查看: 2927|回復: 0
fpga SPI接口源代碼
ID:581831 發表于 2020-10-24 10:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
FPGA與SPI接口程序(hdl源代碼)
  1. `timescale 1ns/1ps
  2. module spi(clk,reset,mosi,sclk,csb);
  3. input                         clk;
  4. input                         reset;
  5. //input                         enable;
  6. output                         mosi;
  7. output                         sclk;
  8. output                         csb;
  9. reg sclk_reg;
  10. reg csb;
  11. reg [7:0] counter;
  12. reg [4:0] mosi_index;
  13. wire clk_s;
  14. parameter enable = 1'b1;
  15. parameter spi_data = 16'h8000;
  16. // Instantiate the module
  17. clk_gen instance_name (
  18.     .clk(clk),
  19.     .reset(reset),
  20.     .clk_o(clk_s)
  21.     );
  22. //generate fl counter
  23. always@ (posedge clk_s or negedge reset)
  24. begin
  25. if(!reset)
  26.         counter <= 8'b0;
  27. else if(enable)
  28. begin
  29.         if(counter< 8'h35)
  30.         counter <= counter + 1;
  31. end
  32. end
  33. //generate signal csb
  34. always@ (posedge clk_s or negedge reset)
  35. begin
  36.         if(!reset)
  37.                 csb <= 1'b1;
  38.         else if(counter>= 8'b1 && counter<= 8'h32)
  39.                 csb <= 1'b0;
  40.         else
  41.                 csb <= 1'b1;
  42. end
  43. //Generate sclk
  44. always@ (posedge clk_s)
  45. begin
  46. case(counter)
  47.      8'h02: sclk_reg <= 1'b1;
  48.      8'h05: sclk_reg <= 1'b1;
  49.      8'h08: sclk_reg <= 1'b1;
  50.      8'h0b: sclk_reg <= 1'b1;
  51.      8'h0e: sclk_reg <= 1'b1;
  52.      8'h11: sclk_reg <= 1'b1;
  53.      8'h14: sclk_reg <= 1'b1;
  54.      8'h17: sclk_reg <= 1'b1;
  55.      8'h1a: sclk_reg <= 1'b1;
  56.      8'h1d: sclk_reg <= 1'b1;
  57.      8'h20: sclk_reg <= 1'b1;
  58.      8'h23: sclk_reg <= 1'b1;
  59.      8'h26: sclk_reg <= 1'b1;
  60.      8'h29: sclk_reg <= 1'b1;
  61.      8'h2c: sclk_reg <= 1'b1;
  62.      8'h2f: sclk_reg <= 1'b1;
  63.      default: sclk_reg <= 1'b0;
  64. endcase
  65. end
  66. always@ (counter or csb)
  67. begin
  68.         if(csb == 0)
  69.         case(counter)
  70.              8'h00,
  71.              8'h01,
  72.              8'h02,
  73.              8'h03: mosi_index = 5'h0F;
  74.              8'h04,
  75.              8'h05,
  76.              8'h06: mosi_index = 5'h0E;
  77.              8'h07,
  78.              8'h08,
  79.              8'h09: mosi_index = 5'h0D;
  80.              8'h0A,
  81.              8'h0B,
  82.              8'h0C: mosi_index = 5'h0C;
  83.              8'h0D,
  84.              8'h0E,
  85.              8'h0F: mosi_index = 5'h0B;
  86.              8'h10,
  87.              8'h11,
  88.              8'h12: mosi_index = 5'h0A;
  89.              8'h13,
  90.              8'h14,
  91.              8'h15: mosi_index = 5'h09;
  92.              8'h16,
  93.              8'h17,
  94.              8'h18: mosi_index = 5'h08;
  95.              8'h19,
  96.              8'h1A,
  97.              8'h1B: mosi_index = 5'h07;
  98.              8'h1C,
  99.              8'h1D,
  100.              8'h1E: mosi_index = 5'h06;
  101.              8'h1F,
  102.              8'h20,
  103.              8'h21: mosi_index = 5'h05 ;
  104.              8'h22,
  105.              8'h23,
  106.              8'h24: mosi_index = 5'h04;
  107.              8'h25,
  108.              8'h26,
  109.              8'h27: mosi_index = 5'h03 ;
  110.              8'h28,
  111.              8'h29,
  112.              8'h2A: mosi_index = 5'h02 ;
  113.              8'h2B,
  114.              8'h2C,
  115.              8'h2D: mosi_index = 5'h01;
  116.              8'h2E,
  117.              8'h2F,
  118.              8'h30: mosi_index = 5'h00;
  119.            default: mosi_index = 5'h00;
  120.        endcase
  121.        else  mosi_index = 8'h00;
  122. end
  123. assign sclk = sclk_reg;
  124. assign mosi = spi_data[mosi_index];
  125. endmodule
