為了給集訓隊的學生訓練,購買了一些電子套件
其中包括這個老李的搖搖棒。呵呵,由于老李的程序原來只提供HEX文件,后來拿到了匯編文件,但是匯編的程序要換個內容比較麻煩,所以就自己寫了個C的程序。如下:
- <span style="line-height: 1.5;">#include <reg51.h>//寄存器預定義</span>
- sbit kaiguan=P3^5;//水銀開關,用于檢測是否甩到左邊
- sbit genghuan=P3^0;//內容更換按鈕,按下按鈕更換顯示內容
- unsigned char linshi,jishu,index;//臨時變量,掃描計數變量,內容變量
- unsigned char *DISP;//顯示指針,該指針指向不同的地址,則顯示不同的內容
- //以下點陣數據使用字模3軟件制作,縱向取模,字節正序,反色
- unsigned char code index1[]={中國歐軟4457430
- ; 源文件 / 文字 : ★■
- ; 寬×高(像素): 36×12
- 0xFF,0xE3,0xC1,0xC1,0xC0,0xE0,0xE0,0xC0,0xC1,0xC1,0xE3,0xFF,0xF7,0xF3,0xF3,0xF0,
- 0xC0,0x00,0xC0,0xF0,0xF3,0xF3,0xF7,0xFF,0xFF,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xD0,0x30,0x70,0x70,0xF0,0x70,0x70,0x30,0xD0,0xF0,0xF0,0xF0,0x30,0x30,0x30,
- 0x30,0x30,0x30,0x30,0x30,0x30,0xF0,0xF0,
- };中國歐軟4457430
- unsigned char code index2[]={
- ; 源文件 / 文字 : I心U
- ; 寬×高(像素): 36×12
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xDF,0xC0,0xDF,0xDF,0xFF,0xFF,0xE3,0xC1,0xC1,
- 0xC0,0xE0,0xE0,0xC0,0xC1,0xC1,0xE3,0xFF,0xDF,0xC0,0xFF,0xFF,0xC0,0xDF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xB0,0xB0,0x30,0xB0,0xB0,0xF0,
- 0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0xB0,0xB0,
- 0x70,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- };中國歐軟4457430
- unsigned char code index3[]={
- ; 源文件 / 文字 : 笑臉
- ; 寬×高(像素): 36×12
- 0xFF,0xF0,0xEF,0xDC,0xB7,0xBF,0xBF,0xB7,0xDC,0xEF,0xF0,0xFF,0xFF,0xF0,0xEF,0xDC,
- 0xB7,0xBF,0xBF,0xB7,0xDC,0xEF,0xF0,0xFF,0xFF,0xF0,0xEF,0xDC,0xB7,0xBF,0xBF,0xB7,
- 0xDC,0xEF,0xF0,0xFF,0xF0,0xF0,0x70,0xB0,0x50,0x50,0x50,0x50,0xB0,0x70,0xF0,0xF0,
- 0xF0,0xF0,0x70,0xB0,0x50,0x50,0x50,0x50,0xB0,0x70,0xF0,0xF0,0xF0,0xF0,0x70,0xB0,
- 0x50,0x50,0x50,0x50,0xB0,0x70,0xF0,0xF0,
- };中國歐軟4457430
- unsigned char code index4[]={
- ; 源文件 / 文字 : (@﹏@)
- ; 寬×高(像素): 36×12
- 0xFF,0xFF,0xFF,0xE0,0xDF,0xBF,0xE0,0xDF,0xD8,0xD6,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0xDF,0xD8,0xD6,0xE0,0xFF,0xFF,0xBF,
- 0xDF,0xE0,0xFF,0xFF,0xF0,0xF0,0xF0,0x70,0xB0,0xD0,0x70,0xB0,0xB0,0xB0,0xB0,0xF0,
- 0xD0,0xB0,0xB0,0xB0,0xD0,0xD0,0xB0,0xB0,0xD0,0xD0,0xB0,0xF0,0x70,0xB0,0xB0,0xB0,
- 0xB0,0xF0,0xF0,0xD0,0xB0,0x70,0xF0,0xF0,
- unsigned char code index5[]={
- ; 源文件 / 文字 : 答對了
- ; 寬×高(像素): 36×12中國歐軟4457430
- 0xED,0xDD,0x3A,0x92,0xAA,0xAA,0x92,0x3A,0x9A,0xAD,0xBD,0xFF,0xBF,0xAF,0xB6,0xB9,
- 0x86,0xEF,0xEB,0xEC,0xEF,0x00,0xEF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0x60,0x6F,0x5F,
