查看: 3869|回復: 0
Mini2440裸機程序之ADC
ID:70976 發表于 2014-12-25 19:55 | 顯示全部樓層 |閱讀模式
源代碼及注釋
#define GLOBAL_CLK  1
#include <stdlib.h>
#include <string.h>
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include "2440lib.h"
#include "2440slib.h"
#include "mmu.h"
#include "memtest.h"
#include "Mylib.h"
#define LED1 (1 << (5 * 2))
#define LED2 (1 << (6 * 2))
#define LED3 (1 << (7 * 2))
#define LED4 (1 << (8 * 2))
#define LEDS (LED1 | LED2 | LED3 | LED4)
#define LED1_ON   ~(1<<5)
#define LED2_ON   ~(1<<6)
#define LED3_ON   ~(1<<7)
#define LED4_ON   ~(1<<8)
#define LED1_OFF   (1<<5)
#define LED2_OFF   (1<<6)
#define LED3_OFF   (1<<7)
#define LED4_OFF   (1<<8)
void init()
    cal_cpu_bus_clk();//在MyLib.h中有定義
    Uart_Init(0,115200);//PCLK、波特率為115200
    Uart_Select(0);//選擇串口0
    My_Logo();//在MyLib.h中有定義
int ADC_Test()
    int temp;
    rADCCON = (1<<14)|(0x31<<6)|(0<<3);//預分頻器使能、預分頻值為49、通道0
    rADCCON |=0x1;// A/D開始轉換,開始之后,此位被清除
    while(rADCCON&0x1);//檢測有沒有開始
    while(!(rADCCON&0x8000));//檢測轉換是否結束
    temp = rADCDAT0&0x3ff;//返回轉換值,正常A/D轉換的數值只能通過ADCDAT0寄存器的[9:0]位讀取
    return temp;
void Main(void)
    int temp,Value;
    U8 key;
    init();
    MMU_Init();//內存初始化
    rGPBCON = LEDS;   //初始化LED相應引腳為輸出
    rGPBDAT = rGPBDAT|(LED1_OFF)|(LED2_OFF)|(LED3_OFF)|(LED4_OFF); // LED 滅
    rGPBDAT &= ~(0x1);
    Uart_Printf("\n\n\nPress 'Enter' to refresh the Screen\n");//終端提示
           temp = ADC_Test();//調用A/D轉換函數
           Value = ((3300/1024)*temp)*1000;//轉換成電壓值,單位mV,Value值比實際值放大了1000倍
           key=Uart_Getch();//等待從鍵盤接收按鍵
           Beep(2000,100);//蜂鳴器發聲函數
           // 刷新A/D轉換,原因很簡單,我們往往在等待按鍵時調整電位器
           temp = ADC_Test();
           rGPBCON = LEDS;   //還原GPB的配置,原因調用了蜂鳴器發聲函數,改變了GPB原先的配置
          if(key==ENTER_KEY)//判斷是否按了Enter鍵
               key=0;//按鍵清零
               rGPBDAT = (~temp)&(~0x1);//輸出到LED顯示,務必把GPB0清零,否則你將會有麻煩 ^|^
               Uart_Printf("\n\n\n%d %% 1000000 %(V%)\n",Value);//把電壓值輸出到終端顯示
               key=0;
               Uart_Printf("\n\n\nPress the 'Enter' key!\n");//按鍵非Enter鍵,提示按鍵
程序結果
聲明:本人將不會再發表其它相關ARM裸機源代碼,包括上傳共享資料,望見諒!
