代碼寫(xiě)的有點(diǎn)啰嗦,不過(guò)用起來(lái)挺好用的, 漢字取模采用最普遍的 橫向左高位取模,
可以自己任意組合滾動(dòng)方式, 上下左右滾,想怎么滾就怎么滾,不會(huì)的就看看哈
2013-6-26 04:30 上傳
源碼及其仿真文件下載:
16x16點(diǎn)陣滾動(dòng)51hei.com.rar
(50.79 KB, 下載次數(shù): 1382)
2013-6-26 04:31 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
下面是源代碼預(yù)覽:
#include <reg51.h>
#include <intrins.h>
#define DATAOUT P2 //P2 use as data, you can change
#define SPEED 13
void ymove(char dir,unsigned char *ptr,char speed);
void xmove(char dir,unsigned char *ptr,char n,char speed);
void delay(unsigned int a);
void display();
void displaytime(char time);
void init164();
sbit ADATA= DATAOUT^0;
sbit ASCK= DATAOUT^1;
sbit LATCH= DATAOUT^2;
sbit BDATA= DATAOUT^3;
sbit BCLK= DATAOUT^4;
code unsigned char xin[32]={
0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x38, //心
0x1F,0x7C,0x3F,0xFE,0x3F,0xFE,0x3F,0xFE,
0x1F,0xFC,0x0F,0xF8,0x07,0xF0,0x03,0xE0,
0x01,0xC0,0x00,0x80,0x00,0x00,0x00,0x00};
code unsigned char zhong[32]={
0x01,0x00,0x01,0x00,0x01,0x04,0x7F,0xFE, //中
0x41,0x04,0x41,0x04,0x41,0x04,0x41,0x04,
0x7F,0xFC,0x41,0x04,0x01,0x00,0x01,0x00,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00};
code unsigned char guo[32]={
0x00,0x04,0x7F,0xFE,0x40,0x24,0x5F,0xF4, //國(guó)
0x41,0x04,0x41,0x04,0x41,0x44,0x4F,0xE4,
0x41,0x04,0x41,0x44,0x41,0x24,0x41,0x04,
0x5F,0xF4,0x40,0x04,0x7F,0xFC,0x40,0x04};
code unsigned char dui[32]={
0x7C,0x40,0x44,0x40,0x48,0x40,0x48,0x40, //隊(duì)
0x50,0x40,0x48,0x40,0x48,0x40,0x44,0xA0,
0x44,0xA0,0x44,0xA0,0x69,0x10,0x51,0x10,
0x42,0x08,0x44,0x06,0x48,0x04,0x00,0x00};
code unsigned char jia[32]={
0x10,0x00,0x10,0x00,0x10,0x04,0x12,0x7E, //加
0xFF,0x44,0x12,0x44,0x12,0x44,0x12,0x44,
0x12,0x44,0x22,0x44,0x22,0x44,0x22,0x44,
0x22,0x44,0x4A,0x7C,0x84,0x44,0x00,0x00};
code unsigned char you[32]={
0x00,0x40,0x40,0x40,0x30,0x40,0x10,0x44, //油
0x87,0xFE,0x64,0x44,0x24,0x44,0x0C,0x44,
0x14,0x44,0x27,0xFC,0xE4,0x44,0x24,0x44,
0x24,0x44,0x24,0x44,0x27,0xFC,0x24,0x04 };
code unsigned char gth[32]={
0x00,0x00,0x01,0x80,0x03,0xC0,0x03,0xC0, //!