- 0x3F,0x7F,0xFF,0xFF,0xF0,0xF0,0x10,0xD0,0xD0,0xD0,0xD0,0xD0,0x10,0xF0,0xF0,0xF0,
- 0xB0,0x70,0xF0,0xF0,0x30,0xF0,0xF0,0xD0,0xD0,0x10,0xF0,0xF0,0xF0,0xF0,0xF0,0xD0,
- 0xD0,0x10,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- unsigned char code index6[]={中國歐軟4457430
- ; 源文件 / 文字 : 你是豬
- ; 寬×高(像素): 36×12
- 0xF7,0xEF,0xC0,0x37,0xEE,0x99,0x5F,0xD0,0xDF,0xD9,0xCE,0xFF,0xFD,0xFD,0xFC,0x05,
- 0x55,0x54,0x55,0x55,0x05,0xFD,0xFD,0xFF,0x76,0xAD,0xC0,0x37,0xD6,0xD4,0x01,0xD5,
- 0xC5,0x94,0xF7,0xFF,0xF0,0xF0,0x10,0x70,0xF0,0xD0,0xD0,0x10,0xF0,0xF0,0x70,0xF0,
- 0xD0,0xB0,0x70,0x70,0xB0,0x10,0x50,0x50,0x50,0x50,0xD0,0xF0,0xD0,0xD0,0x30,0x70,
- 0xF0,0x10,0x50,0x50,0x50,0x10,0xF0,0xF0,
- unsigned char code index7[]={
- ; 源文件 / 文字 : 我愛你
- ; 寬×高(像素): 36×12
- 0xAE,0xAE,0xAD,0x80,0x6D,0xEB,0x01,0xEE,0x6D,0xAB,0xEF,0xFF,0xE7,0xAB,0xAB,0x8B,
- 0xA0,0x8A,0x6A,0x4A,0x2A,0x6B,0xE7,0xFF,0xF7,0xEF,0xC0,0x37,0xEE,0x99,0x5F,0xD0,
- 0xDF,0xD9,0xCE,0xFF,0xF0,0xD0,0xD0,0x10,0xB0,0xB0,0x70,0x70,0xB0,0xD0,0x10,0xF0,
- 0xD0,0xD0,0xB0,0x50,0x50,0xB0,0xB0,0x50,0xD0,0xD0,0xD0,0xF0,0xF0,0xF0,0x10,0x70,
- 0xF0,0xD0,0xD0,0x10,0xF0,0xF0,0x70,0xF0,
- };中國歐軟4457430
- unsigned char code index8[]={
- ; 源文件 / 文字 : 好喜歡
- ; 寬×高(像素): 36×12
- 0xDC,0xC2,0x1F,0xDC,0xC3,0x7B,0x7B,0x60,0x5B,0x3B,0xFB,0xFF,0xBE,0xBE,0xA2,0xAA,
- 0xA8,0x0A,0xAA,0xA8,0xA2,0xBE,0xBE,0xFF,0xAF,0xB6,0xB9,0x86,0xBF,0xE7,0x1E,0xD1,
- 0xDE,0xD7,0xCF,0xFF,0xD0,0xB0,0x70,0x70,0xB0,0xF0,0xD0,0x10,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0x10,0xD0,0xD0,0xD0,0xD0,0xD0,0x10,0xF0,0xF0,0xF0,0xB0,0x70,0xF0,0xD0,
- 0x50,0xB0,0x70,0xF0,0x70,0xB0,0xD0,0xF0,
- };中國歐軟4457430
- unsigned char code index9[]={
- ; 源文件 / 文字 : √√√
- ; 寬×高(像素): 36×12
- 0xFF,0xFF,0xFE,0xFD,0xFE,0xFF,0xFE,0xF1,0x8F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,
- 0xFE,0xFF,0xFE,0xF1,0x8F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFE,0xFF,0xFE,0xF1,
- 0x8F,0xFF,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0x30,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0x30,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0x70,0x30,0xF0,0xF0,0xF0,0xF0,0xF0,
- };中國歐軟4457430
- unsigned char code index10[]={
- ; 源文件 / 文字 : ×××
- 0xFF,0xFF,0xDF,0xEE,0xF5,0xFB,0xF5,0xEE,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xEE,
- 0xF5,0xFB,0xF5,0xEE,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xEE,0xF5,0xFB,0xF5,0xEE,
