查看: 5575|回復(fù): 1
51單片機(jī)驅(qū)動adc0804 lcd1602液晶顯示程序
ID:76127 發(fā)表于 2015-4-18 04:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar code dis0[]={"Volter(V)"};
  6. uchar code dis1[]={"dianliuA"};
  7. sbit jia=P3^4;
  8. sbit jian=P3^5;
  9. sbit lcden=P3^2;
  10. sbit lcdrs=P3^0;
  11. sbit adwr=P3^6;
  12. sbit adrd=P3^7;
  13. sbit  wr1=P3^1;
  14. uchar num;
  15. uint ad_data,ad_data1,ad_data2,ad_data3,adval,ad_data4,da,rw1;
  16. unsigned char CYCLE; //定義周期 該數(shù)字X基準(zhǔn)定時時間 如果是10 則周期是10 x 0.1ms
  17. unsigned char PWM_ON;//定義高電平時間
  18. sbit LED = P3^3;
  19. void delay(uint z)
  20. {
  21. // uint y;
  22. // for(y=110;y>0;y--);
  23.   while(z--);
  24. }
  25. key(uchar num)
  26. {if(jia==0)
  27. {delay(10);if(jia==0)
  28. {num++;
  29.      if(num==7)num=6;
  30.   while(jia==0);}
  31.    }
  32.   if(jian==0)
  33.   {delay(10);
  34.   if (jian==0)
  35.    {   if(num!=0)num--;else num=0;while(jian==0);}
  36.   }
  37.   return num;
  38. }
  39. dispose(unsigned char PWM_ON)
  40. {
  41.    switch(num)
  42.    {case 0:PWM_ON=20;break;
  43.    case 1:PWM_ON=40;break;
  44.    case 3:PWM_ON=80;break;
  45.    case 2:PWM_ON=60;break;
  46.    case 4:PWM_ON=100;break;
  47.    case 5:PWM_ON=120;break;
  48.    case 6:PWM_ON=140;break;
  49.    }
  50.    return PWM_ON;
  51.   }
  52. void dac0832()
  53. { int i;
  54. //lcden=1;delay(5);
  55. lcden=0;delay(50);
  56. wr1=1;delay(5);
  57. wr1=0;delay(50);
  58.   P2=ad_data;
  59. da=ad_data;
  60. for(i=0;i<5;i++)
  61. {
  62. if(PWM_ON>da) P2=--da;
  63. if(PWM_ON<da) P2=++da;
  64. if(PWM_ON==da)P2=da;
  65. }
  66. lcden=0;wr1=1;
  67. }
  68. /*void init0()    //初始化
  69. { TMOD =0x01;//定時器設(shè)置 0.1ms in 12M crystal
  70. TH0=(65536-100)/256;
  71. TL0=(65536-100)%256;//定時0.1mS
  72. IE= 0x82;  //打開中斷
  73. TR0=1;
  74. }
  75. void tim(void) interrupt 1 using 1
  76. {
  77. static unsigned char count; //
  78. TH0=(65536-1000)/256;
  79. TL0=(65536-1000)%256;//定時1mS
  80. if (count==PWM_ON)
  81.     {
  82.      LED = 0; //燈滅
  83.     }
  84.   count++;
  85. if(count == CYCLE)
  86.     {
  87.     count=0;
  88. if(PWM_ON!=0) //如果左右時間是0 保持原來狀態(tài)
  89.     LED =1;//燈亮
  90.     }
  91. }     */
  92. void write_com(uchar com)
  93. {
  94.   lcdrs=0;P0=com;
  95.   delay(5);
  96.   lcden=1;
  97.   delay(5);
  98.   lcden=0;
  99. }
  100. void write_data(uchar dota)
  101. {
  102.   lcdrs=1;
  103.   P0=dota;
  104.   delay(5);
  105.   lcden=1;
  106.   delay(5);
  107.   lcden=0;
  108. }
  109. void init()
  110. {
  111.   lcden=0;
  112.   write_com(0x38);
  113.   write_com(0x0c);
  114.   write_com(0x06);
  115.   write_com(0x01);
  116. }
  117. void display0()
  118. { write_com(0x80);
  119.   for(num=0;num<10;num++)
  120. {
  121.   write_data(dis0[num]);
  122.   delay(5);
  123. }
  124.   delay(5);
  125.   write_data(ad_data1+0x30);delay(1);
  126.   write_data(ad_data2+0x30);delay(1);
  127.   write_data('.');delay(1);
  128.   write_data(ad_data3+0x30);delay(1);
  129. // write_data(ad_data4+0x30);delay(2);
  130.   write_com(0x80+0x40);
  131.   for(num=0;num<8;num++)
  132. {
  133.   write_data(dis1[num]);
  134.   delay(5);}
  135. }
  136. AD0804(uint ad_data)
  137. { adwr=1;_nop_();
  138.   adwr=0;_nop_();delay(5);
  139.   adwr=1;_nop_();
  140.   P1=0xff;
  141.   adrd=1;_nop_();
  142.   adrd=0;_nop_();
  143.   ad_data=P1;
  144.   adval=ad_data;
  145.   adval=adval*100/51;
  146.   ad_data1=adval/100;
  147.   ad_data2=adval%100/10;
  148.   ad_data3=adval%100%10;
  149. // ad_data4=adval%1000%100%10;
  150. return ad_data;
  151. }
  152. void main()
  153. {   init();
  154.     ad_data=1;
  155.     ad_data1=2;
  156. LED=0;
  157. num=0;
  158. CYCLE=200;
  159. PWM_ON=100;
  160. while(1)
  161.     {LED=0;
  162. display0();
  163. AD0804(ad_data);
  164.     key(num);
  165.     dispose(PWM_ON);
  166. dac0832();
  167.     LED=1;delay(CYCLE);
  168. }
  169.
  170. }
相關(guān)帖子
ID:56948 發(fā)表于 2015-5-10 10:02 | 只看該作者
好東西,學(xué)習(xí)一下,謝謝分享!
