- #include <AT89X52.h> //調(diào)用51單片機的頭文件
- #include <Intrins.h>
- sbit ds18b20=P3^7;
- sbit OK=P3^6;
- unsigned char TT,temp1,num,TL=20,TH=27,w,s,m,n;
- unsigned char temp,temp2,key,dat;
- unsigned char code tabcc[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0xff};//共陰極
- unsigned char code tabca[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xBF};//共陽極
- //名稱:復(fù)位DS18B20函數(shù)
- void delay(int ms)
- int i;
- while(ms--)
- for(i=0;i<120;i++);
- void disp(w,s)
- unsigned char temp=0x01;
- P0=tabca[s]; //顯示一位數(shù)據(jù)
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- P0=1<<w-1; //一位位選
- P2 =0x01;
- _nop_();
- P2 |=0x03;
- _nop_();
- delay(6);
- P0=0xff; //一位顯示完后清屏
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- void main()
- char i;
- while(1)
- TT++;
- if(TT==100)
- TT=0;
- n=TT/10;
- m=TT%10;
- for(i=0;i<20;i++)
- disp(1,m); //個位
- disp(2,n); //十位
- disp(6,10);//右杠
- disp(7,2);//區(qū)間
- disp(8,10);//左杠
- sbit OK=P3^6;
- unsigned char TT,temp1,num,TL=20,TH=27,y;
- unsigned char code tabca[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x00};//共陽極
- int i;
- while(ms--)
- void disp(void)
- P0=tabca[TT%10]; //第一位顯示數(shù)據(jù)
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- P0=0x01; //第一位位選
- P2 =0x01;
- _nop_();
- P2 |=0x03;
- _nop_();
- delay(6);
- P0=0xff; //第一位顯示數(shù)據(jù)
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- P0=tabca[TT/10]; //第二位顯示數(shù)據(jù)
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- P0=0x02; //第二位位選
- P2 =0x01;
- _nop_();
- P2 |=0x03;
- _nop_();
- delay(6);
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- void main()
- char i;
- while(1)
- TT++;
- if(TT==100)
- TT=0;
- for(i=0;i<20;i++)
- disp();
- sbit OK=P3^6;
- unsigned char code tabca[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xBF,0xFF};//共陽極
- //名稱:ms延遲
- int i;
- while(ms--)
- bit Reset(void)
- unsigned int i;
- bit k;
- ds18b20=0;
- i=95;
- while(i--);
- ds18b20=1;
- i=9;
- while(i--);
- k=ds18b20;
- i=55;
- while(i--);
- return k;
- //名稱:讀一字節(jié)函數(shù)
- unsigned char ReadByte(void)
- unsigned int i;
- unsigned char j,buf=0;
- for(j=0;j<8;j++)
- buf=buf>>1;
- ds18b20=0;
- _nop_();
- _nop_();
- ds18b20=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- if(ds18b20==1)
- buf|=0x80;
- i=7;
- while(i--);
- return buf;
- //名稱:寫一字節(jié)函數(shù)
- void WriteByte(unsigned char dat)
- unsigned int i;
- unsigned char j;
- for(j=0;j<8;j++)
- if(dat&0x01) //如果寫1
- ds18b20=0; //拉低
- _nop_(); //維持2US,符合大于1US小于15US的規(guī)范
- ds18b20=1; //拉高
- i=7; //維持約63US,符合不低于60US的要求
- while(i--); //維持約63US,符合不低于60US的要求
- else //如果寫0
- ds18b20=0; //拉低
- ds18b20=1; //拉高
- _nop_(); //維持2US,符合大于1US的規(guī)范
- dat=dat>>1; //寫入字節(jié)右移1位
- //名稱:DS18B20溫度轉(zhuǎn)換函數(shù)
- bit Convert(void)
- if(Reset()==0) //復(fù)位DS18B20成功
- WriteByte(0xcc); //寫入跳過序列號命令字 Skip Rom
- WriteByte(0x44); //寫入溫度轉(zhuǎn)換命令字 Convert T
- return 1; //啟動溫度轉(zhuǎn)換成功
- else //失敗
- return 0; //啟動溫度轉(zhuǎn)換失敗
- //名稱:轉(zhuǎn)換結(jié)束處理函數(shù)
- void ReadFlash(void)
- unsigned char Lsb,Msb;
- WriteByte(0xbe); //寫入讀取數(shù)據(jù)令字 Read Scratchpad
- Lsb=ReadByte(); //讀出第一個字節(jié)暫存于LSB
- Msb=ReadByte(); //讀出第二個字節(jié)暫存于MSB
- temp1=Lsb; //temp1內(nèi)裝溫度參數(shù)的小數(shù)部分
- temp2=Msb; //(Msb>>4)|(Lsb<<4);//temp2內(nèi)裝溫度參數(shù)的整數(shù)部分
- else
- temp1=0; //如果復(fù)位失敗,溫度參數(shù)清零
- temp2=0; //如果復(fù)位失敗,溫度參數(shù)清零
- void disp(w,s)
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- P0=1<<w-1; //一位位選
- P2 =0x01;
- _nop_();
- P2 |=0x03;
- _nop_();
- delay(4);
- P2 &=0xFC;
- _nop_();
- P2 |=0x03;
- _nop_();
- void main()
- while(1)
- if(Convert()==1);
- ReadFlash();
- TT=(temp2<<4)|(temp1>>4);
- if(TT<TL)
- num=0;
- else if(TT>TH)
- num=2;
- else //((TT>=TL)&(TT<=TH))
- num=1;
- disp(1,TT%10); //個位
- disp(2,TT/10); //十位
- disp(6,10);//右杠
- disp(7,num);//區(qū)間
- disp(8,10);//左杠
