查看: 4594|回復: 3
51單片機交通燈仿真
51單片機做的交通燈仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載):
  1. //proteus仿真論壇
  2. #include <reg51.h>
  3. #include <stdio.h>
  4. #define uchar     unsigned char
  5. #define uint      unsigned int
  6. uchar h;
  7. uint r=0;
  8. uint s;
  9. uchar code  dis[]={0Xc0,0Xf9,0Xa4,0Xb0,0X99,
  10.                   0X92,0X82,0Xf8,0X80,0X90,0Xff,};
  11. void delay(uint c)
  12. {
  13.    uint i,j;
  14.     for(i=0;i<c;i++)
  15.           for(j=0;j<100;j++);
  16.
  17. }
  18. //interrupt 1
  19. void t0(void) interrupt 0 using 1
  20. {
  21.   delay(2);
  22.    if(INT0==0)
  23.     {
  24.       r++;
  25.           if(r==2)
  26.            {
  27.                   r=0;
  28.            }
  29.           r%=2;
  30.           if(r==0)
  31.            {
  32.             P0=0xeb;
  33.         P1=0x00;
  34.         P2=0xff;
  35.            }while(1)
  36.             {
  37.                    if(INT0==0|INT1==0|T0==0)
  38.                   {
  39.                   delay(2);
  40.                   if(INT0==0|INT1==0|T0==0)
  41.                           break;
  42.                   }
  43.             };
  44.
  45.     }
  46. }
  47. //interrupt 2
  48. void t1(void) interrupt 2 using 1
  49. {
  50.   delay(2);
  51.    if(INT1==0)
  52.     {
  53.           r++;
  54.           if(r==2)
  55.            {
  56.                   r=0;
  57.            }
  58.           r%=2;
  59.           if(r==0)
  60.            {
  61.             P0=0xdd;
  62.         P1=0x00;
  63.         P2=0xff;
  64.            }while(1)
  65.             {
  66.                    if(INT1==0|INT0==0|T0==0)
  67.                   {
  68.                    delay(2);
  69.                    if(INT1==0|INT0==0|T0==0)
  70.                           break;
  71.                   }
  72.             };
  73.     }
  74. }
  75. //interrupt 3
  76. void t2(void) interrupt 1 using 1
  77. {
  78.   TH0=0xff;
  79.   TL0=0xff;
  80.     delay(2);
  81.      if(T0==0)
  82.        {
  83.             P0=0xdb;
  84.         P1=0x00;
  85.         P2=0xff;
  86.            }while(1)
  87.             {
  88.                    if(INT0==0|INT1==0)
  89.                   {
  90.                     delay(2);
  91.                         if(INT0==0|INT1==0)
  92.                           break;
  93.                   }
  94.             };
  95. }
  96. void main(void)
  97. {
  98.   TMOD=0x06;
  99.   TH0=0xff;
  100.   TL0=0xff;
  101.   TR0=1;
  102.   EA=1;
  103.   EX0=1;
  104.   EX1=1;
  105.   ET0=1;
  106.
  107.
  108. while(1)
  109. {
  110.     P0=0xeb;
  111.      for(h=28;h>0;h--)
  112.      {
  113.        for(s=248;s>0;s--)
  114.        {
  115.         P1=0x00;
  116.         P2=0xff;
  117.         P1=0x01;
  118.         P2=dis[h/10];
  119.          delay(1);
  120.                 P1=0x00;
  121.         P2=0xff;
  122.         P1=0x02;
  123.         P2=dis[h%10];
  124.                  delay(1);
  125.                 P1=0x00;
  126.         P2=0xff;
  127.                 P1=0x04;
  128.         P2=dis[(h+2)/10];
  129.                  delay(1);
  130.                 P1=0x00;
  131.         P2=0xff;
  132.                 P1=0x08;
  133.         P2=dis[(h+2)%10];
  134.          delay(1);
  135.        }
  136.      }
  137.     delay(248);
  138.     P0=0xf3;
  139.      for(h=3;h>0;h--)
  140.      {
  141.         delay(392);
  142.          P0=0xf3;
  143.          delay(1);
  144.         P1=0x00;
  145.         P2=0xff;
  146.         P1=0xaa;
  147.         P2=dis[(h-1)%10];
  148.          delay(600);
  149.         P0=0xfb;
  150.      }
  151.     delay(248);
  152.
  153.     P0=0xdd;
  154.      for(h=38;h>0;h--)
  155.      {
  156.        for(s=248;s>0;s--)
  157.        {
  158.
  159.                 P1=0x00;
  160.         P2=0xff;
  161.         P1=0x01;
  162.         P2=dis[(h+2)/10];
  163.                  delay(1);
  164.                 P1=0x00;
  165.         P2=0xff;
  166.         P1=0x02;
  167.         P2=dis[(h+2)%10];
  168.                  delay(1);
  169.         P1=0x00;
  170.         P2=0xff;
  171.         P1=0x04;
  172.         P2=dis[h/10];
  173.          delay(1);
  174.         P1=0x00;
  175.         P2=0xff;
  176.         P1=0x08;
  177.         P2=dis[h%10];
  178.          delay(1);
  179.        }
  180. ……………………
  181. …………限于本文篇幅 余下代碼請從51黑下載附件…………
C51交通燈.zip (82.17 KB, 下載次數: 46)
ID:267456 發表于 2017-12-27 10:33 | 只看該作者
很不錯的設計
ID:233789 發表于 2017-9-18 11:28 | 只看該作者
這個是幾個數碼管顯示的設計????
ID:110866 發表于 2017-6-24 18:45 | 只看該作者
不錯,設計的很完善
