendData(U8 length, U8 *payload)
- U8 i;
- RFSetIdleMode();
- //turn on the Tx LED to show the packet transmission
- //TxLEDOn();
- /*SET THE CONTENT OF THE PACKET*/
- //set the length of the payload.
- SpiWriteRegister(0x3E, length);
- //fill the payload into the transmit FIFO
- for(i = 0; i < length; i++)
- SpiWriteRegister(0x7F, payload[i]);
- //Disable all other interrupts and enable the packet sent interrupt only.
- //This will be used for indicating the successfull packet transmission for the MCU
- SpiWriteRegister(0x05, 0x04); //write 0x04 to the Interrupt Enable 1 register
- SpiWriteRegister(0x06, 0x00); //write 0x00 to the Interrupt Enable 2 register
- RFSetTxMode();
- /*wait for the packet sent interrupt*/
- //The MCU just needs to wait for the 'ipksent' interrupt.
- //等待發射完成中斷的到來,如果中斷采用非查詢方式,則本程序到這里可以結束,但必須在中斷服務程序中讀取狀態寄存器0x03和0x04,以便釋放中斷
- while(NIRQ == 1);
- UART_Send_Str("已發送..............\n");//調試信息時候用
- //read interrupt status registers to release the interrupt flags
- //turn off the Tx LED
- //TurnOffAllLEDs();
51單片機驅動程序4432.rar
2015-6-4 14:16 上傳
下載積分: 黑幣 -5
59.3 KB, 下載次數: 42, 下載積分: 黑幣 -5
