是用51hei單片機開發(fā)板 電路圖詳見:http://www.raoushi.com/f/51hei-5.pdf 的數(shù)碼管部分, 用2個74hc573 鎖存,p0口作為數(shù)據(jù)口 ,p3.6和p3.7分別是段和位的鎖存端口.P2口上面是按鍵- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit D=P3^6;
- sbit V=P3^7;
- uchar ACT[4]={0xfe,0xfd,0xfb,0xf7};
- void sum(uint *q,uint n)
- uint i,s;
- uint *t;
- t=q;
- for(i=0;i<n;i++)s=s+*(t+i);
- t=q+10;
- *t=s;
- void delay(uint k)
- uint i,j;
- for(i=0;i<k;i++){
- for(j=0;j<121;j++)
- void main(void)
- uint a[11]={0,1,2,3,4,5,6,7,8,9,0};
- uint *pt,len=10;
- pt=a;
- sum(a,len);
- while(1)
- D=1;P0=SEG7[a[10]/1000];D=0;P0=0xff;V=1;P0=ACT[0];V=0;delay(5);
- D=1;P0=SEG7[(a[10]/100)%10];D=0;P0=0xff;V=1;P0=ACT[1];V=0;delay(5);
- D=1;P0=SEG7[(a[10]/10)%10];D=0;P0=0xff;V=1;P0=ACT[2];V=0;delay(5);
- D=1;P0=SEG7[a[10]%10];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay(5);
