查看: 15983|回復(fù): 12
MAX7219中文資料下載+單片機(jī)控制MAX7219點(diǎn)陣模塊源程序 原理圖
ID:169458 發(fā)表于 2017-5-8 20:35 | 顯示全部樓層 |閱讀模式
點(diǎn)陣資料加程序
MAX7219點(diǎn)陣模塊+控制模塊+單片機(jī)模塊+顯示模塊杜邦線5根
MAX7219原理圖:
MAX7219中文資料下載(pdf格式):
單片機(jī)源程序:
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint  unsigned int
  5. //定義Max7219端口
  6. sbit Max7219_pinCLK = P2^2;
  7. sbit Max7219_pinCS  = P2^1;
  8. sbit Max7219_pinDIN = P2^0;
  9. uchar code disp1[38][8]={
  10. {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
  11. {0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
  12. {0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
  13. {0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
  14. {0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
  15. {0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
  16. {0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
  17. {0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
  18. {0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
  19. {0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
  20. {0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
  21. {0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
  22. {0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
  23. {0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
  24. {0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
  25. {0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
  26. {0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
  27. {0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
  28. {0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
  29. {0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
  30. {0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
  31. {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
  32. {0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
  33. {0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
  34. {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
  35. {0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
  36. {0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
  37. {0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
  38. {0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
  39. {0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
  40. {0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
  41. {0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
  42. {0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
  43. {0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
  44. {0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
  45. {0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
  46. {0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//中
  47. {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//國(guó)
  48. };
  49. void Delay_xms(uint x)
  50. {
  51. uint i,j;
  52. for(i=0;i<x;i++)
  53.   for(j=0;j<112;j++);
  54. }
  55. //--------------------------------------------
  56. //功能:向MAX7219(U3)寫入字節(jié)
  57. //入口參數(shù):DATA
  58. //出口參數(shù):無
  59. //說明:
  60. void Write_Max7219_byte(uchar DATA)
  61. {
  62.             uchar i;
  63.                 Max7219_pinCS=0;
  64.             for(i=8;i>=1;i--)
  65.           {
  66.             Max7219_pinCLK=0;
  67.             Max7219_pinDIN=DATA&0x80;
  68.             DATA=DATA<<1;
  69.             Max7219_pinCLK=1;
  70.            }
  71. }
  72. //-------------------------------------------
  73. //功能:向MAX7219寫入數(shù)據(jù)
  74. //入口參數(shù):address、dat
  75. //出口參數(shù):無
  76. //說明:
  77. void Write_Max7219(uchar address,uchar dat)
  78. {
  79.      Max7219_pinCS=0;
  80.          Write_Max7219_byte(address);           //寫入地址,即數(shù)碼管編號(hào)
  81.      Write_Max7219_byte(dat);               //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
  82.          Max7219_pinCS=1;
  83. }
  84. void Init_MAX7219(void)
  85. {
  86. Write_Max7219(0x09, 0x00);       //譯碼方式:BCD碼
  87. Write_Max7219(0x0a, 0x03);       //亮度
  88. Write_Max7219(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
  89. Write_Max7219(0x0c, 0x01);       //掉電模式:0,普通模式:1
  90. Write_Max7219(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
  91. }
  92. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
完整資料下載:
MAX7219點(diǎn)陣模塊 控制模塊 單片機(jī)模塊 顯示模塊杜邦線5根.rar (512.56 KB, 下載次數(shù): 238)
MAX7219ERG-cn.pdf (1.37 MB, 下載次數(shù): 83)
評(píng)分
參與人數(shù) 1黑幣 +5 收起 理由
LQL-LQL + 5 共享資料的黑幣獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:1 發(fā)表于 2017-5-18 03:20 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:202142 發(fā)表于 2017-5-18 13:15 | 顯示全部樓層
非常好,謝謝分享~~
ID:203047 發(fā)表于 2017-5-21 10:40 | 顯示全部樓層
好資料,謝謝分享!
ID:222282 發(fā)表于 2017-8-30 18:53 | 顯示全部樓層
請(qǐng)問文件里面的原理圖是什么格式的?
ID:104845 發(fā)表于 2017-10-12 10:03 | 顯示全部樓層
好資料,謝謝分享!
ID:299298 發(fā)表于 2018-3-30 10:39 | 顯示全部樓層
在CSDN看過一個(gè)類似的程序,貌似有不完善的,具體表現(xiàn)為當(dāng)多片級(jí)聯(lián)時(shí)會(huì)出現(xiàn)鬼影現(xiàn)象;假設(shè)為5片級(jí)聯(lián),具體表現(xiàn)則為當(dāng)各片點(diǎn)陣屏顯示不同內(nèi)容時(shí),第3片屏?xí)霈F(xiàn)第一屏內(nèi)容的鬼影;第5片會(huì)出現(xiàn)第2片的鬼影
評(píng)分
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:495179 發(fā)表于 2019-3-21 10:39 | 顯示全部樓層
非常好
ID:158956 發(fā)表于 2019-3-21 18:13 | 顯示全部樓層
感謝分享,謝謝樓主
ID:527406 發(fā)表于 2019-5-5 09:40 | 顯示全部樓層
學(xué)習(xí)了 ,
ID:527406 發(fā)表于 2019-5-5 09:41 | 顯示全部樓層
感謝樓主分享資料。
無效樓層,該帖已經(jīng)被刪除
ID:246783 發(fā)表于 2020-3-26 11:51 | 顯示全部樓層
沒資料可以不發(fā)   弄個(gè)垃圾資料就不好了
ID:716017 發(fā)表于 2020-3-26 19:04 | 顯示全部樓層
http://www.raoushi.com/bbs/dpj-109401-1.html
這里可以下載,不需要幣