- 0xDF,0xFF,0xFF,0xFF,0xF0,0xF0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,0x70,0xF0,
- 0xF0,0xF0,0xF0,0xF0,0x70,0xF0,0xF0,0xF0,
- unsigned char code index11[]={
- ; 源文件 / 文字 : 笑臉中國歐軟4457430
- ; 寬×高(像素): 36×12
- 0xFF,0xF0,0xE0,0xC3,0x88,0x80,0x80,0x88,0xC3,0xE0,0xF0,0xFF,0xFF,0xF0,0xE0,0xC3,
- 0x88,0x80,0x80,0x88,0xC3,0xE0,0xF0,0xFF,0xFF,0xF0,0xE0,0xC3,0x88,0x80,0x80,0x88,
- 0xC3,0xE0,0xF0,0xFF,0xF0,0xF0,0x70,0x30,0x90,0x90,0x90,0x90,0x30,0x70,0xF0,0xF0,
- 0xF0,0xF0,0x70,0x30,0x90,0x90,0x90,0x90,0x30,0x70,0xF0,0xF0,0xF0,0xF0,0x70,0x30,
- 0x90,0x90,0x90,0x90,0x30,0x70,0xF0,0xF0,
- unsigned char code index12[]={
- ; 源文件 / 文字 : %>_<%中國歐軟4457430
- ; 寬×高(像素): 36×12
- 0xFF,0xFF,0xFF,0xE7,0xDB,0xE4,0xF2,0xCD,0xFE,0xFF,0xBF,0xDF,0xEE,0xF5,0xFB,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xF5,0xEE,0xDF,0xBF,0xE7,0xDB,0xE4,0xF2,0xCD,
- 0xFE,0xFF,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0x30,0xF0,0x70,0xB0,0x70,0xF0,0xB0,0x70,
- 0xF0,0xF0,0xF0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xF0,0xF0,0xF0,0xF0,0x70,0xB0,0xF0,
- 0x30,0xF0,0x70,0xB0,0x70,0xF0,0xF0,0xF0,
- unsigned char code index13[]={
- ; 源文件 / 文字 : I?U
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xDF,0xC0,0xDF,0xDF,0xFF,0xFF,0xC7,0xB9,0x7E,
- 0x7F,0xBF,0xDF,0xBF,0x7F,0x7E,0xB9,0xC7,0xFF,0x80,0x80,0xFF,0xFF,0xFF,0x80,0x80,
- 0xF0,0xF0,0xF0,0xF0,0x70,0xB0,0xD0,0xB0,0x70,0xF0,0xF0,0xF0,0xF0,0x70,0x30,0xB0,
- 0xB0,0xB0,0x30,0x70,0xF0,0xF0,0xF0,0xF0,
- unsigned char code index14[]={
- ; 源文件 / 文字 : 音樂
- ; 寬×高(像素): 36×12
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0xCF,0xE7,0xF0,0xFF,0xFF,0xFF,0xFE,0x80,
- 0x9F,0x9F,0xCF,0xC0,0xFF,0xFF,0xFF,0xFF,0xC0,0xDB,0xB7,0xB7,0x6F,0x6E,0x00,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0xF0,0x90,0x10,0x30,0xF0,0x70,0xF0,0xF0,
- 0xF0,0x30,0x30,0x70,0xF0,0x90,0x10,0x30,0xF0,0xF0,0x90,0x10,0x30,0xF0,0xF0,0xF0,
- 0x30,0x30,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,
- };中國歐軟4457430
- unsigned char code index15[]={
- ; 源文件 / 文字 : 我≠你
- ; 寬×高(像素): 36×12
- 0xAE,0xAE,0xAD,0x80,0x6D,0xEB,0x01,0xEE,0x6D,0xAB,0xEF,0xFF,0xFF,0xF5,0xF5,0xF5,
- 0xF4,0xF1,0xE5,0x95,0xF5,0xF5,0xFF,0xFF,0xF7,0xEF,0xC0,0x37,0xEE,0x99,0x5F,0xD0,
- 0xF0,0xF0,0xF0,0x30,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0x10,0x70,
- unsigned char code index16[]={
- ; 源文件 / 文字 : ㏒10=?
