利用GSM模塊上傳數據到onenet,沒任何反應,僅僅可以發短信。
程序:
- #include "reg52.h"
- #include "type.h"
- #include <string.h>
- #include <stdio.h>
- bit flag;
- uchar model=0; //模式
- uchar temp1H=35; //上限值
- uchar temp2H=35; //上限值
- uchar temp3H=35; //上限值
- uchar hum1H=50; //上限值
- uchar hum2H=50; //上限值
- uchar hum3H=50; //上限值
- uchar temp_L=10;
- uchar date[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- unsigned char temp1=0,temp2=0,temp3=0,hum1=0,hum2=0,hum3=0;
- #define SEND_MESSA_TO_YOUR "at+cmgs=\"185*****436\"\r\n" //填入你手上的手機號碼 不是板子的
- #include "LCD1602.H"
- sbit set=P1^6;
- sbit add=P3^5;
- sbit min=P3^4;
- sbit beep=P3^6;
- sbit led1=P1^2;
- sbit led2=P1^1;
- /***********模擬開關*********************/
- sbit CS_4052=P1^0;
- sbit B_4052=P1^1;
- sbit A_4052=P1^2;
- uchar fen=0; //定時發送短信計時
- bit sendFlag=0; //發送短信標志
- void delay1ms(unsigned int ms)//延時1毫秒(不夠精確的)
- {unsigned int i,j;
- for(i=0;i<ms;i++)
- for(j=0;j<100;j++);
- void Uart_Send(uchar dat) //發送一字節
- SBUF=dat;
- while(!TI);
- TI=0;
- //發送一串字符到串口
- void Uart_Sends(char* data_at)
- unsigned char cnt=0;
- while(*(data_at+cnt)) //判斷一串數據是否結束
- Uart_Send(*(data_at+cnt));
- cnt++;
- void select(uchar num)
- if(num==1) //上位機串口使能
- CS_4052=0;
- B_4052=0;
- A_4052=0;
- else if(num==2) //CC2530串口使能
- CS_4052=0;
- B_4052=0;
- A_4052=1;
- else if(num==3) //wifi串口使能
- CS_4052=0;
- B_4052=1;
- A_4052=0;
- //發送短信函數
- void Send_SMS(void)
- uchar yy=1;
- select(1); //GSM模塊串口使能
- delay1ms(100);
- Uart_Sends("AT+CMGF=1\r");//設置中文方式發送
- delay1ms(800);
- delay1ms(1000);
- Uart_Sends(SEND_MESSA_TO_YOUR);
- delay1ms(1000);
- switch (yy)
- case 1 : Uart_Sends("wendu1=\r\n");
- Uart_Send(temp1/10+0x30);
- Uart_Send(temp1%10+0x30);
- Uart_Sends(",wendu2=");
- Uart_Send(temp2/10+0x30);
- Uart_Send(temp2%10+0x30);
- Uart_Sends(",wendu3=");
- Uart_Send(temp3/10+0x30);
- Uart_Send(temp3%10+0x30);
- Uart_Sends("\r\nshidu1=\r\n");
- Uart_Send(hum1/10+0x30);
- Uart_Send(hum1%10+0x30);
- Uart_Sends(",shidu2=");
- Uart_Send(hum2/10+0x30);
- Uart_Send(hum2%10+0x30);
- Uart_Sends(",shidu3=");
- Uart_Send(hum3/10+0x30);
- Uart_Send(hum3%10+0x30);
- Uart_Sends("\r\n");
- if(temp1>temp1H)
- Uart_Sends("wendu1 Warning!!!\r\n");
- if(temp2>temp2H)
- Uart_Sends("wendu2 Warning!!!\r\n");
- if(temp3>temp3H)
- Uart_Sends("wendu3 Warning!!!\r\n");
- if(hum1>hum1H)
- Uart_Sends("hum1 Warning!!!\r\n");
- if(hum2>hum2H)
- Uart_Sends("hum2 Warning!!!\r\n");
- if(hum3>hum3H)
- Uart_Sends("hum3 Warning!!!\r\n");
- break; //煙霧報警
- Uart_Send(0x1a);//以0x1a來結束,表示內容結束,發送短信
- void key()
- uchar i=0;
- if(!set) //檢測設置按鍵
- while(!set);
- model++;
- if(model==7)
- model=0;
- if(model==1)//設置模式顯示
- WRITE_LCD1602_COM(0x80);
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB3[i]);
- WRITE_LCD1602_COM(0x80+0x40);
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB4[i]);
- WRITE_LCD1602_COM(0x80+0x40+9);
- else if(model==0)//正常模式顯示
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB1[i]);
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB2[i]);
- else if(!add)
- while(!add);
- switch(model)
- case 1: if(temp1H<90) temp1H++; break;
- case 2: if(temp2H<90) temp2H++; break;
- case 3: if(temp3H<90) temp3H++; break;
- case 4: if(hum1H<90) hum1H++; break;
- case 5: if(hum2H<90) hum2H++; break;
- case 6: if(hum3H<90) hum3H++; break;
- default:break;
- else if(!min)
- while(!min);
- switch(model)
- case 1: if(temp1H>0) temp1H--; break;
- case 2: if(temp2H>0) temp2H--; break;
- case 3: if(temp3H>0) temp3H--; break;
- case 4: if(hum1H>0) hum1H--; break;
- case 5: if(hum2H>0) hum2H--; break;
- case 6: if(hum3H>0) hum3H--; break;
- default:break;
- void beeps()
- static uchar count;
- count++;
