基于51單片機的nRF24L01無線傳感模塊的接收個發送的程序。
2017-5-13 21:20 上傳
- #include <reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit RS = P0^2; //定義端口
- sbit RW = P0^1;
- sbit EN = P0^0;
- sbit DQ = P0^3; //定義總線的I/O管腳
- bit crrent;
- uint value;
- uchar data disdat[6];
- uchar data setdat[4];
- #define TX_ADR_WIDTH 5
- #define TX_PLOAD_WIDTH 2
- uchar const TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x55,0x10,0x10,0x01};
- uchar rx_buf[TX_PLOAD_WIDTH];
- uchar tx_buf[TX_PLOAD_WIDTH];
- uchar distance_data[2];
- uchar flag;
- sbit CE=P2^5;
- sbit CSN=P2^0;
- sbit SCK=P2^4;
- sbit MOSI=P2^1;
- sbit MISO=P2^3;
- sbit IRQ=P2^2;
- uchar bdata sta;
- sbit RX_DR =sta^6;
- sbit TX_DS =sta^5;
- sbit MAX_RT =sta^4;
- unsigned char time;
- #define READ_REG 0x00
- #define WRITE_REG 0x20
- #define RD_RX_PLOAD 0x61
- #define WR_TX_PLOAD 0xA0
- #define FLUSH_TX 0xE1
- #define FLUSH_RX 0xE2
- #define REUSE_TX_PL 0xE3
- #define NOP 0xFF
- #define CONFIG 0x00
- #define EN_AA 0x01
- #define EN_RXADDR 0x02
- #define SETUP_AW 0x03
- #define SETUP_RETR 0x04
- #define RF_CH 0x05
- #define RF_SETUP 0x06
- #define STATUS 0x07
- #define OBSERVE_TX 0x08
- #define CD 0x09
- #define RX_ADDR_P0 0x0A
- #define RX_ADDR_P1 0x0B
- #define RX_ADDR_P2 0x0C
- #define RX_ADDR_P3 0x0D
- #define RX_ADDR_P4 0x0E
- #define RX_ADDR_P5 0x0F
- #define TX_ADDR 0x10
- #define RX_PW_P0 0x11
- #define RX_PW_P1 0x12
- #define RX_PW_P2 0x13
- #define RX_PW_P3 0x14
- #define RX_PW_P4 0x15
- #define RX_PW_P5 0x16
- #define FIFO_STATUS 0x17
- void init_io(void)
- CE=0;
- CSN=1;
- SCK=0;
- void delay_ms(unsigned int x)
- unsigned int i,j;
- for(i=0;i<x;i++)
- j=108;
- while(j--);
- uchar SPI_RW(uchar byte)
- uchar bit_ctr;
- for(bit_ctr=0;bit_ctr<8;bit_ctr++)
- MOSI = (byte&0x80);
- byte = (byte<<1);
- SCK = 1;
- byte|=MISO;
- SCK=0;
- return(byte);
- uchar SPI_RW_Reg(uchar reg, uchar value)
- uchar status;
- CSN = 0;
- status = SPI_RW(reg);
- SPI_RW(value);
- CSN = 1;
- return(status);
- uchar SPI_Read(uchar reg)
- uchar reg_val;
- CSN = 0;
- SPI_RW(reg);
- reg_val = SPI_RW(0);
- CSN = 1;
- return(reg_val);
- uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes)
- uchar status,byte_ctr;
- CSN = 0;
- for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
- pBuf[byte_ctr] = SPI_RW(0);
- CSN = 1;
- return(status);
- uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes)
- CSN = 0;
- for(byte_ctr=0;
- byte_ctr<bytes; byte_ctr++)
- SPI_RW(*pBuf++);
- CSN = 1;
- return(status);
- void TX_Mode(void)
- CE=0;
- SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
- SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);
- SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a);
- SPI_RW_Reg(WRITE_REG + RF_CH,40);
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);
- CE=1;
- void checkflag()
- sta=SPI_Read(STATUS);
- if(RX_DR)
- SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);
- flag=1;
- if(MAX_RT)
- SPI_RW_Reg(FLUSH_TX,0);
- SPI_RW_Reg(WRITE_REG+STATUS,sta);
- void SendByte(unsigned char dat);
- void zf_1602(unsigned char x,unsigned char y,unsigned dat);
- void Delay4us() //延時4us
- void Delay(unsigned char j) //一個循環15us
- unsigned char i;
- while(j--)
- i = 5;
