- #include<reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit SDA=P0^0;
- sbit SCL=P0^1;
- sbit dio=P0^2;
- sbit clk=P0^3;
- sbit stb=P0^4;
- sfr P3M1=0xb1;//強(qiáng)推挽輸出
- sfr P3M0=0xb2;
- sfr ADC_CONTR=0xBC; //ADC用
- sfr ADC_RES=0xBD;
- sfr P1ASF=0x9D;
- sbit kzd=P3^7; //低速控制
- sbit kzz=P3^6; //中速控制
- sbit kzg=P3^5; //高速控制
- sbit kzf=P3^4; //負(fù)離子控制
- sbit kzj=P3^1; //加濕控制
- sbit ledd=P2^1;//低速指示燈
- sbit ledz=P2^2;//中速指示燈
- sbit ledg=P2^3;//高速指示燈
- sbit ledj=P2^4;//加濕指示燈
- sbit ledf=P2^5;//負(fù)離子指示燈
- sbit ledkq=P1^1;//空氣質(zhì)量指示燈
- sbit ledds=P1^3;//定時(shí)指示燈
- sbit fmq=P3^0; //蜂鳴器
- uint zzshu=1000;//初始化時(shí),賦值大于轉(zhuǎn)動(dòng)脈沖數(shù)
- uint fzshu=1000;//初始化時(shí),賦值大于轉(zhuǎn)動(dòng)脈沖數(shù)
- uchar qw; //氣味處理值
- uint qwcaiji; //氣味采集值
- uint key;
- uchar TM_0,TM_2,TM_4; //TM1629B顯示用參數(shù)
- uchar code table[]={0x7e,0x42,0x5d,0x57,0x63,0x37,0x3f,0x52,0x7f,0x77};
- uchar code zheng[]={0x30,0x60,0xc0,0x90};
- uchar code fan[]={0x30,0x90,0xc0,0x60};
- void TM1629B_xie(uchar xie)
- uchar i;
- for(i=0;i<8;i++)
- clk=0;
- if(xie&0x01)
- {dio=1;}
- else
- {dio=0;}
- clk=1;
- xie>>=1;
- void TM1629B_COM(uchar cmd)
- stb=0;
- TM1629B_xie(cmd);
- stb=1;
- void TM1629B_mie(void)
- uchar i;
- stb=0;
- TM1629B_xie(0xc0); //地址命令,00H顯示地址
- for(i=0;i<14;i++)
- {TM1629B_xie(0x00);} //所有顯示為滅
- stb=1;
- void TM1629B_init(void)
- clk=1;
- stb=1;
- dio=1;
- TM1629B_COM(0x00);//顯示模式
- TM1629B_COM(0x40);//寫數(shù)據(jù)、地址自動(dòng)增加
- TM1629B_mie();
- TM1629B_COM(0x89);//顯示開(kāi),灰度2/16
- void delay(int x)
- uint i,j;
- for(i=x;i>0;i--)
- for(j=1100;j>0;j--);
- void init_ADC(void); //ADC初始化
- uint get_ADC_qw(void); //獲取氣味AD結(jié)果
- void SC09A(void);//按鍵掃描
- uint a,b;//定時(shí)、風(fēng)速
- bit g;//開(kāi)機(jī)
- bit qh;//切換標(biāo)志位
- uint num; //時(shí)間定時(shí)
- uchar ir; //紅外線用
- uint startflag;
- uint bitnum;
- uchar irjsok,irjmok;
- uchar ircode[4];
- uchar irdata[33];
- void irjm(void) //把ir時(shí)間值解碼
- uchar k,i,j;
- uchar value;
- k=1;
- for(j=0;j<4;j++)
- for(i=0;i<8;i++)
- value=value>>1; //移位保存
- if(irdata[k]>6) //判斷值1或0
- value=value|0x80;
- k++;
- ircode[j]=value;
- irjmok=1;
- void irkz(void) //一個(gè)碼值對(duì)應(yīng)一個(gè)控制
- if(ircode[1]==0xFF)
- if(ircode[2]==0x09)//第1個(gè)按鈕,開(kāi)關(guān)
- fmq=1;
- delay(15);
- fmq=0;
- g=~g;
- a=0;//開(kāi)機(jī)復(fù)位,定時(shí)燈全滅
- b=1;//開(kāi)機(jī)低速運(yùn)行
- if(g==1)
- zzshu=0;
- fzshu=1000;
- else
- zzshu=1000;
- fzshu=0;
- if(g==1) //防止關(guān)機(jī)時(shí),按鍵有聲音
- if(ircode[2]==0x11) //第2個(gè)按鈕,風(fēng)速
- fmq=1;
- delay(15);
- fmq=0;
- b++;
- if(b>3)//風(fēng)速循環(huán)
- b=1;
- if(ircode[2]==0x19)//第3個(gè)按鈕,加濕