0x03,0xC0,0x03,0xC0,0x03,0xC0,0x01,0x80,
0x01,0x80,0x01,0x80,0x00,0x00,0x01,0x80,
0x03,0xC0,0x01,0x80,0x00,0x00,0x00,0x00};
unsigned char idata buffer[32];
void main(void)
unsigned char i;
init164();
for(i=0;i<32;i++)
buffer[ i]=xin[ i];
displaytime(1);
xmove(1,zhong,3,SPEED);
displaytime(1);
ymove(1,0,SPEED);
ymove(1,jia,SPEED);
ymove(1,you,SPEED);
ymove(1,0,SPEED);
xmove(0,jia,3,SPEED);
ymove(0,gth,SPEED);
ymove(0,0,SPEED);
xmove(1,xin,1,SPEED);
/************* 子函數(shù) ******************/
while(a--);
void display()
unsigned char hang,ib,k,tmp;
DATAOUT= 0x0;
BDATA = 0;
for(hang=0;hang<16;hang++)
ASCK =0;
LATCH=0;
BCLK =0;
for(ib=0;ib<2;ib++)
tmp = buffer[hang*2+ib];
for(k=0;k<8;k++)
tmp <<=1;
ASCK =0;
ADATA =CY;
ASCK =1;
DATAOUT|=0x14;
//LATCH=1;
//BCLK=1;
BDATA=1;
delay(64);
ASCK =0;
ASCK =1;
unsigned char i;
while(time--)
i=130;
while(i--)
display();
void init164()
char i;
BDATA=1;
for(i=0;i<16;i++)
BCLK =0;
BCLK =1;
{ /* 方向 n是要移動(dòng)的漢字個(gè)數(shù) 移動(dòng)速度*/
unsigned char i=0, ib=0;
unsigned int tmp=0, speedm=0;
unsigned char buffer2[16]; //半個(gè)漢字的緩存
n*=2; //左半字和右半字,所以要x2
for(i=0;i<16;i++) //清零
buffer2[ i]=0;
if(dir == 1)
/**** 向左移動(dòng) ****/
for(n;n>0;n--)
if(ptr != 0)
tmp = n%2; //判斷是左半字還是右半字
for(i=0;i<16;i++)
buffer2[ i]=ptr[i*2+tmp];
if(tmp) //tmp為1時(shí),將地址指向下一個(gè)漢字
ptr+=32;
for(tmp=8;tmp>0;tmp--) //要移動(dòng)8列
ib=0;
for(i=0;i<16;i++)
{ //要移16行,共16個(gè)字節(jié)
buffer[ib] <<=1; //移第一個(gè)半字
if(buffer[ib+1] & 0x80)
buffer[ib]++;
ib++;
buffer[ib]<<=1; //移后半字
if(buffer2[ i] & 0x80)
buffer[ib]++;
ib++;
buffer2[ i]<<=1; //緩沖左半字向左移一位
speedm=speed; //更新點(diǎn)陣
while(speedm--)
display();
/****** 向右移動(dòng) ******/
for(n;n>0;n--)
if(ptr != 0)
tmp = (n+1) % 2 ; //判斷左半字還是右半字
for(i=0;i<16;i++)
if(tmp == 0) //tmp為0時(shí),將地址指向下一個(gè)漢字
ptr+=32;
ib=0;
for(i=0;i<16;i++)
buffer[ib+1] >>= 1; //移右半字
if(buffer[ib] & 0x01)
buffer[ib+1] |=0x80 ;
buffer[ib] >>= 1; //移左半字
if(buffer2[ i] & 0x01)
buffer[ib] |= 0x80;
ib+=2;
buffer2[ i] >>=1; //下個(gè)漢字的右半字向右移一位
speedm=speed;
while(speedm--) //更新點(diǎn)陣
display();
void ymove(char dir,unsigned char *ptr, char speed)
{ //dir=1上移動(dòng),dir=0為下移動(dòng)
char i=0, j=0, ib=0;
if(dir==0)
/**** 向下移 ****/
ib=31;
for(i=16;i>0;i--) //下移16行
for(j=29;j>-1;j--)
buffer[j+2]=buffer[j]; //將上一行的內(nèi)容復(fù)制到下一行
if(ptr==0)
{ //移空時(shí),buffer的首行用0移入
buffer[0]=0;
buffer[1]=0;
{ //否則,處理buffer的首行元素
buffer[1]=ptr[ib];
buffer[0]=ptr[ib-1];
ib=ib-2;
speedm=speed;
display();
/****** 向上移 *******/
ib=0; //數(shù)組元素序號(hào)
for(i=0;i<16;i++) //上移16行
for(j=0;j<30;j++) //將下一行的內(nèi)容復(fù)制到上一行
buffer[j]=buffer[j+2];
if(ptr==0) //移入為空,buffer的末行用0移入
buffer[30]=0;
buffer[31]=0;
{ //否則,處理buffer的末行元素
buffer[30]=ptr[ib];
buffer[31]=ptr[ib+1];
ib=ib+2;
while(speedm--)
display();