- while (--i);
- bit d18b20_qs() //18b20 起始
- DQ = 1; //DQ復位
- Delay4us();
- DQ = 0; //拉低總線
- Delay(35);
- DQ = 1;
- Delay(2);
- crrent= DQ;
- Delay(2);
- return crrent; //返回數值
- void d18b20_x(unsigned char dat) //寫 8 位 數 據
- unsigned char i;
- for(i=0;i<8;i++)
- DQ = 0; //拉低總線
- DQ = dat & 0x01;
- Delay(3); //延時45us
- DQ = 1;
- dat >>= 1; //數據右移一位
- unsigned char d18b20_d() //讀 8 位 數 據
- unsigned char i,dat=0;
- for(i=0;i<8;i++) //8位計數器
- DQ = 0; //拉低總線
- DQ = 1;
- if(DQ)
- dat |= 0x80;
- Delay(4);
- return dat; //返回讀取到數據數據
- unsigned int wd() //讀取溫度函數
- unsigned char i = 0; //低8位數據
- unsigned char j = 0; //高8位數據
- unsigned int k = 0;
- d18b20_qs();
- d18b20_x(0xCC);
- d18b20_x(0x44);
- Delay(200);
- d18b20_qs();
- d18b20_x(0xCC);
- d18b20_x(0xBE);
- i = d18b20_d();
- j = d18b20_d();
- distance_data[0]=j;
- distance_data[1]=i;
- k = j;
- k <<= 8;
- k = k + i;
- return k; //返回讀取到的16位數據
- void zh(unsigned int i)
- unsigned char x,z;
- x = i & 0x0f; //取出小數
- i >>=4;
- switch(x) //小數位轉換
- case 0: z=0;break;
- case 1: z=1;break;
- case 2: z=1;break;
- case 3: z=2;break;
- case 4: z=3;break;
- case 5: z=3;break;
- case 6: z=4;break;
- case 7: z=4;break;
- case 8: z=5;break;
- case 9: z=6;break;
- case 10: z=6;break;
- case 11: z=7;break;
- case 12: z=8;break;
- case 13: z=8;break;
- case 14: z=9;break;
- case 15: z=9;break;
- z = z +48; //轉換成ascii碼
- zf_1602(8,1,z); //寫入1602緩存
- z = i & 0xff; //取出整數
- x = z/10; //取出十位
- x= x+48;
- zf_1602(5,1,x);
- x = z%10;
- x= x+48;
- zf_1602(6,1,x);
- void Delayus(unsigned char t)
- while(--t);
- void Delayms(unsigned char t)
- while(t--)
- //大致延時1mS
- Delayus(245);
- Delayus(245);
- bit m_1602() //判斷1602是否忙
- P1 = 0xFF;
- RS = 0;
- RW = 1;
- EN = 0;
- _nop_();
- EN = 1;
- return (bit)(P1 & 0x80);
- void x_1602(bit i,unsigned char j) //參數一是寫(0、寫指令 1、寫數據),參數二是寫入的8位數據
- while(m_1602())
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- RS = i;
- RW = 0;
- EN = 1;
- P1 = j;
- _nop_();
- EN = 0; //產生下降沿
- void qp_1602() //清屏函數
- x_1602(0,0x01); //第一個參數是:寫入的類型(0、寫指令 1、寫數據),第一個參數是:寫入的數據
- Delayms(5);
- //顯示字符
- void zf_1602(unsigned char x,unsigned char y,unsigned dat) //參數一是顯示的列,參數二是顯示的行,參數三是顯示的數據
- if(y==0)
- x_1602(0,(0x80+x)); //第一行
- else
- x_1602(0,(0xc0+x)); //第二行
- x_1602(1,dat); //寫入數據
- void zfc_1602(unsigned char x,unsigned char y,unsigned char *dat)
- if(y==0)
- else
- while(*dat) //&:取地址 *:取值
- x_1602(1,*dat);
- dat ++;
- void csh_1602() //初始化1602
- x_1602(0,0x38);
- Delayms(5);
- x_1602(0,0x38);
- Delayms(5);
- x_1602(0,0x38);
- Delayms(5);
- x_1602(0,0x38);
- x_1602(0,0x08);
- x_1602(0,0x01);
- x_1602(0,0x06);
- Delayms(5);
- x_1602(0,0x0c);
- void Lcd_User_Chr(void) // 1602 自定義字符(攝氏度的小點) 自定義字符
- x_1602(0,0x48); //"01 001 000" 第1行地址
- x_1602(1,0x03); //"XXX 00001" 第1行數據
- x_1602(0,0x49); //"01 001 001" 第2行地址
- x_1602(1,0x03); //"XXX 11011" 第2行數據
- x_1602(0,0x4a); //"01 001 010" 第3行地址
- x_1602(1,0x00); //"XXX 11101" 第3行數據
- x_1602(0,0x4b); //"01 001 011" 第4行地址
- x_1602(1,0x00); //"XXX 11001" 第4行數據
- x_1602(0,0x4c); //"01 001 100" 第5行地址
- x_1602(1,0x00); //"XXX 11101" 第5行數據
- x_1602(0,0x4d); //"01 001 101" 第6行地址
無線收發代碼.rar
(5 KB, 下載次數: 48)
2017-5-13 13:04 上傳
無線接收和發送的代碼 下載積分: 黑幣 -5
