查看: 14064|回復: 7
51單片機控制32個LED多花樣流水燈程序
ID:76127 發表于 2015-4-17 21:11 | 顯示全部樓層 |閱讀模式
32個led燈接在51單片機的4個p口上面 剛好32個.下面是程序源碼:
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #define ushort unsigned short                       //P0,P1,P2,P3數據類型是 unsigned short  ;數值范圍 :0~~~~65 635
  4. #define uint unsigned int
  5. ushort code display_P0[]={                         //P0 口顯示內容
  6. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,           //P0--》P3逐個堆積點亮部分的P0 流水點亮
  7. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,           //P0  全滅等待
  8. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  9. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  10. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  11. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  12. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  13. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  14. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  15. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  16. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  17. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  18. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  19. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  20. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  21. 0xFF,0xFF,0xFF,0xFF,0xFF,
  22. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  23. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  24. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  25. 0xFF,0xFF,0xFF,0xFF,
  26. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  27. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  28. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  29. 0xFF,0xFF,0xFF,
  30. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  31. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  32. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  33. 0xFF,0xFF,
  34. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  35. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  36. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  37. 0xFF,
  38. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  39. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  40. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  41. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  42. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  43. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  44. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  45. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  46. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  47. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  48. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  49. 0xFF,0xFF,0xFF,0xFF,0xFF,
  50. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  51. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  52. 0xFF,0xFF,0xFF,0xFF,
  53. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  54. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  55. 0xFF,0xFF,0xFF,
  56. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  57. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  58. 0xFF,0xFF,
  59. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  60. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  61. 0xFF,
  62. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  63. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  64. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  65. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  66. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  67. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  68. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  69. 0xFF,0xFF,0xFF,0xFF,0xFF,
  70. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  71. 0xFF,0xFF,0xFF,0xFF,
  72. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  73. 0xFF,0xFF,0xFF,
  74. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  75. 0xFF,0xFF,
  76. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  77. 0xFF,
  78. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,                      //P0--》P3逐個堆積點亮部分的P0 堆積點亮
  79. 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F,
  80. 0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
  81. 0x1E,0x1D,0x1B,0x17,0x0F,
  82. 0x0E,0x0D,0x0B,0x07,
  83. 0x06,0x05,0x03,
  84. 0x02,0x01,
  85. 0x00,
  86. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                       //P0 閃爍
  87. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  88. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  89. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  90. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  91. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,                      //P0--》P3間隔點亮部分的P0 1,3,5,7 亮。2,4,6,8滅
  92. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  93. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  94. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  95. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  96. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  97. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  98. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  99. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  100. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  101. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  102. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  103. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  104. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  105. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  106. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  107. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                    //P0 閃爍
  108. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  109. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  110. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  111. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  112. 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,                    //P0--》P3從兩邊到中間逐個點亮部分的P0逐個點亮
  113. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                    //P0--》P3從兩邊到中間逐個點亮部分的P0全亮等待
  114. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  115. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  116. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                   //P0--》P3從兩邊到中間逐個熄滅部分的P0全亮等待
  117. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  118. 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,                   //P0--》P3從兩邊到中間逐個熄滅部分的P0逐個熄滅
  119. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                   //P0 閃爍//
  120. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  121. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  122. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  123. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  124. 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,                  //P0--》P3從左到右逐個點亮部分的P0逐個點亮
  125. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                  //P0--》P3從左到右逐個點亮部分的P0全亮等待
  126. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  127. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  128. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  129. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  130. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                  //P0--》P3從右到左逐個熄滅部分的P0全亮等待
  131. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  132. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  133. 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,                  //P0--》P3從右到左逐個熄滅部分的P0逐個熄滅
  134. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                  //P0 閃爍
  135. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  136. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  137. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  138. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  139. };
  140. ushort code display_P1[]={
  141. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  142. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  143. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  144. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  145. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  146. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  147. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  148. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  149. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  150. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  151. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  152. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  153. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  154. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  155. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  156. 0xFF,0xFF,0xFF,0xFF,0xFF,
  157. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  158. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  159. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  160. 0xFF,0xFF,0xFF,0xFF,
  161. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  162. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  163. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  164. 0xFF,0xFF,0xFF,
  165. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  166. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  167. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  168. 0xFF,0xFF,
  169. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  170. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  171. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  172. 0xFF,
  173. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  174. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  175. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  176. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  177. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  178. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  179. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  180. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  181. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  182. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  183. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  184. 0xFF,0xFF,0xFF,0xFF,0xFF,
