#include "reg52.h"
#include "intrins.h"
#include "main.h"
#include "rc522.h"
#include "string.h"
void delay_ns(unsigned int ns)
unsigned int i;
for(i=0;i<ns;i++)
nop();
nop();
nop();
// 讀SPI數據
unsigned char SPIReadByte(void)
unsigned char SPICount; // Counter used to clock out the data
unsigned char SPIData;
SPIData = 0;
for (SPICount = 0; SPICount < 8; SPICount++) // Prepare to clock in the data to be read
SPIData <<=1; // Rotate the data
CLR_SPI_CK; //nop();//nop(); // Raise the clock to clock the data out of the MAX7456
if(STU_SPI_MISO)
SPIData|=0x01;
SET_SPI_CK; //nop();//nop(); // Drop the clock ready for the next bit
} // and loop back
return (SPIData); // Finally return the read data
// 寫SPI數據
void SPIWriteByte(unsigned char SPIData)
if (SPIData & 0x80)
SET_SPI_MOSI;
CLR_SPI_MOSI;
nop();nop();
CLR_SPI_CK;nop();nop();
SET_SPI_CK;nop();nop();
SPIData <<= 1;
//功 能:讀RC632寄存器
//參數說明:Address[IN]:寄存器地址
//返 回:讀出的值
unsigned char ReadRawRC(unsigned char Address)
unsigned char ucAddr;
unsigned char ucResult=0;
CLR_SPI_CS;
ucAddr = ((Address<<1)&0x7E)|0x80;
SPIWriteByte(ucAddr);
ucResult=SPIReadByte();
SET_SPI_CS;
return ucResult;
//功 能:寫RC632寄存器
// value[IN]:寫入的值
void WriteRawRC(unsigned char Address, unsigned char value)
CLR_SPI_CS;
ucAddr = ((Address<<1)&0x7E);
SPIWriteByte(value);
SET_SPI_CS;
//功 能:清RC522寄存器位
//參數說明:reg[IN]:寄存器地址
// mask[IN]:清位值
void ClearBitMask(unsigned char reg,unsigned char mask)
char tmp = 0x00;
tmp = ReadRawRC(reg);
WriteRawRC(reg, tmp & ~mask); // clear bit mask
//功 能:置RC522寄存器位
// mask[IN]:置位值
void SetBitMask(unsigned char reg,unsigned char mask)
char tmp = 0x00;
WriteRawRC(reg,tmp | mask); // set bit mask
//用MF522計算CRC16函數
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
unsigned char i,n;
ClearBitMask(DivIrqReg,0x04);
WriteRawRC(CommandReg,PCD_IDLE);
SetBitMask(FIFOLevelReg,0x80);
for (i=0; i<len; i++)
{ WriteRawRC(FIFODataReg, *(pIndata+i)); }
WriteRawRC(CommandReg, PCD_CALCCRC);
i = 0xFF;
do
n = ReadRawRC(DivIrqReg);
i--;
while ((i!=0) && !(n&0x04));
pOutData[0] = ReadRawRC(CRCResultRegL);
pOutData[1] = ReadRawRC(CRCResultRegM);
//功 能:通過RC522和ISO14443卡通訊
//參數說明:Command[IN]:RC522命令字
// pInData[IN]:通過RC522發(fā)送到卡片的數據
// InLenByte[IN]:發(fā)送數據的字節(jié)長度
// pOutData[OUT]:接收到的卡片返回數據
// *pOutLenBit[OUT]:返回數據的位長度
char PcdComMF522(unsigned char Command,
unsigned char *pInData,
unsigned char InLenByte,
unsigned char *pOutData,
unsigned int *pOutLenBit)
char status = MI_ERR;
unsigned char irqEn = 0x00;
unsigned char waitFor = 0x00;
unsigned char lastBits;
unsigned char n;
unsigned int i;
switch (Command)
case PCD_AUTHENT:
irqEn = 0x12;
waitFor = 0x10;
break;
case PCD_TRANSCEIVE:
irqEn = 0x77;
waitFor = 0x30;
break;
default:
break;
WriteRawRC(ComIEnReg,irqEn|0x80);
ClearBitMask(ComIrqReg,0x80);
for (i=0; i<InLenByte; i++)