- if(count<20)
- beep=0;
- else if(count<40)
- beep=1;
- else
- count=0;
- void control()//報警檢測控制
- static uchar flagsend=0;
- if((temp1>temp1H)||(temp2>temp2H)||(temp3>temp3H)||
- (hum1>hum1H)||(hum2>hum2H)||(hum3>hum3H)) //溫度控制
- beeps(); // 蜂鳴器報警
- if(flagsend==0)
- flagsend=1;
- Send_SMS();
- else
- flagsend=0;
- beep=1;// 關閉蜂鳴器報警
- void rec_cc2530data()
- select(2); //選通 cc2530 串口
- ES=1; //串口接收中斷
- if(date[0]==0x55)
- date[0]=0;
- if((date[1]==1)&&(date[2]+date[3]==date[4])) //第一路 數據
- date[1]=0;
- temp1=date[2];
- hum1=date[3];
- if((date[1]==2)&&(date[2]+date[3]==date[4])) //第二路
- date[1]=0;
- temp2=date[2];
- hum2=date[3];
- if((date[1]==3)&&(date[2]+date[3]==date[4])) //第三路
- date[1]=0;
- temp3=date[2];
- hum3=date[3];
- void GsmInit()
- select(1); //打開上位機串口
- Uart_Sends("AT+CIPCLOSE\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CIPSHUT\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CREG?\x00D\x00A");
- delay1ms(1000);
- Uart_Sends("AT+CGATT=1\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CIPRXGET=0\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CSTT=CMIOT\r\n");
- Uart_Sends("AT+CIICR\r\n");
- delay1ms(1000);
- delay1ms(1000);
- Uart_Sends("AT+CIPQRCLOSE=1\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CIPMODE=0\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CIPSTART=\"TCP\",\"183.230.40.33\",\"80\"\r\n");//此處修改你建立服務器的IP,服務器端口號8080
- delay1ms(1000);
- // Uart_Sends("AT+CIPSEND\r\n");
- // delay1ms(1000);
- //SendString("POST /devices/1100286/datapoints?type=3 HTTP/1.1\r\n");
- Uart_Sends("POST /devices/594614665/datapoints?type=3 HTTP/1.1\r\n"); //將數字修改為自己的設備id)
- delay1ms(1000);
- Uart_Sends("Host:api.heclouds點com\r\n");
- delay1ms(1000);
- //SendString("api-key:DcQ2NF=70s3j3=mlsFXfPod1kaY=\r\n");
- Uart_Sends("api-key: RJPjiEVRqddktp2OP5mbn=qiWWI=\r\n"); //這里填寫自己的API-key
- delay1ms(1000);
- void SendGprsData(uchar *sendbuf) //ADD
- unsigned char lenbuf[4];
- select(1);
- delay1ms(1000);
- Uart_Sends("AT+CIPSEND=");
- sprintf(lenbuf,"%d",strlen(sendbuf));
- Uart_Sends(lenbuf);
- delay1ms(1000);
- Uart_Sends(sendbuf);
- Uart_Sends(0x1a);//ADD
- delay1ms(1000);
- void Timer0Init(void) //50毫秒@11.0592MHz
- TMOD &= 0xF0; //設置定時器模式
- TMOD |= 0x01; //設置定時器模式
- TL0 = 0x00; //設置定時初值
- TH0 = 0x4C; //設置定時初值
- TF0 = 0; //清除TF0標志
- TR0 = 1; //定時器0開始計時
- ET0=1;
- bit SendGprsFlag=0,GsmInitFlag=0;
- idata unsigned char SendBuf[26];
- void main()
- init_1602();
- TMOD=0x20; // T1定時方式2
- SCON=0x40;//串行工作 方式1
- PCON=0x00; //不加倍
- TH1=TL1=0xfd; //定時器1賦初值 保證波特率9600
- TR1=1; //開定時器1
- REN=1; //允許串口接收
- ES=1; //打開串口中斷
- EA=1; //開總中?
- Timer0Init();
- GsmInit(); //sim800初始化 ******ADD
- while(1)
- control(); //控制
- key(); //按鍵功能
- if(SendGprsFlag==1) //1一分鐘向GPRS發送一次數據
- SendGprsFlag=0; //ADD
- if(GsmInitFlag==0)
- GsmInitFlag=1;
- GsmInit(); //H1:50%,
- } //T1:23C,
- sprintf(SendBuf,"T1:%2dC,T2:%2dC,T2:%2dC\r\n",(unsigned int)temp1,(unsigned int)temp2,(unsigned int)temp3);
- SendGprsData(SendBuf);
- delay1ms(1000);
- sprintf(SendBuf,"H1:%2%%,H2:%2%%,H3:%2%%\r\n",(unsigned int)hum1,(unsigned int)hum2,(unsigned int)hum3);
- if(sendFlag==0)
- sendFlag=1; //代表已經發過一次,不在發了
- Send_SMS(); //發送短信
- rec_cc2530data();
- delay1ms(50);
- display();
- void serial()interrupt 4 //串口中斷服務函數
- static uchar j;
- if(!RI);
- RI=0; //清楚接收完畢標志
- date[j]=SBUF;
- if(date[0]==0x55) //判斷接收到的第一位為傳感器所發數據
- j++;
- else
- j=0;
- if(j==5) //接收傳感器所發數據字節
- j=0;
- void timer0() interrupt 1 //50ms
- static uchar count=0,miao=0;
- count++;
- if(count>20)
- count=0;
- miao++;
- if(miao>60)
- miao=0;
- fen++;
- if(fen>=1)
- fen=0;
- sendFlag=0;
接收機-程序.zip
2020-4-29 21:30 上傳
102.51 KB, 下載次數: 9