  185. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  186. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  187. 0xFF,0xFF,0xFF,0xFF,
  188. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  189. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  190. 0xFF,0xFF,0xFF,
  191. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  192. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  193. 0xFF,0xFF,
  194. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  195. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  196. 0xFF,
  197. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  198. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  199. 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  200. 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F,
  201. 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
  202. 0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
  203. 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
  204. 0x1E,0x1D,0x1B,0x17,0x0F,
  205. 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
  206. 0x0E,0x0D,0x0B,0x07,
  207. 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
  208. 0x06,0x05,0x03,
  209. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  210. 0x02,0x01,
  211. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  212. 0x00,
  213. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  214. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  215. 0x00,0x00,0x00,0x00,0x00,0x00,
  216. 0x00,0x00,0x00,0x00,0x00,
  217. 0x00,0x00,0x00,0x00,
  218. 0x00,0x00,0x00,
  219. 0x00,0x00,
  220. 0x00,
  221. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  222. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  223. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  224. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  225. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  226. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  227. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  228. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  229. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  230. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  231. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  232. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  233. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  234. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  235. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  236. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  237. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  238. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  239. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  240. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  241. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  242. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  243. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  244. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  245. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  246. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  247. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  248. 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,
  249. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  250. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  251. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  252. 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
  253. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  254. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  255. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  256. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  257. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  258. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  259. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  260. 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,
  261. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  262. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  263. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  264. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  265. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  266. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  267. 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
  268. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  269. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  270. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  271. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  272. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  273. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  274. };
  275. ushort code display_P2[]={
  276. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  277. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  278. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  279. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  280. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  281. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  282. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  283. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  284. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  285. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  286. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  287. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  288. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  289. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  290. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  291. 0xFF,0xFF,0xFF,0xFF,0xFF,
  292. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  293. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  294. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  295. 0xFF,0xFF,0xFF,0xFF,
  296. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  297. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  298. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  299. 0xFF,0xFF,0xFF,
  300. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  301. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  302. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  303. 0xFF,0xFF,
  304. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  305. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  306. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  307. 0xFF,
  308. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  309. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  310. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  311. 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  312. 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  313. 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F,
  314. 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
  315. 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
  316. 0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
  317. 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
  318. 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
  319. 0x1E,0x1D,0x1B,0x17,0x0F,
  320. 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
  321. 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
  322. 0x0E,0x0D,0x0B,0x07,
  323. 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
  324. 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
  325. 0x06,0x05,0x03,
  326. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  327. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  328. 0x02,0x01,
  329. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  330. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  331. 0x00,
  332. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  333. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  334. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  335. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  336. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  337. 0x00,0x00,0x00,0x00,0x00,0x00,
  338. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  339. 0x00,0x00,0x00,0x00,0x00,
  340. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  341. 0x00,0x00,0x00,0x00,
  342. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  343. 0x00,0x00,0x00,
  344. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  345. 0x00,0x00,
  346. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  347. 0x00,
  348. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  349. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  350. 0x00,0x00,0x00,0x00,0x00,0x00,
  351. 0x00,0x00,0x00,0x00,0x00,
  352. 0x00,0x00,0x00,0x00,
  353. 0x00,0x00,0x00,
  354. 0x00,0x00,
  355. 0x00,
  356. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  357. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  358. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  359. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  360. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  361. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  362. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  363. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  364. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  365. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  366. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  367. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  368. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  369. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  370. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  371. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  372. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  373. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  374. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  375. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  376. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  377. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  378. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  379. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  380. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  381. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  382. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  383. 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,
