8*8點(diǎn)陣程序,我檢查很多次,都看不出程序的問(wèn)題,可還是會(huì)有一個(gè)警告,麻煩各位大佬幫忙看一下,這到底是哪里出問(wèn)題了
2021-6-20 14:52 上傳
單片機(jī)源程序如下:
- #include "reg51.h" //此文件中定義了單片機(jī)的一些特殊功能寄存器
- #include<intrins.h>
- typedef unsigned int u16; //對(duì)數(shù)據(jù)類型進(jìn)行聲明定義
- typedef unsigned char u8;
- sbit SRCLK=P3^6;
- sbit RCLK=P3^5;
- sbit SER=P3^4;
- sbit buzzer=P1^5;
- unsigned char code ledduan[17][8]={
- {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00},
- {0x00,0x00,0x24,0x7C,0x04,0x00,0x00,0x00},
- {0x00,0x00,0x26,0x4A,0x52,0x22,0x00,0x00},
- {0x00,0x00,0x2A,0x2A,0x2A,0x3E,0x00,0x00},
- {0x00,0x08,0x18,0x28,0x7E,0x08,0x00,0x00},
- {0x00,0x00,0x7A,0x4A,0x4E,0x00,0x00,0x00},
- {0x00,0x00,0x7E,0x4A,0x4E,0x00,0x00,0x00},
- {0x00,0x40,0x40,0x40,0x7E,0x00,0x00,0x00},
- {0x00,0x7E,0x4A,0x4A,0x7E,0x00,0x00,0x00},
- {0x00,0x7A,0x4A,0x4A,0x7E,0x00,0x00,0x00},
- {0x00,0x00,0x7E,0x48,0x78,0x00,0x00,0x00},
- {0x00,0x00,0x7E,0x48,0x48,0x00,0x00,0x00},
- {0x40,0x40,0x7E,0x40,0x40,0x00,0x00,0x00},
- {0x00,0x00,0x3E,0x02,0x02,0x00,0x00,0x00},
- {0x00,0x00,0x3E,0x02,0x3E,0x00,0x00,0x00},
- {0x00,0x30,0x48,0x24,0x24,0x48,0x30,0x00}
- unsigned char code ledwei[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
- void delay1(u16 i)
- while(i--);
- void beep()
- u16 i;
- for(i=0;i<100;i++)
- delay1(100);
- buzzer=~buzzer;
- void delay(unsigned int time)
- unsigned int i,j;
- for (i=0;i<time;i++)
- for (j=0;j<121;j++);
- * 函數(shù)名 : Hc595SendByte(u8 dat)
- * 函數(shù)功能 : 向74HC595發(fā)送一個(gè)字節(jié)的數(shù)據(jù),從高位開(kāi)始到低位
- * 輸入 : 無(wú)
- * 輸出 : 無(wú)
- void Hc595SendByte(u8 dat)
- u8 a;
- SRCLK=0;
- RCLK=0;
- for(a=0;a<8;a++)
- SER=dat>>7;//運(yùn)算時(shí),先將dat的值復(fù)制到一個(gè)臨時(shí)單元,向右移位運(yùn)算的是臨時(shí)單元的值,而不是dat,所以移位后, dat的值不變。
- dat<<=1;
- SRCLK=1;
- _nop_();
- _nop_();
- SRCLK=0;
- RCLK=1;
- _nop_();
- _nop_();
- RCLK=0;
- * 函 數(shù) 名 : main
- * 函數(shù)功能 : 主函數(shù)
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void main()
- unsigned char tab,j;
- unsigned int i;
- while(1)
- for (i=0;i<50;i++)
- { for(tab=0;tab<8;tab++)
- { Hc595SendByte(0x00);//消隱,去掉重影
- P0=ledwei[tab];
- Hc595SendByte(ledduan[j][tab]);
- delay(2);
- j++;
- beep();
- if(j==17)
- j=0;
