查看: 25165|回復: 13
基于C語言的51單片機直線圓弧插補程序
ID:77496 發表于 2015-5-9 17:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
經過幾天的鉆研和調試,終于在51單片機上實現了二軸聯動,通過調用line(x1,y1,x2,y2,v)函數以及cytu(x1,y1,x2,a,b,r,v)和cyao(x1,y1,x2,a,b,r,v)三個命令便可實現任意圓弧和直線的插補,注意任意二字,比如直線命令,可以是水平線可以是豎直線,可以是從左往右也可從右往左,可以當做一個繪圖儀使用,如果愿意進一步升級,簡單修改加個Z軸做成數控銑床的控制器亦未嘗不可。下面是整個源程序,有興趣的可以參考參考。
#include <REG51.h>
#include <FLOAT.h>
#include <MATH.h>
sbit mai0=P1^0;
sbit mai1=P1^1;
sbit shuru=P0^0;
sbit dir0=P1^6;
sbit dir1=P1^7;
void delay(unsigned int t){
         unsigned int g;
                      while(t!=0){
                       for(g=0;g++;g<600);
           t--;
void mc_p0(signed long m0,unsigned int n0)
                       {if(m0<0){
               m0=-m0;
         dir0=1;
      else{dir0=0;}
      while(m0--!=0){
                     mai0=0;
                     delay(n0/2);
            mai0=1;
            delay(n0/2);
void mc_p1(signed long m1,unsigned int n1)
                       {if(m1<0){
               m1=-m1;
         dir1=1;
      else{dir1=0;}
      while(m1--!=0){mai1=0;
                     delay(n1/2);
            mai1=1;
            delay(n1/2);
void line(float x0,float y0,float x1,float y1,unsigned int v0){
     float k=0;
     float x=0;
     float y=0;
     float ys=0;
     signed long yc=0;
     x=x0;
     ys=y0;
     k=(y1-y0)/(x1-x0);
     if(x0==x1){
                mc_p1((y1-y0)*2,50000/v0);}
     if(y0==y1){
                mc_p0((x1-x0)*2,50000/v0);}
     if((x0!=x1)&&(y0!=y1)){
       if(x0<x1){    while(x<x1){
              mc_p0(2,50000/v0);
        x=x+1;
        y=k*(x-x1)+y1;
        yc=y-ys;
        ys=y;
        mc_p1(yc*2,50000/v0);
       if(x0>x1){    while(x>x1){
              mc_p0(-2,50000/v0);
        x=x-1;
        y=k*(x-x1)+y1;
        yc=y-ys;
        ys=y;
void cytu(float x3,float y3,float x4,float a1,float b1,
          float r1,unsigned int v1){
                float xx;
          float yy;
          float yys;
          signed int yyc;
    xx=x3;
    yys=y3;
    if(x3<x4){
        while(xx<x4){
              mc_p0(2,50000/v1);
        xx=xx+1;
        yy=b1+sqrt(r1*r1-(xx-a1)*(xx-a1));
        yyc=yy-yys;
        yys=yy;
        mc_p1(yyc*2,50000/v1);
     if(x3>x4){
        while(xx>x4){
              mc_p0(-2,50000/v1);
        xx=xx-1;
        yyc=yy-yys;
        yys=yy;
void cyao(float x5,float y5,float x6,float a2,float b2,
          float r2,unsigned int v2){
                float xxx;
          float yyy;
          float yyys;
          signed int yyyc;
    xxx=x5;
    yyys=y5;
    if(x5<x6){
        while(xxx<x6){
              mc_p0(2,50000/v2);
        xxx=xxx+1;
        yyy=b2-sqrt(r2*r2-(xxx-a2)*(xxx-a2));
        yyyc=yyy-yyys;
        yyys=yyy;
        mc_p1(yyyc*2,50000/v2);
     if(x5>x6){
        while(xxx>x6){
              mc_p0(-2,50000/v2);
        xxx=xxx-1;
        yyyc=yyy-yyys;
        yyys=yyy;
void main (void){
                while(1){
         while(shuru==0){
       line(0,0,10,10,5); //直線命令,調用格式line(起點坐標x1,y1,終點坐標x2,y2,速度v)
       delay(100000);  //延時
       line(10,10,0,0,5);
       delay(100000);
       line(0,0,-20,0,5);
       delay(60000);
        cytu(-20,0,20,0,0,20,5); //位于本身圓心上面的圓弧命令,調用格式cytu(起點x1,y1,終點x2,圓心a,b,半徑r,速度v)
       delay(60000);
        cyao(20,0,60,40,0,20,5);  //位于本身圓心下面的圓弧命令,調用格式cyao(起點x1,y1,終點x2,圓心a,b,半徑r,速度v)
       delay(60000);
        cytu(60,0,20,40,0,20,5);
       delay(60000);
        cyao(20,0,-20,0,0,20,5); }
參與人數 1黑幣 +5 收起 理由
qgcwh + 5 很給力!
收藏收藏5 分享淘帖 頂2 踩
相關帖子
ID:81653 發表于 2015-6-18 19:53 | 只看該作者
這個是對應g代碼的?
ID:81653 發表于 2015-6-18 20:40 | 只看該作者
樓主在嗎?
ID:90474 發表于 2015-9-18 18:32 | 只看該作者
本帖最后由 yanzaihong 于 2015-9-19 11:52 編輯
樓主該程序,我遇到個問題。就是直線插補中當:如X0 = 0; Y0 = 0;  X1 = 40; Y1  = 20;  X1 的值小于Y1的值時,好像運行的不對!
ID:98031 發表于 2015-12-21 00:23 | 只看該作者
等了好久終于等到了大神
ID:168756 發表于 2017-3-7 11:33 | 只看該作者
謝謝,學習中
ID:168756 發表于 2017-3-7 11:35 | 只看該作者
hippo6 發表于 2015-6-18 19:53
**** 作者被禁止或刪除 內容自動屏蔽 ****
肯定要轉譯的,G代碼是另一回事。也是G代碼要下傳下來,由單片機再翻成運作。
ID:184537 發表于 2017-3-29 17:11 | 只看該作者
師傅 你太厲害了
ID:193180 發表于 2017-5-17 19:18 | 只看該作者
你好,有原理圖嗎?我也想做一個來玩?
ID:193180 發表于 2017-5-17 19:20 | 只看該作者
你好,我是初學者,也想做一個玩,能給張原理圖嗎,謝謝了
ID:19250 發表于 2021-10-6 07:38 | 只看該作者
感謝無私共享,你的程序很有啟發,為別人指出了一個方向。
ID:401973 發表于 2022-4-24 12:41 | 只看該作者
正在研究
ID:1026584 發表于 2022-5-30 20:56 | 只看該作者
請問這個是如何實現繪圖的呢?
ID:1030689 發表于 2022-11-24 21:46 | 只看該作者
這個正是我需要的
