完整程序源代碼工程文件下載地址:
gpio.rar
(230.86 KB, 下載次數: 15)
2015-5-27 17:03 上傳
- STM32學習日志(2)----GPIO測試程序
- 編譯環境: EWARM V5.30
- 硬件環境: 51hei EK-STM32F
- 作者 : szlihongtao
- 時間 : 2010-06-29
- 說明 : 1.驗證引腳的輸入輸出功能
- 2.驗證引腳配置的鎖定功能
- 3.將JTAG引腳配置為普通的IO口
- * @file Project/Template/main.c
- * @author MCD Application Team
- * @version V3.0.0
- * @date 04/06/2009
- * @brief Main program body
- * @copy
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include "stm32_m.h"
- /** @addtogroup Template_Project
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program.
- * @param None
- * @retval : None
- // 延時50ms
- static void delay(void)
- INT32U i;
- static INT32U jjj=5240*50;
- for (i=0; i<jjj; i++);
- // 時鐘設置初始化
- static void RCC_Configuration(void)
- ErrorStatus HSEStartUpStatus;
- RCC_AdjustHSICalibrationValue 調整內部高速晶振(HSI)校準值
- RCC_ITConfig 使能或者失能指定的RCC中斷
- RCC_ClearFlag 清除RCC的復位標志位
- RCC_GetITStatus 檢查指定的RCC中斷發生與否
- RCC_ClearITPendingBit 清除RCC的中斷待處理位
- /* RCC system reset(for debug purpose) */
- // 時鐘系統復位
- RCC_DeInit();
- // 使能外部的8M晶振
- // 設置外部高速晶振(HSE)
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- // 使能或者失能內部高速晶振(HSI)
- RCC_HSICmd(DISABLE);
- // 等待HSE起振
- // 該函數將等待直到HSE就緒,或者在超時的情況下退出
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- /* HCLK = SYSCLK */
- // 設置AHB時鐘(HCLK)
- RCC_HCLKConfig(RCC_SYSCLK_Div1); // 72 MHz
- /* PCLK1 = HCLK/2 */
- // 設置低速AHB時鐘(PCLK1)
- RCC_PCLK1Config(RCC_HCLK_Div2); // 36 MHz
- /* PCLK2 = HCLK */
- // 設置高速AHB時鐘(PCLK2)
- RCC_PCLK2Config(RCC_HCLK_Div1); // 72 MHz
- /* ADCCLK = PCLK2/8 */
- // 設置ADC時鐘(ADCCLK)
- RCC_ADCCLKConfig(RCC_PCLK2_Div8);
- // 設置USB時鐘(USBCLK)
- // USB時鐘 = PLL時鐘除以1.5
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
- // 設置外部低速晶振(LSE)
- RCC_LSEConfig(RCC_LSE_OFF);
- // 使能或者失能內部低速晶振(LSI)
- // LSE晶振OFF
- RCC_LSICmd(DISABLE);
- // 設置RTC時鐘(RTCCLK)
- // 選擇HSE時鐘頻率除以128作為RTC時鐘
- RCC_RTCCLKConfig(RCC_RTCCLKSource_HSE_Div128);
- // 使能或者失能RTC時鐘
- // RTC時鐘的新狀態
- RCC_RTCCLKCmd(DISABLE);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2);
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- /* PLLCLK = 8MHz * 9 = 72 MHz */
- // 設置PLL時鐘源及倍頻系數
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- /* Enable PLL */
- // 使能或者失能PLL
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- // 檢查指定的RCC標志位設置與否
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- // 設置系統時鐘(SYSCLK)
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- // 返回用作系統時鐘的時鐘源
- while(RCC_GetSYSCLKSource() != 0x08)
- #if 0
- // 讀取返回不同片上時鐘的頻率,單位 Hz
- /* Get the frequencies of different on chip clocks */
- RCC_ClocksTypeDef RCC_Clocks;// 指向結構RCC_ClocksTypeDef的指針,包含了各個時鐘的頻率
- RCC_GetClocksFreq(&RCC_Clocks); // 可以在仿真環境下看到各個不同的頻率
- delay();
- #endif
- // 使能或者失能AHB外設時鐘
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1
- |RCC_AHBPeriph_DMA2
- |RCC_AHBPeriph_SRAM
- |RCC_AHBPeriph_FLITF
- |RCC_AHBPeriph_CRC
- |RCC_AHBPeriph_FSMC
- |RCC_AHBPeriph_SDIO,DISABLE);
- // 使能或者失能APB1外設時鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL,DISABLE);
- // 強制或者釋放高速APB(APB2)外設復位
- RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,ENABLE);
- // 退出復位狀態
- RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,DISABLE);
- // 強制或者釋放低速APB(APB1)外設復位
- RCC_APB1PeriphResetCmd(RCC_APB1Periph_ALL,ENABLE);
- // 強制或者釋放后備域復位
- RCC_BackupResetCmd(ENABLE);
- // 使能或者失能時鐘安全系統
- RCC_ClockSecuritySystemCmd(DISABLE);
- #if 0
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- // 選擇在MCO管腳上輸出的時鐘源
- // 選中HSE
- // 警告:當選中系統時鐘作為MCO管腳的輸出時,注意它的時鐘頻率不超過50MHz(最大I/O速率)。
- // PA8/USART1_CK/ TIM1_CH1/MCO STM32F103VBT6---pin67
- //RCC_MCOConfig(RCC_MCO_NoClock);// 示波器實際輸出低電平
- RCC_MCOConfig(RCC_MCO_HSE); // 示波器實際測量頻率8.00047MHz,外部晶振