WriteRawRC(FIFODataReg, pInData[i]);
WriteRawRC(CommandReg, Command);
if (Command == PCD_TRANSCEIVE)
SetBitMask(BitFramingReg,0x80);
//i = 600;//根據時鐘頻率調整,操作M1卡最大等待時間25ms
i = 2000;
do
n = ReadRawRC(ComIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitFor));
ClearBitMask(BitFramingReg,0x80);
if (i!=0)
if(!(ReadRawRC(ErrorReg)&0x1B))
status = MI_OK;
if (n & irqEn & 0x01)
{ status = MI_NOTAGERR; }
n = ReadRawRC(FIFOLevelReg);
lastBits = ReadRawRC(ControlReg) & 0x07;
if (lastBits)
*pOutLenBit = (n-1)*8 + lastBits;
*pOutLenBit = n*8;
if (n == 0)
n = 1;
if (n > MAXRLEN)
n = MAXRLEN;
for (i=0; i<n; i++)
pOutData[i] = ReadRawRC(FIFODataReg);
status = MI_ERR;
SetBitMask(ControlReg,0x80); // stop timer now
return status;
//功 能:尋卡
//參數說明: req_code[IN]:尋卡方式
// 0x52 = 尋感應區(qū)內所有符合14443A標準的卡
// 0x26 = 尋未進入休眠狀態(tài)的卡
// pTagType[OUT]:卡片類型代碼
// 0x4400 = Mifare_UltraLight
// 0x0400 = Mifare_One(S50)
// 0x0200 = Mifare_One(S70)
// 0x0800 = Mifare_Pro(X)
// 0x4403 = Mifare_DESFire
//返 回: 成功返回MI_OK
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
char status;
unsigned int unLen;
unsigned char ucComMF522Buf[MAXRLEN];
ClearBitMask(Status2Reg,0x08);
WriteRawRC(BitFramingReg,0x07);
SetBitMask(TxControlReg,0x03);
ucComMF522Buf[0] = req_code;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x10))
*pTagType = ucComMF522Buf[0];
*(pTagType+1) = ucComMF522Buf[1];
status = MI_ERR;
return status;
//功 能:防沖撞
//參數說明: pSnr[OUT]:卡片序列號,4字節(jié)
//返 回: 成功返回MI_OK
char PcdAnticoll(unsigned char *pSnr)
char status;
unsigned char i,snr_check=0;
unsigned int unLen;
WriteRawRC(BitFramingReg,0x00);
ClearBitMask(CollReg,0x80);
ucComMF522Buf[0] = PICC_ANTICOLL1;
ucComMF522Buf[1] = 0x20;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
if (status == MI_OK)
for (i=0; i<4; i++)
*(pSnr+i) = ucComMF522Buf[i];
snr_check ^= ucComMF522Buf[i];
if (snr_check != ucComMF522Buf[i])
status = MI_ERR;
SetBitMask(CollReg,0x80);
return status;
//功 能:選定卡片
//參數說明: pSnr[IN]:卡片序列號,4字節(jié)
//返 回: 成功返回MI_OK
char PcdSelect(unsigned char *pSnr)
char status;
unsigned char i;
unsigned int unLen;
ucComMF522Buf[1] = 0x70;
ucComMF522Buf[6] = 0;
for (i=0; i<4; i++)
ucComMF522Buf[i+2] = *(pSnr+i);
ucComMF522Buf[6] ^= *(pSnr+i);
CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x18))
status = MI_OK;
status = MI_ERR;
return status;
//功 能:驗證卡片密碼
//參數說明: auth_mode[IN]: 密碼驗證模式
// 0x60 = 驗證A密鑰
// 0x61 = 驗證B密鑰
// addr[IN]:塊地址
// pKey[IN]:密碼
// pSnr[IN]:卡片序列號,4字節(jié)
//返 回: 成功返回MI_OK
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
char status;
unsigned int unLen;
ucComMF522Buf[0] = auth_mode;
ucComMF522Buf[1] = addr;
memcpy(&ucComMF522Buf[2], pKey, 6);
memcpy(&ucComMF522Buf[8], pSnr, 6);
status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
status = MI_ERR;
return status;
//功 能:讀取M1卡一塊數據
