查看: 2514|回復: 1
單片機條件語句實驗
ID:72519 發表于 2015-1-21 22:59 | 顯示全部樓層 |閱讀模式
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit KEY_S1=P2^4;
  5. //==============
  6.   void delay(uint k)
  7. {
  8. uint i,j;
  9. for(i=0;i<k;i++){
  10. for(j=0;j<121;j++)
  11. {;}}
  12. }
  13. //==============
  14. void main(void)
  15. {
  16.   delay(50);
  17.   while(1)
  18.   {
  19.   if(!KEY_S1){P1=0x00;}
  20.   else {P1=0xff;}
  21.   delay(5);
  22.       }
  23. }
#include<reg52.h>
sbit KEY_S1=P2^4;
sbit KEY_S2=P2^5;
sbit KEY_S3=P2^6;
sbit KEY_S4=P2^7;
  void delay(uint k)
uint i,j;
for(i=0;i<k;i++){
for(j=0;j<121;j++)
void main(void)
  delay(50);
   if(!KEY_S1){P1=0xfc;}
  else if(!KEY_S2){P1=0xf3;}
   else if(!KEY_S3){P1=0xcf;}
   else if(!KEY_S4){P1=0x3f;}
   else {P1=0xff;}
   delay(5);