- #endif
- // NVIC設置
- static void NVIC_Configuration(void)
- // SysTick設置初始化
- static void SysTick_Config1(void)
- #define SystemFreq 72000000.0 // 單位為Hz
- #define TB_SysTick 100000.0 // 單位為uS,與示波器實測一致
- INT32U ticks;
- ticks=(INT32U)((TB_SysTick/1000000.0)*SystemFreq);
- ticks=ticks;
- //SysTick_Config(ticks);
- // GPIO設置
- static void GPIO_Configuration(void)
- #define CONFIG_BUT 1
- // 使能或者失能APB2外設時鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- #if (CONFIG_BUT==0)
- IO口為輸入模式,由于電路板上有外接的10K上拉電阻
- 實際測量端口電壓為3.300V
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- #elif (CONFIG_BUT==1)
- IO口為輸入上拉模式,輸出端口應該寫入1,以便使能內部的上拉電阻
- 這時,外部的10K上拉電阻可以不接
- // 這時,測量引腳電壓為3.300V
- GPIO_SetBits(GPIOD, GPIO_Pin_3 | GPIO_Pin_4);// 這條語句可以取消,因為有外部上拉電阻
- //GPIO_ResetBits(GPIOD, GPIO_Pin_3 | GPIO_Pin_4);
- // 這時,測量引腳電壓為2.650V,根據歐姆定律推算內部的下拉電阻為40K
- #elif (CONFIG_BUT==2)
- IO口為輸入下拉模式,輸出端口應該寫入0,以便使能內部的電阻
- 這時,外部的10K上拉電阻一定要接
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
- //GPIO_SetBits(GPIOD, GPIO_Pin_3 | GPIO_Pin_4);// 這條語句可以取消,因為有外部上拉電阻
- GPIO_ResetBits(GPIOD, GPIO_Pin_3 | GPIO_Pin_4);
- #else
- error!
- #endif
- 總結:
- 按鍵輸入的時候,以下5種設置都是可以運行的!
- 1.設定為懸空輸入 GPIO_Mode_IN_FLOATING,外接電電阻,推薦
- 2.設定為上拉輸入 GPIO_Mode_IPU,輸出寫1,可以不外接電阻,強烈推薦
- 3.設定為上拉輸入 GPIO_Mode_IPU,輸出寫0,外接電阻,不推薦!!!!!!!!!!
- 4.設定為下拉輸入 GPIO_Mode_IPD,輸出寫0,外接電阻,不推薦!!!!!!!!!!
- 5.設定為下拉輸入 GPIO_Mode_IPD,輸出寫1,可以不外接電阻,可以
- // LED5亮
- void Led_RW_ON(void)
- GPIO_SetBits(GPIOC,GPIO_Pin_4);
- // LED5滅
- void Led_RW_OFF(void)
- GPIO_ResetBits(GPIOC,GPIO_Pin_4);
- // 主程序
- int main(void)
- RCC_Configuration();
- GPIO_Configuration();
- NVIC_Configuration();
- SysTick_Config1();
- Led_RW_ON();
- delay();
- Led_RW_OFF();
- // 以下代碼驗證引腳配置的鎖定功能
- #if 0
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; // oc門
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
- GPIO_ResetBits(GPIOD,GPIO_Pin_4); // OC門設置的話,輸出必須設定0
- GPIO_PinLockConfig(GPIOD, GPIO_Pin_4); // 鎖定引腳設置寄存器
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; // 重新設定為輸入
- for(;;)
- // 按key3沒有反映,因為引腳設置鎖定了,修改無效
- if (GPIO_ReadInputDataBit(GPIOD,GPIO_Pin_4)==Bit_SET)
- Led_RW_ON();
- else
- Led_RW_OFF();
- #endif
- // 以下代碼 JTAG引腳配置為普通的IO口
- #if 1
- if (GPIO_ReadInputDataBit(GPIOD,GPIO_Pin_4)==Bit_RESET) /* Key3 is pressed */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
- delay();
- /* Disable the Serial Wire Jtag Debug Port SWJ-DP */
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE);
- /* Configure PA.13 (JTMS/SWDAT), PA.14 (JTCK/SWCLK) and PA.15 (JTDI) as
- output push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
- /* Configure PB.03 (JTDO) and PB.04 (JTRST) as output push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- for (;;) /* Toggle JTMS/SWDAT pin */
- GPIOA->ODR ^= GPIO_Pin_13; // JTMS/SWDAT, PIN72
- GPIOA->ODR ^= GPIO_Pin_14; // JTCK/SWCLK, PIN76
- GPIOA->ODR ^= GPIO_Pin_15; // JTDI, PIN77
- GPIOB->ODR ^= GPIO_Pin_3; // JTDO, PIN89
- GPIOB->ODR ^= GPIO_Pin_4; // JTRST, PIN90
- delay();
- GPIOC->ODR ^= GPIO_Pin_4; // led5 toogle
- #endif
- for (;;)
- delay();
- if (GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_3)) // key2
- GPIO_SetBits(GPIOC,GPIO_Pin_7); // led2
- else
- GPIO_ResetBits(GPIOC,GPIO_Pin_7);
- GPIO_WriteBit(GPIOC,GPIO_Pin_5,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_5)));// LED4
- //GPIO_WriteBit(GPIOC,GPIO_Pin_4,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_4)));//LED5
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval : None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
- LED2---------PC7
- LED3---------PC6
- LED4---------PC5
- LED5---------PC4
- KEY2---------PD3
- KEY3---------PD4