- fmq=1;
- delay(15);
- fmq=0;
- kzj=~kzj;
- ledj=~ledj;//加濕指示燈
- if(ircode[2]==0x17)//第4個(gè)按鈕,負(fù)離子
- fmq=1;
- delay(15);
- fmq=0;
- ledf=~ledf;
- kzf=~kzf;
- if(ircode[2]==0x16) //第5個(gè)按鈕,定時(shí)
- fmq=1;
- delay(15);
- fmq=0;
- a=a+60;
- if(a>360)
- a=0;
- qh=1;//按定時(shí)按鈕,顯示自動(dòng)切換成定時(shí)
- if(ircode[2]==0x04) //第6個(gè)按鈕,切換
- fmq=1;
- delay(15);
- fmq=0;
- qh=~qh;
- }//if(g==1)
- }//if(ircode[1]==0xFF)
- }//irkz
- void main()
- uint t;//ADC采樣時(shí)間控制
- P3M1=0;//P3.0強(qiáng)推挽輸出
- P3M0=0x01;
- fmq=1;//上電響
- delay(50);
- fmq=0;
- delay(350);//電壓穩(wěn)定再進(jìn)行IAP操作
- init_ADC();
- TM1629B_init();
- TMOD=0x12;//定時(shí)器1為方式1,定時(shí)器0為方式2
- EA=1;
- TH1=(65535-45872)/256;
- TL1=(65535-45872)%256;
- ET1=1;
- TH0=0x00;
- TL0=0x00;
- ET0=1;
- TR0=1;
- TR1=1; //定時(shí)器1開(kāi),定時(shí)、濾網(wǎng)時(shí)間共用
- IT1=1; //外部中斷1設(shè)置
- EX1=1; //外部中斷1允許
- IT0=1; //外部中斷0設(shè)置
- EX0=1; //外部中斷0允許
- while(1)
- if(irjsok) //紅外程序,用遙控器按鈕6解除濾網(wǎng)報(bào)警
- irjm();
- irjsok=0;
- if(irjmok)
- irkz();
- irjmok=0;
- SC09A();//按鍵掃描
- if(zzshu<150)//正轉(zhuǎn)150個(gè)脈沖
- int i;
- zzshu++;
- for(i=0;i<4;i++)
- P1=P1&0x0f;
- P1=P1|zheng[i];
- delay(8);//
- else
- P1=P1&0x0f;
- if(fzshu<150)//反轉(zhuǎn)150個(gè)脈沖
- int i;
- fzshu++;
- for(i=0;i<4;i++)
- P1=P1&0x0f;
- P1=P1|fan[i];
- delay(8);//
- else
- P1=P1&0x0f;
- if(a==1)
- if(num>1100) //最后1分鐘算做55秒
- g=0;
- a=0;//定時(shí)時(shí)間到關(guān)機(jī),為了區(qū)別手動(dòng)按到0值時(shí)不能關(guān)機(jī)
- //紅外線測(cè)試時(shí)加g=1
- if(g==1)//開(kāi)機(jī)時(shí),執(zhí)行以下程序
- if(a!=0) //定時(shí)器T0開(kāi)始工作
- if(num>1205)//設(shè)置定時(shí)時(shí)間,1分鐘設(shè)置為1205
- num=0;
- a--;
- if(a==0)//a=0時(shí),一直保持num值加不上去
- num=0;
- if(qh==1)
- ledkq=1;
- ledds=0;
- else
- ledkq=0;
- ledds=1;
- if(b==1)//低速
- kzd=0; //低風(fēng)
- kzz=1;
- kzg=1;
- ledd=0;
- ledz=1;
- ledg=1;
- if(b==2)//中速
- kzd=1; //中風(fēng)
- kzz=0;
- kzg=1;
- ledd=1;
- ledz=0;
- ledg=1;
- if(b==3)//高速
- kzd=1; //高風(fēng)
- kzz=1;
- kzg=0;
- ledd=1;
- ledz=1;
- ledg=0;
- TM1629B_COM(0x44);//寫數(shù)據(jù)、固定地址
- stb=0;
- TM1629B_xie(0xc0); //地址命令設(shè)置00H,這是個(gè)位
- TM1629B_xie(table[TM_0]);
- stb=1;
- stb=0;
- TM1629B_xie(0xc2); //地址命令設(shè)置02H,這是十位
- TM1629B_xie(table[TM_2]);
- stb=1;
- stb=0;
- TM1629B_xie(0xc4); //地址命令設(shè)置04H,這是百位
- TM1629B_xie(table[TM_4]);
- stb=1;
- else//g不等于1時(shí),關(guān)閉輸出
- kzd=1; //低速控制
- kzz=1; //中速控制
- kzg=1; //高速控制
- kzf=1; //負(fù)離子控制
- kzj=1; //加濕控制
- ledd=1;//低速指示燈
- ledz=1;//中速指示燈
- ledg=1;//高速指示燈
- ledj=1;//加濕指示燈
- ledf=1;//負(fù)離子指示燈
- ledkq=1;//空氣質(zhì)量指示燈
- ledds=1;//定時(shí)指示燈
- qh=0; //開(kāi)機(jī)顯示空氣質(zhì)量
- TM1629B_COM(0x00);//關(guān)閉屏幕操作
