查看: 4431|回復: 0
STM32學習手記⑨-RTC實時時鐘
ID:71259 發表于 2014-12-30 00:45 | 顯示全部樓層 |閱讀模式
#include "stm32f10x_lib.h"
#include"stdio.h"
vu32 TimeDisplay = 0;
void RCC_Configuration()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO | RCC_APB2Periph_USART1 , ENABLE);   //打開APB2外設
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);     //使能電源時鐘和備份區時鐘
void NVIC_Configuration( )
  NVIC_InitTypeDef NVIC_InitStructure;                           //定義一個中斷結構體
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQChannel;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);   //無搶占式優先級
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;    //響應優先級為0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void GPIO_Configuration()
GPIO_InitTypeDef GPIO_InitStructure;      //定義GPIO初始化結構體
//--------USART1 TX 配置為復用推挽輸出 AF_PP---------------------//
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;  //管腳位置定義,標號可以是NONE、ALL015。
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_2MHz;  //輸出速度2MHz
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;  //推挽輸出模式 Out_PP
GPIO_Init(GPIOA,&GPIO_InitStructure);  //EGPIO初始化
//--------USART1 RX 配置為浮空輸入 IN_FLOATING---------------------//
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;  //管腳位置定義
//輸入模式下配置輸出速度無意義
//GPIO_InitStructure.GPIO_Speed=GPIO_Speed_2MHz;  //輸出速度2MHz
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;  //浮空輸入 IN_FLOATING
GPIO_Init(GPIOA,&GPIO_InitStructure);   //CGPIO初始化
void USART1_Configuration( )
USART_InitTypeDef USART_InitStructure;               //串口設置恢復默認參數
USART_ClockInitTypeDef  USART_ClockInitStructure;
USART_InitStructure.USART_BaudRate = 115200;       //波特率115200
USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //字長8
USART_InitStructure.USART_StopBits = USART_StopBits_1;  //1位停止字節
USART_InitStructure.USART_Parity = USART_Parity_No;   //無奇偶校驗
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //無流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;  //打開Rx接收和Tx發送功能
USART_Init(USART1, &USART_InitStructure);   //初始化
USART_Cmd(USART1, ENABLE); //啟動串口
//-----如下語句解決第1個字節無法正確發送出去的問題-----//
USART_ClearFlag(USART1, USART_FLAG_TC);     // 清標志
void RTC_Configuration(void)
     PWR_BackupAccessCmd(ENABLE);    //取消備份區寫保護(寫保護在每次硬件復位后被使能)
BKP_DeInit();   //備份區恢復默認
RCC_LSEConfig(RCC_LSE_ON); //LSE(外部低速振蕩時鐘)打開
while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET);  //等待LSE準備就緒
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);    //LSE作為RTC時鐘
RCC_RTCCLKCmd(ENABLE);   //RTC時鐘打開
RTC_WaitForSynchro();  //等待RTC寄存器同步
RTC_WaitForLastTask();  //RTC任何寄存器的操作,都必須在前一次寫操作完成后執行
RTC_ITConfig(RTC_IT_SEC, ENABLE);    //使能 秒中斷
RTC_SetPrescaler(32767);   //RTC時鐘分頻  32.768K/(32767+1)=1Hz
u8 USART_Scanf(u32 value)
  u32 index = 0;
  u32 tmp[2] = {0, 0};
  while(index < 2)
    /* Loop until RXNE = 1 */
    while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
    tmp[index++] = (USART_ReceiveData(USART1));
    if((tmp[index - 1] < 0x30) || (tmp[index - 1] > 0x39))
      printf("\n\rPlease enter valid number between 0 and 9");
      index--;
  /* Calculate the Corresponding value */
  index = (tmp[1] - 0x30) + ((tmp[0] - 0x30) * 10);
  /* Checks */
  if(index > value)
    printf("\n\rPlease enter valid number between 0 and %d", value);
    return 0xFF;
  return index;
u32 Time_Regulate(void)
  u32 Tmp_HH = 0xFF, Tmp_MM = 0xFF, Tmp_SS = 0xFF;
  printf("\r\n==============Time Settings=====================================");
  printf("\r\n  Please Set Hours");
  while(Tmp_HH == 0xFF)
    Tmp_HH = USART_Scanf(23);
  printf(":  %d", Tmp_HH);
  printf("\r\n  Please Set Minutes");
  while(Tmp_MM == 0xFF)
    Tmp_MM = USART_Scanf(59);
  printf(":  %d", Tmp_MM);
  printf("\r\n  Please Set Seconds");
  while(Tmp_SS == 0xFF)
    Tmp_SS = USART_Scanf(59);
  printf(":  %d", Tmp_SS);
  /* Return the value to store in RTC counter register */
  return((Tmp_HH*3600 + Tmp_MM*60 + Tmp_SS));
void Time_Adjust(void)
  RTC_SetCounter(Time_Regulate());  //設置計數值
void Time_Display(u32 TimeVar)
  u32 THH = 0, TMM = 0, TSS = 0;
  THH = TimeVar/3600; //計算小時
  TMM = (TimeVar % 3600)/60;//計算分
  TSS = (TimeVar % 3600)% 60; //計算秒
  printf("Time: %0.2d:%0.2d:%0.2d\r\n",THH, TMM, TSS);
void Time_Show(void)
  while(1)  //infinite loop
    if(TimeDisplay == 1)  //if 1s has passed
      Time_Display(RTC_GetCounter()); //display current time
      TimeDisplay = 0;
int fputc(int ch, FILE *f)    //在源代碼中添加fputc函數,可以用printf函數做為調試輸出
  /* Printf內容發往串口 */
  USART_SendData(USART1, (u8) ch);
  /* 循環,直到傳送完成 */
  while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
  return ch;
int main()
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration( );
USART1_Configuration();
if (BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5){   //檢查是否第一次配置RTC
printf("\r\n\n RTC not yet configured....");
  RTC_Configuration();
  printf("\r\n RTC configured....");
  Time_Adjust();
  BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
else{
if(RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET)   //檢查是否是上電復位
printf("\r\n\n Power On Reset occurred....");
else if(RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET)  //檢查是否是復位腳復位
printf("\r\n\n External Reset occurred....");
printf("\r\n No need to configure RTC....");
RCC_ClearFlag();   //清除復位標志
Time_Show();
//秒中斷函數 ,在  stm32f10x_it.c
void RTC_IRQHandler(void)
if(RTC_GetITStatus(RTC_IT_SEC) != RESET)    //判斷是否是秒中斷
     RTC_ClearITPendingBit(RTC_IT_SEC); //清除RTC秒中斷標志
     TimeDisplay = 1; //將標志位置1,代表1s過去
     RTC_WaitForLastTask();        //wait until last write operation on RTC regisiters has finished
     if(RTC_GetCounter() == 0x00015180) //reset RTC counter when time is 23:59:59
       RTC_SetCounter(0x0);