- 0x00,0xFF,0xF1,0xEE,0xEE,0xF1,0xFF,0xF0,0xEA,0xEA,0xD7,0xFF,0xFF,0xEF,0xC0,0xFF,
- 0xFF,0xFF,0xE0,0xDF,0xDF,0xDF,0xE0,0xFF,0xF6,0xF6,0xF6,0xF6,0xF6,0xFF,0xE7,0xDF,
- 0xDC,0xDB,0xE7,0xFF,0x30,0xB0,0xF0,0xF0,0xF0,0xF0,0x30,0xD0,0xD0,0xD0,0x30,0xF0,
- 0xF0,0xB0,0x30,0xB0,0xF0,0xF0,0x70,0xB0,0xB0,0xB0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0xF0,0xF0,0xB0,0xF0,0xF0,0xF0,
- unsigned char code index17[]={
- ; 源文件 / 文字 : 你≌豬
- 0xF7,0xEF,0xC0,0x37,0xEE,0x99,0x5F,0xD0,0xDF,0xD9,0xCE,0xFF,0xFF,0xE6,0xDA,0xDA,
- 0xFA,0xF6,0xEE,0xDE,0xDA,0xDA,0xE6,0xFF,0x76,0xAD,0xC0,0x37,0xD6,0xD4,0x01,0xD5,
- 0xF0,0xB0,0xB0,0xB0,0xB0,0xB0,0xB0,0xB0,0xB0,0xB0,0xB0,0xF0,0xD0,0xD0,0x30,0x70,
- unsigned char code index18[]={
- ; 源文件 / 文字 : √√√
- ; 寬×高(像素): 36×12
- unsigned char code index19[]={
- ; 源文件 / 文字 : 99.5℃
- 0xE3,0xDD,0xDD,0xDD,0xE0,0xFF,0xE3,0xDD,0xDD,0xDD,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xC3,0xDB,0xDB,0xDB,0xDC,0xFF,0x8F,0xAF,0x8F,0xE0,0xDF,0xBF,0xBF,0xBF,
- 0xDF,0x8E,0xFF,0xFF,0xF0,0x30,0xB0,0xB0,0x70,0xF0,0xF0,0x30,0xB0,0xB0,0x70,0xF0,
- 0xF0,0xB0,0xF0,0xF0,0xF0,0xF0,0x70,0xB0,0xB0,0xB0,0x70,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0x70,0xB0,0xB0,0xB0,0xB0,0x70,0xF0,0xF0,
- unsigned char code index20[]={
- ; 源文件 / 文字 : 囧rz=3
- ; 寬×高(像素): 36×12
- 0xFF,0x00,0x77,0x6C,0x5D,0x7D,0x7D,0x5C,0x6F,0x77,0x00,0xFF,0xFB,0xF8,0xFD,0xFB,
- 0xFB,0xFF,0xFF,0xFB,0xFA,0xF9,0xFB,0xFF,0xF6,0xF6,0xF6,0xF6,0xF6,0xFF,0xEF,0xDF,
- 0xDB,0xDB,0xE4,0xFF,0xF0,0x10,0xD0,0x10,0xD0,0xD0,0xD0,0x10,0xD0,0xD0,0x10,0xF0,
- 0xB0,0x30,0xB0,0xF0,0xF0,0xF0,0xF0,0xB0,0x30,0xB0,0xB0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0x70,0xB0,0xB0,0xB0,0x70,0xF0,中國歐軟4457430
- void delay(unsigned char dtime)//延時函數,傳遞參數為無符號字符型,傳遞的
- { //參數越大,則延時時間約長,但不能大于255.
- unsigned char temp; //函數內部使用的臨時變量
- while(dtime--) //外層循環
- while(--temp); //內層循環
- void main()
- DISP=index1;//開機后將內容指針指向第一幅畫面
- index=0;//內容變量初始化中國歐軟4457430
- while(1)
- if(!kaiguan)//是否甩到左邊
- delay(50);//由于換向時存在延時,因此延時一段時間,本延時影響顯示內容的左右位置,越大越靠右
- for(jishu=0;jishu<36;jishu++)//掃描循環,共36列數據
- linshi=DISP[jishu];//獲得高半截點陣數據
- linshi=linshi>>3;//移動位置,使之對應LED
- linshi=linshi|0xe1;//只保留D4-D1位數據
- P3=linshi;//拼合數據,點亮LED中國歐軟4457430
- linshi=linshi<<4;//移動位置,使之對應LED
- P1=0Xff;//熄滅P1口所有LED
- linshi=linshi|0x0f;//保留高四位
- P1=P1&linshi;//將高4位輸出到P1
- linshi=DISP[jishu+36];//獲得下半截點陣數據
- linshi=linshi>>4;//移位以對其LED
- linshi=linshi|0xf0;//保留低四位中國歐軟4457430
- P1=P1&linshi;//低四位輸出到P1
- delay(1);//掃描延時,本延時影響字體寬度,延時時間越長,則字體越寬
- P1=0XFF;//掃描完成,關閉LED
- P3=P3|0X1E;//掃描完成,關閉LED
- if(!genghuan)//更換內容按鈕是否按下?
- while(!genghuan);//等待按鈕松開中國歐軟4457430
- index=index+1;//指向下一內容
- if(index>19){index=0;}//判斷內容是否超界
- DISP=index*72+index1;//計算指針地址,由于每幅畫面為36列,垂直像素為12,因此每幅畫面占用72字節空間
- P1=index^0xff;//將內容號顯示在P1上的LED,便于觀察
- delay(100);//延時一段時間
- P1=0XFF;//關閉P1LED顯示
- delay(100);//延時一段時間中國歐軟4457430
- P1=0XFF;//實現內容號的閃爍顯示中國歐軟4457430
