電風扇是我用智能電風扇的仿真文件改的,所以其他功能沒有,就只有壓力傳感器有用
單片機源碼:
- #include"reg52.h"//頭文件
- #include<intrins.h>
- #define DD P2
- sbit CS=P1^0; //定義端口
- sbit CLK=P1^1;
- sbit DO=P1^2;
- sbit DI=P1^3;
- sbit KEY=P1^7;
- sbit buzzer=P0^0;
- sbit Rs=P1^4;//LCD定義端口
- sbit Rw=P1^5;
- sbit E=P1^6;
- sbit busy_p=ACC^7;
- unsigned char CH=0x02,key_count=1;
- unsigned char HC[6]={0};
- unsigned char BZ=0;
- void delay_1ms(unsigned char i) //延時函數1ms
- unsigned char j;
- while(i--)
- for(j=0;j<125; j++);
- void delay_10ns(unsigned char i)//延時函數10ns
- unsigned char j;
- while(i--)
- for(j=0;j<10; j++);
- void xiezhiling(unsigned char com,bit p)//寫命令函數
- if(p)
- delay_10ns(5);
- E=0;
- Rs=0;
- Rw=0;
- DD=com;
- delay_10ns(50);
- E=1;
- delay_1ms(2);
- E=0;
- delay_10ns(4);
- void xieshuju(unsigned char DATA)//寫數據函數
- delay_10ns(50);
- E=0;
- Rs=1;
- Rw=0;
- DD=DATA;
- delay_10ns(50);
- E=1;
- delay_10ns(50);
- E=0;
- delay_10ns(4);
- void init(void)//初始化函數
- delay_1ms(15);
- xiezhiling(0x38,0);
- delay_1ms(5);
- delay_1ms(5);
- delay_1ms(5);
- xiezhiling(0x38,1); //功能設定(8位,2行,5*7點矩陣)
- xiezhiling(0x08,1);
- xiezhiling(0x01,1); //清除屏幕
- xiezhiling(0x06,1); //加1
- xiezhiling(0x0c,1);//顯示器ON,光標OFF,閃爍OFF
- unsigned char ADconv(void)//AD轉換子程序
- unsigned char i;
- unsigned int data_f=0,data_c=0;
- DI=1;
- CS=1;
- _nop_();
- CS=0;
- DI=1; ;
- CLK=1;
- _nop_();
- _nop_();
- CLK=0;
- _nop_();
- _nop_();
- CLK=1;
- DI=(bit)(0x02&CH);
- _nop_();
- CLK=0;
- _nop_();
- _nop_();
- CLK=1;
- DI=(bit)(0x01&CH);
- _nop_();
- _nop_();
- CLK=0;
- DI=1;
- CLK=1;
- _nop_();
- _nop_();
- CLK=0;
- _nop_();
- CLK=1;
- for(i=8;i>0;i--)
- data_f|=DO;
- data_f<<=1;
- CLK=1;
- _nop_();
- _nop_();
- CLK=0;
- _nop_();
- for(i=8;i>0;i--)
- data_c<<=1;
- data_c|=DO;
- _nop_();
- CLK=1;
- _nop_();
- _nop_();
- CLK=0;
- _nop_();
- CLK=0;
- _nop_();
- _nop_();
- CLK=1;
- _nop_();
- _nop_();
- CLK=0;
- _nop_();
- _nop_();
- CLK=1;
- _nop_();
- CS=1;
- _nop_();
- _nop_();
- return data_f;
- void xs_int(unsigned int shuju)//將一個數據各個位分開并存放在H C[]數組中
- if(shuju < 10)
- BZ = 1;
- else if(shuju < 100) BZ = 2;
- else if(shuju < 1000) BZ = 3;
- else if(shuju < 10000) BZ = 4;
- else if(shuju < 65535) BZ = 5;
- switch(BZ)
- case 5:HC[5] = shuju/10000; //百位
- case 4:HC[3] = shuju%10000/1000;//十位
- case 3:HC[2] = shuju%1000/100;//個位
- case 2:HC[1] = shuju%100/10;//小數點后一位
- case 1:HC[0] = shuju%10;
- break;
- default:break;
- void main(void)//主函數
- unsigned int data_temp=0;
- init();
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- ET0=1;
- TR0=1;
- while(1)
- data_temp=ADconv();
- if(data_temp>128)//報警數值
- EA=1;
- else
- EA=0;
- buzzer=0;
- P3=~data_temp;
- xs_int(196*data_temp);
- if(KEY==0)
- delay_1ms(10);
- if(KEY==0)
- while(!KEY);
- key_count++;
- if(key_count==3)
- key_count=1;
- xiezhiling(0x01,0);
- if(key_count==1)
- xiezhiling(0x80,1);//LCD第一行
- xieshuju('P');
- xieshuju('R');
- xieshuju('E');
- xieshuju('S');
- xieshuju('S');
- xieshuju('U');
- xieshuju('R');
- xieshuju('E');
- xieshuju('-');
- xieshuju(HC[5]+0x30);
- xieshuju(HC[3]+0x30);
- xieshuju(HC[2]+0x30);
- xieshuju('.');
- xieshuju(HC[1]+0x30);
- xieshuju('P');
- xieshuju('a');
- xiezhiling(0x80+0x40,1);//LCD第二行
- xieshuju('A');
- xieshuju('l');
- xieshuju('a');
- xieshuju('r');
- xieshuju('m');
- xieshuju(' ');
- xieshuju('S');
- xieshuju('t');
- xieshuju('a');
- xieshuju('t');
- xieshuju('u');
- xieshuju('s');
- xieshuju('-');
- xieshuju('-');
- xieshuju('O');
- xieshuju('N');
- if(key_count==2)
- xieshuju('P');
- xieshuju('r');
- xieshuju('e');
- xieshuju('s');
- xieshuju('s');
- xieshuju('u');
- xieshuju('r');
- xieshuju('e');
- xieshuju(' ');
- xieshuju('i');
- xieshuju('s');
- xieshuju(' ');
- xieshuju('O');
- xieshuju('K');
- xieshuju(' ');
- xieshuju(' ');
- xieshuju('m');
- xieshuju('a');
- xieshuju('d');
- xieshuju('e');
- xieshuju(' ');
- xieshuju('B');
- xieshuju('Y');
- xieshuju(' ');
- xieshuju('f');
- xieshuju('u');
- xieshuju('b');
- xieshuju('a');
- xieshuju('o');
- xieshuju('j');
- xieshuju('i');
- xieshuju('e');
- xieshuju(' ');
全部資料51hei下載地址:
電風扇.zip
(123.1 KB, 下載次數: 72)
2018-11-26 20:29 上傳