  384. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  385. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  386. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  387. 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,
  388. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  389. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  390. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  391. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  392. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  393. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  394. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  395. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  396. 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,
  397. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  398. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  399. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  400. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  401. 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
  402. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  403. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  404. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  405. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  406. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  407. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  408. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  409. };
  410. ushort code display_P3[]={
  411. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  412. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  413. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  414. 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
  415. 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  416. 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  417. 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  418. 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F,
  419. 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
  420. 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
  421. 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
  422. 0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
  423. 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
  424. 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
  425. 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
  426. 0x1E,0x1D,0x1B,0x17,0x0F,
  427. 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
  428. 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
  429. 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
  430. 0x0E,0x0D,0x0B,0x07,
  431. 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
  432. 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
  433. 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
  434. 0x06,0x05,0x03,
  435. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  436. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  437. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  438. 0x02,0x01,
  439. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  440. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  441. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  442. 0x00,
  443. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  444. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  445. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  446. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  447. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  448. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  449. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  450. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  451. 0x00,0x00,0x00,0x00,0x00,0x00,
  452. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  453. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  454. 0x00,0x00,0x00,0x00,0x00,
  455. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  456. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  457. 0x00,0x00,0x00,0x00,
  458. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  459. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  460. 0x00,0x00,0x00,
  461. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  462. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  463. 0x00,0x00,
  464. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  465. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  466. 0x00,
  467. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  468. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  469. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  470. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  471. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  472. 0x00,0x00,0x00,0x00,0x00,0x00,
  473. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  474. 0x00,0x00,0x00,0x00,0x00,
  475. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  476. 0x00,0x00,0x00,0x00,
  477. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  478. 0x00,0x00,0x00,
  479. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  480. 0x00,0x00,
  481. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  482. 0x00,
  483. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  484. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  485. 0x00,0x00,0x00,0x00,0x00,0x00,
  486. 0x00,0x00,0x00,0x00,0x00,
  487. 0x00,0x00,0x00,0x00,
  488. 0x00,0x00,0x00,
  489. 0x00,0x00,
  490. 0x00,
  491. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  492. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  493. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  494. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  495. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  496. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  497. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  498. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  499. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  500. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  501. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  502. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  503. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  504. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  505. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  506. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  507. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  508. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  509. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  510. 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
  511. 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
  512. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  513. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  514. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  515. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  516. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  517. 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,
  518. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  519. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  520. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  521. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  522. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  523. 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,
  524. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  525. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  526. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  527. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  528. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  529. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  530. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  531. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  532. 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,
  533. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  534. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  535. 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
  536. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  537. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  538. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  539. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  540. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  541. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  542. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  543. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  544. };
  545. void delayms(uint ms)                                //延時子程序
  546. {
  547.   ushort k;
  548.   while(ms--)
  549.   {
  550.     for(k = 0; k < 50; k++);
  551.   }
  552. }
  553. void main(void)                                     //P0---》P3 初始狀態
  554. {
  555.   ushort i;
  556.   P0 = 0xff;
  557.   P1 = 0xff;
  558.   P2 = 0xff;
  559.   P3 = 0xff;
  560.
  561.   while(1)                                         //定義P0,P1,P2,P3,
  562.    for(i=0;i <946; i++)
  563.     {
  564.       P0 =display_P0[i];
  565.       P1 =display_P1[i];
  566.       P2 =display_P2[i];
  567.       P3 =display_P3[i];
  568.       delayms(50);
  569.     }
  570. }
ID:76273 發表于 2015-4-24 19:06 | 顯示全部樓層
不錯挺好的
ID:77945 發表于 2015-4-24 21:04 | 顯示全部樓層
樓主  好好
ID:77965 發表于 2015-4-24 23:03 | 顯示全部樓層
感謝分享
ID:82807 發表于 2015-6-12 18:08 | 顯示全部樓層
  你能把電路圖 和 程序發給我么
ID:74408 發表于 2015-6-21 19:59 | 顯示全部樓層
求電路圖
ID:107657 發表于 2016-3-19 10:37 | 顯示全部樓層
這是什么意思呀
Build target '目標 1'
compiling xx.c...
linking...
BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
"xx.obj"
TO "xx"
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 1E57H BYTE (379%) *
Program Size: data=11.0 xdata=0 code=7782
LINK/LOCATE RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
    MODULE:  E:\\C51\LIB\C51S.LIB (-----)
    LIMIT:   0800H BYTES
目標未創建
ID:109676 發表于 2016-3-19 13:21 | 顯示全部樓層
不錯,贊一個
