只需一步,快速開(kāi)始
查看: 6940|回復(fù): 2
stc單片機(jī)PCA擴(kuò)展外部中斷程序
ID:26188 發(fā)表于 2015-2-18 01:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
10.4.用PCA功能擴(kuò)展外部中斷的示例程序(C程序和匯編程序)
1.  C程序:
/* --- STC MCU Limited ---------------- ---------------------------------------*/
/* --- 演示 STC 1T 系列單片機(jī) 用PCA功能擴(kuò)展外部中斷 -----------*/
/* --- Mobile: (86)13922809991 -----------------------------------------------*/
/* --- Fax: 86-755-82905966 ---------------------------------------------------*/
/* --- Tel: 86-755-82948412 ----------------------------------------------------*/
/* --- Web:-----------------------------------------------*/
/* 如果要在程序中使用或在文章中引用該程序, -------------------- ---*/
/* 請(qǐng)?jiān)诔绦蛑谢蛭恼轮凶⒚魇褂昧薙TC的資料及程序 -----------*/
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the PCA */
sfr    CCON     =   0xD8;     //PCA control register
sbit   CCF0     =   CCON^0;   //PCA module-0 interrupt flag
sbit   CCF1     =   CCON^1;   //PCA module-1 interrupt flag
sbit   CR       =   CCON^6;   //PCA timer run control bit
sbit   CF       =   CCON^7;   //PCA timer overflow flag
sfr    CMOD     =   0xD9;     //PCA mode register
sfr    CL       =   0xE9;     //PCA base timer LOW
sfr    CH       =   0xF9;     //PCA base timer HIGH
sfr    CCAPM0   =   0xDA;     //PCA module-0 mode register
sfr    CCAP0L   =   0xEA;     //PCA module-0 capture register LOW
sfr    CCAP0H   =   0xFA;     //PCA module-0 capture register HIGH
sfr    CCAPM1   =   0xDB;     //PCA module-1 mode register
sfr    CCAP1L   =   0xEB;     //PCA module-1 capture register LOW
sfr    CCAP1H   =   0xFB;     //PCA module-1 capture register HIGH
sfr    PCAPWM0  =   0xf2;
sfr    PCAPWM1  =   0xf3;
sbit   PCA_LED  =   P1^0;     //PCA test LED
void PCA_isr() interrupt 7 using 1
      CCF0 = 0;                         //Clear interrupt flag
      PCA_LED = !PCA_LED;               //toggle the test pin while CEX0(P1.3) have a falling edge
      CCON = 0;                         //Initial PCA control register
                                        //PCA timer stop running
                                        //Clear CF flag
                                        //Clear all module interrupt flag
      CL = 0;                           //Reset PCA base timer
      CH = 0;
      CMOD = 0x00;                      //Set PCA timer clock source as Fosc/12
                                        //Disable PCA timer overflow interrupt
      CCAPM0 = 0x11;                    //PCA module-0 capture by a negative tigger on CEX0(P1.3)
                                        //and enable PCA interrupt
      //CCAPM0 = 0x21;                    //PCA module-0 capture by a rising edge on CEX0(P1.3)
      //CCAPM0 = 0x31;                    //PCA module-0 capture by a transition (falling/rising edge)
                                          //on CEX0(P1.3) and enable PCA interrupt
      CR = 1;                           //PCA timer start run
      EA = 1;
      while (1);
10.5.用PCA功能實(shí)現(xiàn)定時(shí)器的示例程序(C程序和匯編程序)
1.  C程序:
/* --- 演示 STC 1T 系列單片機(jī) 用PCA功能實(shí)現(xiàn)16位定時(shí)器 --------*/
#include "reg51.h"
#define   FOSC     18432000L
#define   T100Hz   (FOSC / 12 / 100)
sfr   PCAPWM0       =   0xf2;
sfr   PCAPWM1       =   0xf3;
BYTE   cnt;
WORD   value;
      CCAP0L = value;
  CCAP0H = value >> 8;                //Update compare value
      value += T100Hz;
      if (cnt-- == 0)
            cnt = 100;                      //Count 100 times
            PCA_LED = !PCA_LED;           //Flash once per second
                                            //Clear CF flag
      CH = 0;
      value = T100Hz;
      CCAP0L = value;
  CCAP0H = value >> 8;                //Initial PCA module-0
      value += T100Hz;
      CCAPM0 = 0x49;                       //PCA module-0 work in 16-bit timer mode
      EA = 1;
      cnt = 0;
      while (1);
10.6.PCA輸出高速脈沖的示例程序(C程序和匯編程序)
1.  C程序:
/* --- 演示 STC 1T 系列單片機(jī) PCA輸出高速脈沖 --------------------*/
#include "reg51.h"
#define   T100KHz (FOSC / 4 / 100000)
sfr   PCAPWM0       =   0xf2;
sfr   PCAPWM1       =   0xf3;
BYTE   cnt;
WORD   value;
void PCA_isr( ) interrupt 7 using 1
      CCAP0L = value;
      value += T100KHz;
                                          //Clear CF flag
      CH = 0;
      CMOD = 0x02;                        //Set PCA timer clock source as Fosc/2
      value = T100KHz;
      CCAP0L = value;                     //P1.3 output 100KHz square wave
      value += T100KHz;
      CCAPM0 = 0x4d;                     //PCA module-0 work in 16-bit timer mode
          //and enable PCA interrupt, toggle the output pin CCP0(P1.3)
      EA = 1;
      cnt = 0;
      while (1);
10.7.PCA輸出PWM的示例程序(C程序和匯編程序)
1.  C程序:
/* --- 演示 STC 1T 系列單片機(jī) PCA輸出PWM -------------------------*/
/* --- Web: www.STCMCU.com -----------------------------------------------*/
#include "reg51.h"
sfr   PCAPWM0       =   0xf2;
sfr   PCAPWM1       =   0xf3;
                                          //Clear CF flag
      CH = 0;
      CCAP0H = CCAP0L = 0x80;           //PWM0 port output 50% duty cycle square wave
      CCAPM0 = 0x42;                     //PCA module-0 work in 8-bit PWM mode
          //and no PCA interrupt
      CCAP1H = CCAP1L = 0xff;           //PWM1 port output 0% duty cycle square wave
      PCAPWM1 = 0x03;
      CCAPM1 = 0x42;                     //PCA module-1 work in 8-bit PWM mode
    while (1);
相關(guān)帖子
ID:748788 發(fā)表于 2021-1-19 17:01 | 只看該作者
逐一測(cè)試了4個(gè)程序,前三個(gè)沒(méi)有任何反應(yīng),最后一個(gè)P1.3輸出窄脈沖、P1.4輸出寬脈沖
ID:376438 發(fā)表于 2019-3-23 15:56 | 只看該作者
謝謝!學(xué)習(xí)了
