查看: 3044|回復: 6
求指導,單片機紅外遙控實現LED閃爍程序及PWM調光
求指導,想要實現按鍵4按下LED4延時0.5秒閃爍,按其他鍵或者再按一下熄滅;按鍵2按下LED2稍暗,按其他鍵或者再按一下熄滅,按鍵3按下LED2稍亮,按其他鍵或者再按一下熄滅,程序應該怎么修改呢?程序及按鍵編碼值如下:按鍵編碼值:
按鍵1:00-FF-0C-F3
按鍵2:00-FF-18-E7
按鍵3:00-FF-5E-A1
按鍵4:00-FF-08-7F
按鍵5:00-FF-1C-E3
按鍵6:00-FF-5A-A5
按鍵7:00-FF-42-BD
按鍵8:00-FF-52-AD
程序:
#include <reg52.h>
#include <intrins.h>
#define  NOP()   _nop_()
#define uint  unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_()};
void delay(uchar x);
void delay1(int ms);
void delayms(uint);
void beep(void);
sbit IRIN = P3^2;
sbit LED1 = P1^0;
sbit LED2 = P1^1;
sbit LED3 = P1^2;
sbit LED4 = P1^3;
sbit LED5 = P1^4;
sbit LED6 = P1^5;
sbit LED7 = P1^6;
sbit LED8 = P1^7;
sbit BEEP = P2^3;
uchar IRCOM[7];
unsigned char Y1,Y2,Y3,Y4,Y5,Y6,Y7,Y8,Y9,i,j;
main()
    IE = 0x81;
    TCON = 0x01;
    IRIN=1;
    BEEP=1;
    LED1=1;
    LED2=1;
    LED3=1;
    LED4=1;
    LED5=1;
    LED6=1;
    LED7=1;
    LED8=1;
    delay1(10);
   while(1);
void IR_IN(void) interrupt 0
  unsigned char j,k,N=0;
         EX0 = 0;
         delay(15);
         if (IRIN==1)
                            EX0 =1;
          return;
    while (!IRIN)
    {delay(1);}
    for (j=0;j<4;j++)
                        for (k=0;k<8;k++)
                                while (IRIN)
                                {delay(1);}
                                while (!IRIN)
                                {delay(1);}
                                while (IRIN)
                                        delay(1);
                                        N++;
                                        if (N>=30)
                                         EX0=1;
                                         return;
                                IRCOM[j]=IRCOM[j] >> 1;
                                if (N>=8) {IRCOM[j] = IRCOM[j] | 0x80;}
                                N=0;
   if (IRCOM[2]!=~IRCOM[3])
                 EX0=1;
     return;
   IRCOM[5]=IRCOM[2] & 0x0F;
   IRCOM[6]=IRCOM[2] >> 4;
   if(IRCOM[5]>9)
    { IRCOM[5]=IRCOM[5]+0x37;}
   else IRCOM[5]=IRCOM[5]+0x30;
   if(IRCOM[6]>9)
    { IRCOM[6]=IRCOM[6]+0x37;}
   else IRCOM[6]=IRCOM[6]+0x30;
   Y1=Y2=Y3=Y4=Y5=Y6=Y7=Y8=Y9=0;
   switch(IRCOM[2])
                        case 0x0C: Y1=0x01; break;
      case 0x18: Y2=0x01; break;
      case 0x5E: Y3=0x01; break;
      case 0x08: Y4=0x01; break;
      case 0x1C: Y5=0x01; break;
      case 0x5A: Y6=0x01; break;
      case 0x42: Y7=0x01; break;
      case 0x52: Y8=0x01; break;
                        if(Y1&0xFF)LED1=0;
      else LED1=1;
      if(Y2&0xFF)LED2=0;
      else LED2=1;
      if(Y3&0xFF)LED3=0;
      else LED3=1;
      if(Y4&0xFF)LED4=0;
      else LED4=1;
      if(Y5&0xFF)LED5=0;
      else LED5=1;
      if(Y6&0xFF)LED6=0;
      else LED6=1;
      if(Y7&0xFF)LED7=0;
      else LED7=1;
      if(Y8&0xFF)LED8=0;
      else LED8=1;
    beep();
    EX0 = 1;
void beep(void)
  unsigned char i;
  for (i=0;i<100;i++)
   delay(4);
   BEEP=!BEEP;
  BEEP=1;
void delay(unsigned char x)
        unsigned char i;
  while(x--)
                for (i = 0; i<13; i++) {}
void delay1(int ms)
        unsigned char y;
  while(ms--)
                for(y = 0; y<250; y++)
   _nop_();
   _nop_();
   _nop_();
   _nop_();
ID:147710 發表于 2020-8-26 16:30 | 只看該作者
你這個程序功能代碼互相交叉,牽一發動全身,沒有修改價值,先按照之前的按鍵控制LED的例子先做一遍,各功能模塊要獨立出來:LED顯示,蜂鳴器驅動,鍵值解析,紅外接收,單獨封裝成一個函數,先把這些一個個調試正常,然后一個個組合起來。另外,定時中斷中再用delay很不妥。
ID:230118 發表于 2020-8-26 17:44 | 只看該作者
用個小狀態機描述比較清晰:
idle state :   ledOff();
                  if (capture(Key4))
                        shine(LED4);
                        goto  state  1;
                  if (capture(Key2))
                        darken(LED2)
                        goto  state  2;
                   if (capture(Key3))
                        brighten(LED2)
                        goto  state  3;
state 1、state2、state3:
                   if (capture(anykey))
                         goto state idle;
偽代碼,自己實現函數
ID:626891 發表于 2020-8-26 18:07 來自觸屏版 | 只看該作者
XTXB 發表于 2020-8-26 16:30
你這個程序功能代碼互相交叉,牽一發動全身,沒有修改價值,先按照之前的按鍵控制LED的例子先做一遍,各功 ...
這個程序搞了好久,把各個功能模塊分出來,然后再組合,對于我們初學者來說很難的,不知道從何入手
ID:147710 發表于 2020-8-26 22:02 | 只看該作者
你上次不是提過類似問題么,我給的參考程序有沒有敲一遍?首先在IO口加幾個按鍵代替紅外接收,把LED按照需求點亮,
然后再單獨調通紅外接收。
最后組合在一起。
別急,花點時間把這些吃透,以后就輕松了。
做項目其實都是大同小異。
你這個我以前玩過。
ID:626891 發表于 2020-8-27 10:16 來自觸屏版 | 只看該作者
我有開發板的,就是不知道怎么組合程序
ID:147710 發表于 2020-8-27 12:53 | 只看該作者
截個圖看看,你完成的單個功能。
你這個需求由于有紅外編碼,對時序要求比較嚴,先把單個功能高質量完成才行,別一開始就搞組合功能,到時不能工作都不知道如何查起。
比如先做一個簡單功能,把這個功能封裝成函數,有了封裝換一個不同的遙控器就不至于全部推倒重來。
別想著只用幾行代碼就能解決所有問題,要舍得多聲明變量,多聲明函數,思維要有層次,不要眉毛胡子一把抓,結果啥都沒抓到。
我給你的代碼有你所缺乏的編程思維,認真做一遍后,你目前的很多問題都可迎刃而解。
千萬不要小瞧按鍵點燈程序,你試著完成下面需求:
1,單擊按鍵在按下時馬上點亮
2,單擊按鍵在抬起后才點亮
3,雙擊點亮,
4,長按3秒點亮
5,連續按3次點亮
6,按住按鍵不放,1秒后,LED每秒鐘閃爍3次,松開手后,LED熄滅