//參數說明: addr[IN]:塊地址
// pData[OUT]:讀出的數據,16字節(jié)
//返 回: 成功返回MI_OK
char PcdRead(unsigned char addr,unsigned char *pData)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_READ;
CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x90))
memcpy(pData, ucComMF522Buf, 16);
status = MI_ERR;
return status;
//功 能:寫數據到M1卡一塊
// pData[IN]:寫入的數據,16字節(jié)
//返 回: 成功返回MI_OK
char PcdWrite(unsigned char addr,unsigned char *pData)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_WRITE;
if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
status = MI_ERR;
memcpy(ucComMF522Buf, pData, 16);
CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
status = MI_ERR;
return status;
//功 能:命令卡片進入休眠狀態(tài)
//返 回: 成功返回MI_OK
char PcdHalt(void)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_HALT;
ucComMF522Buf[1] = 0;
return MI_OK;
//功 能:復位RC522
//返 回: 成功返回MI_OK
char PcdReset(void)
SET_RC522RST;
delay_ns(10);
CLR_RC522RST;
delay_ns(10);
SET_RC522RST;
delay_ns(10);
WriteRawRC(CommandReg,PCD_RESETPHASE);
delay_ns(10);
WriteRawRC(ModeReg,0x3D); //和Mifare卡通訊,CRC初始值0x6363
WriteRawRC(TReloadRegL,30);
WriteRawRC(TReloadRegH,0);
WriteRawRC(TModeReg,0x8D);
WriteRawRC(TPrescalerReg,0x3E);
WriteRawRC(TxAutoReg,0x40);//必須要
return MI_OK;
//設置RC632的工作方式
char M500PcdConfigISOType(unsigned char type)
if (type == 'A') //ISO14443_A
WriteRawRC(ModeReg,0x3D);//3F
WriteRawRC(RxSelReg,0x86);//84
WriteRawRC(RFCfgReg,0x7F); //4F
WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
delay_ns(1000);
PcdAntennaOn();
else{ return -1; }
return MI_OK;
//開啟天線
//每次啟動或關閉天險發(fā)射之間應至少有1ms的間隔
void PcdAntennaOn(void)
unsigned char i;
i = ReadRawRC(TxControlReg);
if (!(i & 0x03))
SetBitMask(TxControlReg, 0x03);
//關閉天線
void PcdAntennaOff(void)
ClearBitMask(TxControlReg, 0x03);
void init_rc522(void)
PcdReset();
PcdAntennaOff();
PcdAntennaOn();
M500PcdConfigISOType( 'A' );
//功 能:扣款和充值
//參數說明: dd_mode[IN]:命令字
// 0xC0 = 扣款
// 0xC1 = 充值
// addr[IN]:錢包地址
// pValue[IN]:4字節(jié)增(減)值,低位在前
//返 回: 成功返回MI_OK
/*char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
char status;
unsigned int unLen;
//unsigned char i;
ucComMF522Buf[0] = dd_mode;
{ status = MI_ERR; }
memcpy(ucComMF522Buf, pValue, 4);
//for (i=0; i<16; i++)
//{ ucComMF522Buf[i] = *(pValue+i); }
CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
unLen = 0;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
if (status != MI_ERR)
{ status = MI_OK; }
ucComMF522Buf[0] = PICC_TRANSFER;
return status;
//功 能:備份錢包
//參數說明: sourceaddr[IN]:源地址
// goaladdr[IN]:目標地址
//返 回: 成功返回MI_OK
/*char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_RESTORE;
ucComMF522Buf[1] = sourceaddr;
ucComMF522Buf[0] = 0;
ucComMF522Buf[2] = 0;
ucComMF522Buf[3] = 0;
{ status = MI_OK; }
if (status != MI_OK)
{ return MI_ERR; }
ucComMF522Buf[1] = goaladdr;
return status;