- TM1629B_mie();
- qwcaiji=qwcaiji+get_ADC_qw();
- t++;
- if(t==200) //調(diào)整模擬量處理的時(shí)間間隔
- qw=qwcaiji/200; //平均濾波
- t=0;
- qwcaiji=0;
- if(qh==1) //空氣質(zhì)量與定時(shí)切換顯示
- TM_0=a%10;
- TM_2=a%100/10;
- TM_4=a/100;
- else
- TM_0=qw%10;
- TM_2=qw%100/10;
- TM_4=qw/100;
- }//while
- }//main
- void T1_time() interrupt 3 //定時(shí)、濾網(wǎng)用
- num++;
- void timer0() interrupt 1 //紅外程序用
- ir++; //一個(gè)周期ir值=0.278ms
- void int1() interrupt 2 //INT1下降沿接收紅外信號(hào)
- if(startflag)
- if(ir>42)//檢測(cè)引導(dǎo)嗎
- bitnum=0;
- irdata[bitnum]=ir;
- ir=0;
- bitnum++;
- if(bitnum==33)
- bitnum=0;
- irjsok=1;
- startflag=0;
- else
- startflag=1;
- ir=0;
- P1ASF =0x01; //選擇P1.0通道
- ADC_RES =0; //清理結(jié)果寄存器的值
- ADC_CONTR=0x80; //開(kāi)啟電源、540個(gè)時(shí)鐘、選用P1.0口
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void SC09A(void)
- if(key==0x0020)//開(kāi)關(guān)
- fmq=1;
- delay(15);
- fmq=0;
- g=~g;
- if(g==1)
- zzshu=0;
- fzshu=1000;
- else
- zzshu=1000;
- fzshu=0;
- key=0;
- if(g==1)
- if(key==0x1000)//風(fēng)速
- fmq=1;
- delay(15);
- fmq=0;
- b++;
- b=1;
- key=0;
- if(key==0x0800)//加濕
- fmq=1;
- delay(15);
- fmq=0;
- kzj=~kzj;
- key=0;
- if(key==0x0400)//負(fù)離子
- fmq=1;
- delay(15);
- fmq=0;
- ledf=~ledf;
- kzf=~kzf;
- key=0;
- if(key==0x0080)//定時(shí)
- fmq=1;
- delay(15);
- fmq=0;
- a=a+60;
- if(a>360)
- a=0;
- key=0;
- if(key==0x0040)//切換
- fmq=1;
- delay(15);
- fmq=0;
- qh=~qh;
- key=0;
- }// if(g==1)
- uchar mn=0;
- ADC_CONTR=0X88; //開(kāi)電源、開(kāi)始轉(zhuǎn)換ADC_START=1,選擇P1.0
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- while(!(ADC_CONTR&0X10)); //轉(zhuǎn)換結(jié)束ADC_FLAG=1
- mn=ADC_RES;
- ADC_CONTR&=~0X10; //ADC_FLAG清零
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- return mn;
- void int0() interrupt 0 //INT0下降沿接收SC09A
- uchar i,j,temp;
- uchar dizi=0x81;
- uint keyzhi=0xffff;
- bit bit_temp;
- EA=0; // 屏蔽全局中斷
- SCL=1;
- for(i=0;i<50;i++){} //延時(shí)
- SDA=0; // 拉低SDA,端口送出START 信號(hào)
- for(j=0;j<8;j++)//發(fā)送8位地址
- SCL=0;
- temp=dizi&0x80;
- if(temp==0x80)
- SDA=1;
- else
- SDA=0;
- dizi=dizi<<1;
- SCL=1;
- SDA=1; //釋放SDA 端口,將SDA設(shè)置為輸入端口
- SCL=0;
- SCL=1;
- //此處讀ack回應(yīng),不做處理
- //讀16位按鍵數(shù)據(jù)
- for(j=0;j<16;j++)
- SCL=0;
- SCL=1;
- bit_temp=SDA;
- if(bit_temp)
- keyzhi=keyzhi<<1;
- keyzhi=keyzhi|0x01;
- else
- keyzhi=keyzhi<<1;
- SCL=0;
- SDA=1;
- SCL=1;
- SCL=0;
- SDA=0; //發(fā)送 NACK 信號(hào)
- SCL=1;
- SDA=1; //結(jié)束
- key=keyzhi^0xffff;//異或
- EA=1; //全局中斷使能
- CIN0 0x1000 S1風(fēng)速
- CIN1 0x0800 S2加濕
- CIN2 0x0400 S3負(fù)離子
- CIN5 0x0080 S4定時(shí)
- CIN6 0x0040 S5切換
- CIN7 0x0020 S6開(kāi)關(guān)
