- //按鍵key1 設置紅燈時間
- 按鍵key2 設置綠燈時間
- 按鍵key3設置黃燈時間
- #include
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "stdlib.h"
- static int G=0,R=0,Y=0; //設置綠,紅,黃燈時間變量
- #include "lcd.h"
- #include "key.h"
- #include "time.h"
- //----------- 按鍵函數----------
- void scan_key1()
- static u8 i,j;
- if(key1==0)
- if(i==0)
- j++;
- if(j>3)
- i=1;j=0;
- R++;
- if(R>20)R=0;
- printf("key1 is inputed ");
- else
- i=j=0;
- void scan_key2()
- static u8 i,j;
- if(key2==0)
- if(i==0)
- j++;
- if(j>3)
- i=1;j=0;
- G++;
- if(G>20)G=0;
- printf("key2 is inputed. ");
- else
- i=j=0;
- void scan_key3()
- static u8 i,j;
- if(key3==1)
- if(i==0)
- j++;
- if(j>3)
- i=1;j=0;
- Y++;
- if(Y>20)Y=0;
- printf("key3 is inputed. ");
- else
- i=j=0;
- //各指示燈顯示秒數函數
- void LED_RED(u8 k)
- LCD_ShowNum(120,55,k,2,16);
- void LED_YELLOW(u8 k)
- LCD_ShowNum(120,145,k,2,16);
- void LED_GREEN(u8 k)
- LCD_ShowNum(120,235,k,2,16);
- //-----定時設置函數-------
- void LED_SET_GREEN(u8 k)
- LCD_ShowNum(160,235,k,2,16);
- void LED_SET_YELLOW(u8 k)
- LCD_ShowNum(160,145,k,2,16);
- void LED_SET_RED(u8 k)
- LCD_ShowNum(160,55,k,2,16);
- //-----定時器中斷函數---掃描按鍵和顯示設定值用----
- void TIM3_IRQHandler(void)
- if(TIM3->SR&0x0001)
- scan_key1();
- scan_key2();
- scan_key3();
- LED_SET_RED(R);
- LED_SET_GREEN(G);
- LED_SET_YELLOW(Y);
- TIM3->SR=~(1<<0);
- //------主函數-----------
- int main(void)
- u16 code; //TFT驅動芯片代號
- int i;
- Stm32_Clock_Init(9);
- delay_init(72);
- uart_init(72,9600);
- printf("uart is ok. ");
- Timer_init(300,7199); //定時器初始化 設定溢出時間是 30ms
- printf("time_init is ok. ");
- LCD_Init(); //TFT-LCD初始化
- printf("lcd_init is ok.");
- key_init(); //按鍵I/O口設置初始化
- printf("key_init is ok.");
- JTAG_Set(JTAG_SWD_DISABLE); //關閉JTAG調試器
- code=LCD_ReadReg(0x0000);
- delay_ms(500);
- printf("deiver code is %ld",code); //讀取驅動芯片型號是發送到串口
- LCD_Fill(30,200,100,270,BLACK);
- LCD_Fill(30,110,100,180,BLACK);
- LCD_Fill(30,20,100,90,BLACK);
- LCD_ShowString(110,15,"Show");
- LCD_ShowString(110,30,"Time");
- LCD_ShowString(160,15,"Set ");
- LCD_ShowString(160,30,"Time");
- LED_GREEN(0);
- LED_YELLOW(0);
- LED_RED(0);
- while(1)
- for(i=G;i>=0;i--) //綠燈控制
- LED_GREEN(i);
- LCD_Fill(30,200,100,270,GREEN);
- delay_ms(1000);
- delay_ms(1000);
- for(i=Y;i>=0;i--) //黃燈控制
- LED_YELLOW(i);
- LCD_Fill(30,110,100,180,YELLOW);
- delay_ms(1000);
- delay_ms(1000);
- for(i=R;i>=0;i--) //紅燈控制
- LED_RED(i);
- LCD_Fill(30,20,100,90,RED);
- delay_ms(1000);
- delay_ms(1000);
- //-------各類庫函數省略---------
stm32簡易紅綠燈設計
